22R-E idle
Old Apr 7, 2008 | 09:24 PM
Skater78's Avatar
22R-E idle
idle screw does nothing. what now. dies when started cold and idles at 800 warm. want to raise it too 12 or 1500. used to think it had to do with the power steering deal cause they both weren't working and i know they are related. But I got the power steering fixed today and the idle is still off. The screw that I think is supposed to adjust the idle does nothing. spins up and down but does nothing. used to work before the head gasket/timing adventure
Old Apr 7, 2008 | 09:58 PM
thook's Avatar
Welcome to YT, Skater.
Up and down? I think you're messing with the A/C idle up valve. Large hex head top with a large spring? Leave that alone, for now.
The idle adjustment screw is located on the side of your throttle body.....a large flat head screw. But, leave that alone for now. Your idle is supposed to be 750-800rpm.
The only way the PS and idle are related is that the PS system relies on vacuum to operate the way it's designed. If there's a vacuum loss somewhere in that system....namely the two hoses that go to it and the valve they connect to...it will throw off the idle.
You said the "headgasket/timing adventure". Did you recently replace all of that recently?
Old Apr 8, 2008 | 05:14 PM
Skater78's Avatar
could my disrtibutor be off still? never did know for sure if i did it right. Yeah, i just finished doing the head gasket/timing a few days ago. Drives ok, just chugs if that's the word.
Old Apr 8, 2008 | 05:17 PM
just a 22re's Avatar
did you short the computer when you did the timing??? if you didnt then thats why its still all messed up
Old Apr 14, 2008 | 07:58 AM
Skater78's Avatar
Idle fixed
I think I solved the problem. My father-in-law was listening to it run and thought it sounded like it was sucking air. He sprayed starting fluid on different hoses and stuff and all of a sudden the rpm's went up for a second. I did some searching and found that a gasket tab had been folded up and wasn't sealing. Fixed that and now the idle adjustment screw works great! Idles nicely at 800 rpms.
Blamalam
Mar 12, 2022 07:34 AM
Marsheen
Feb 17, 2016 12:29 PM
GrimWolf
Aug 28, 2015 03:36 AM
Sarcazmo
Aug 15, 2015 08:22 PM
JAmdor3
Aug 11, 2015 10:53 AM
