- missing crank rod for spare tire
- 87 4Runner door smashed in. Questions.
- LCE Header O2 sensor causing CEL is normal
- TPS Question
- Yay! New DD: 4Runner #3
- Rear Driveshaft Bearing or Bushing Gone bad?
- shackle lift?
- 3.0 low compression on 1 & 2 after rebuild
- 22re turbo swap
- Anybody have experience with this tire?
- Advanced Adapters Radiator Install
- GoDan radiator = Transpro?....and other questions
- dry metallic scraping noise from the rear end, quieter when braking
- check it out
- ARB compressor mounting locations
- toolbox for 86 toyota
- Finally TIRES!!
- knocking in front end
- 98-00 tacoma climate controls in 89-95 truck
- Maximum tire size without a lift?
- Help with OBD codes
- ECT Switch
- 22re Not firing...injectors?
- Homade Body Lift Killing Me Plz Help!!!!
- thinking of parting out
- Oxygen Sensor problem.
- nocking
- 1988 Auto Tranny
- Where are your custom rear bumpers??
- Stuck cold start injector?
- my flex
- fuel pump cover/housing on gas tank
- 22r to 22rte conversion
- Interior finally done. Found gray buckets – PICS
- Anyone install a new upper ball joint lately?
- 3.0 to 22RE Swap Economical?
- its not new but i just gotta have em!!!
- interchangeable with a 3.4?
- Downey MAF modification
- Question about EFI Circuit Opening Relay on early 90's 4Runner
- Trouble removing rear brake line
- new knock sensor thread, Please look and give advice
- Best 1st Gen 4runner Suspension lift??????
- Transfer tank- what size/
- one man top removal tricks?
- 20r motor and tranny with stright axle
- Where to get a new factory style front bumper?
- rebuilt 22re wont start
- Intermittent spark - bumpy distributor movement
- Help ID this truck
- 22RE Distributor Drive Gear
- Where is a good place to get cheap/used parts?
- budget issues, need advice
- Anybody running a pro long block from LCE?
- valve adjustment cost
- What to expect with axle seals/wheel bearings?
- How to remove idler pulley on a 3.0?
- which pickup tailgate fits 90-95 runner?
- 86 pickup brake upgrade?
- Cost of swaps
- Turbo 22RE (9.4:1 compression) - how much power
- 22R-E Throttle Body Coolant Hose
- Pcv...
- Valve Cover Gasket
- Where to buy a TPS
- 90 4 runner needs doctor
- 86 4runner 22re AC Compressor clutch removal
- V6 front third member to a 4 cyl front, any issues?
- Rear Leaf Springs '99 Tacoma
- Need some help with bumper bolt size
- Coolant noise, help
- 1st gen truck seats in 2nd gen truck question
- 22RE - To Lube Head Bolts.. Or Not To Lube?
- 22re swap with 22r motor
- Older bumper on newer 2nd Gen?
- 4runner leafs beefier than pickup?
- 22re stupid questions...PITA BOLT, alternator, other side...?
- oil weight question
- What does this go to?
- Help with seats
- Pickup or 4Runner?
- Loud taco
- Flopping around in the engine?
- Yet another knock sensor question
- strange temp gauge
- Gears and MPG's
- Exhaust..
- one of these...
- Throttle body gasket.
- Help... 88 Truck Overheating
- Tune Up...
- custom exhaust question?
- motor swap??
- Leaking Oil?
- 33x1250s and 1" BL
- what is this thing - pix to help
- FYI on Husky Liners
- Shorted something out in my truck.
- Doing what she does best...
- how do Nokian Vativas compare?
- 93 v6 tcase issue
- Heres a new one, brakes make my 3.0 idle weird
- Overheating! Warning lights!
- Valve adjustment or not?
- Steering Pump Vacuum Switch
- replace the 3rd or replace the gears?
- Another No 4wd Question
- white residue on the radiator cap
- spare tire location
- 2.7 into a 94 t4r
- Installing A New Cam
- HELP. First 4runner is dead
- bob 98sr5 - or anyone else
- Oil pan gasket leaking?
- Brakes hiss loudly
- ecu compatibility help
- What is the Correct Thread for Installing Oil Pressure Gauge
- 22R STILL not running... SO confused...WTF??
- Timing chain FUBAR - need help!
- 22RE cold Start Issue.
- Is there a best stock 86-95 Truck/4runner engine?
- vapor canister
- Head gasket, time to replace?
- transmission question
- Lift and driveline questions
- Overheating / High Idle after day of wheeling
- Powertrax No-Slip Info
- 87 22R timing
- Radiator Fan On Constantly 91 4Runner
- Steering wheel nut striped
- passed smog, then engine light on?
- Suggestions for 2" lift on 94 Runner and Pickup
- 86 turbo 4runner\ what do you guys think?
- high idle. throttle sticking?
- HHO (Hydrogen Oxygen) gas on demand setup
- 22R Backfiring Like Hell. Exhast Questions
- Valve adjustment problems. HELP!!
- 4runner Gauges Mechanical or Electrical
- Do i have a 2nd gen 22-r please help
- Those with ARB bumpers on 1st gen 4runner
- Brake issues...
- How much CV angle is too much?
- V6 Chain Drive T-Case rebuild kit?
- Lucas - engine oil stop leak formula (Does this work)
- Sunpro 3pc. combo Gauge Installation Help
- 89 bed on a 86
- Post your GAS MILEAGE!!
- 86 turbo pickup turbo upgrade, now boost cut
- Poll: Where does your oil pressure hang out at?
- My new 33s
- 22ret swap in 94 toyota
- Wheel or tire problem?
- SR5 cluster install and oil pressure gauge
- $50 paint job.
- 3000 rpm screeching noise
- BFG 31's on a 22RE
- engine transplant
- 94 pickup body kits
- I'm hot, and you're not: The rear defroster that couldn't
- Famous "high idle/surge" culprits!
- Another TPS Question
- Removed fuel tank = won't start?
- Exhaust Question
- Alignment issue
- Is this a broken speedo cable ***pics included
- What would make an engine die instantly?
- Wow, crazy day.
- 90 4runner blowing turn signal fuses
- i want one of these
- 90 toy truck
- Hilux parts list
- winch decision
- 90 vs 94 alt on 3.0
- white smoke
- Best Riding Shocks For 3" OME Lift
- Steering Overhaul 89 IFS 3.0L
- Passenger side seat slider
- Rear sway bar bolts sheared
- need help....sr5 cluster swap
- 1990 4runner sluggish at low rpm need help
- Towing Advice
- 1990 4runner pulls to left and shudders while braking
- Wondering about gears and tires? here's my experience
- Gear setup gurus please help
- brake light 90 4runner
- got annihilated by smog today. also, timing issues.
- 22re to 22re swap...
- How Bad is this/Look what I can do!
- is this normal?
- help with codes. yes i searched.
- toolbox/manual security
- loss of oil pressure.
- rear suspension ??
- Toyota carpet
- 86 toyota 4 runner
- How Do I...? Help ASAP.
- 3.0 stops runing at speed
- Comin back, maybe
- help!!
- Ideas for blinker location.
- great 2nd gen f/s in Seattle (not mine tho)w/ARB,Downey etc
- starting problems after fire.
- 1995 3.0 motor parts for sale
- high rev when let off gas???
- Clicking Noise coming from intake.
- My new Project (56k be warned)
- 1995 22re... coolant in oil.
- odd hub issue
- shackle
- 22re no start after compression check
- t-case shifter ridiculously loud
- No injector pulse
- 99 4Runner won't idle
- Cold Air Intake for 22re
- 2wd toyota gas mileage?
- Spedometer Problem ( I think) and searched
- Lets see your bed storage setups...
- Pics of my finished rims on my truck
- Rebuilt 3.0 or JDM?
- 95 4runner auto hub replacement
- Dead cylinder...is what they told me?
- What do you think about 22re stright pipes??
- Trouble changing fluids
- 3.0 engine
- wont start
- 22RE Timing Chain R/R Troubles
- Aisin manual hub conversion
- Jacobs Ignition Crashes and Burns (surprised?)
- 22R-E idle
- Autozone Clutch?
- Pretty awful noise...on newly bought salvaged
- More surprises - how to get a spare tire down?
- flasher mod for LED's "Super Blinkers"
- O2 removal
- Has anyone swapped a 3rz in their truck
- Is this the correct Crank Pulley for a 22RE?
- 22re w/ LCE header to flowmaster sound clip
- Crappy idle + Rev limiter = Good idle???
- Whats that noise?
- Heavy White Smoke in Exhaust
- All Pro Rear Coils
- Rear wiper won't turn off!
- Used 3.0
- 1993 22re engine pinging
- 1986 22rte crankshaft
- Head gasket problem with rebuild
- Clunk on passenger side
- 3.0 egr removal write up
- 1 peice factory rear CV shaft???
