PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266
  1. Can't find the o2 sensor plug!
  2. loose steering wheel
  3. 93 Pickup bad front hub/rotor problem
  4. Darn 3.0l
  5. Fuel issue - Fp +B jumper - no pump noise
  6. 1988 Toyota Pickup 22re ac R134 adaptor
  7. replaced drivers mirror now bad angle?
  8. Part #'s for OME shocks
  9. 3vze o2 sensor code 21
  10. 3VZE Crankshaft pulley
  11. Good Basic Upgrades for 87 pickup
  12. 1993 SR5 4x4 3.0 Fuel Gauge Sits at Half Full
  13. 91 pickup Transmission shifting before 30
  14. 88 22R Aisan Carb smells rich but runs great
  15. super high idle after 3vze head gasket job
  16. EGR deletion kit questions
  17. Throttle position sensor question
  18. Weird intermittent scratching sound
  19. 3vze idle question
  20. Idler Arm hit the bad nerve
  21. Brake pedal pulsing
  22. Engine rebuild and simplification
  23. 16 inch rims on 86 2WD Pickup
  24. '90 Pickup Hard Warm Start 22R
  25. 1987 Toyota Pickup Tranny noises
  26. knocking or tapping at idle only
  27. 3vze No start after sitting, has spark...
  28. 1994 3.0 water pump /timing belt
  29. Fender replacement on a 94 pickup
  30. Crack in radiator near cap (1993 pickup)
  31. Brake bleeder size
  32. 93 4runner rough idle/vapor locking
  33. Torsion bars and keys questions
  34. What do you have to do to get your Truck in the garage?
  35. 3VZ Valve Lifter/Bucket/Puck and shim kit?
  36. 93 3VZE pwr steering vacuum source
  37. Rear shocks for 87 runner
  38. '93 model 22re pickup sat for three years, trying to getnit started.
  39. 1994 auto transmission
  40. 1st Gen 4Runner Roll Bar to Bull Bar
  41. Rusty brake booster ???
  42. 1988 22RE Running Rough
  43. where to use permatex?
  44. Fuel pump mount bracket in tank, $339.20
  45. 22re stumbling and check engine code 2
  46. HELP!! 3vze upper plenum torque sequence.
  47. Tailgate elec connector detached in body.
  48. Tailgate & removal
  49. Water Pump/Timing Belt Tensioner
  50. What else should I do...?
  51. 86 Runner Budget Beefed up IFS
  52. A340f Reverse Light Switch Help!!
  53. 1994SR5 4X4 3.0 V6 Issues
  54. raw gas out the tailpipe of my 1994 4runner
  55. Replacement body panels
  56. Idler arm?
  57. Tranny issue
  58. Help? lost all but some power wont start
  59. Replacement engine 89 22re
  60. 94 pickup no click or no noise from fuel pump
  61. Question for tailgating
  62. Possible to drive with power steering disconnected?
  63. Time for new shocks!
  64. 83 to 87 motor swap...
  65. Odd brake issue binding midway through pedal poss booster or master
  66. 91 4runner 3.0l v6
  67. can you fit 35s on a SASd OME 2"hd springs
  68. Transmission help! no drive
  69. 1989 4runner power window replacement parts
  70. 1st Gen B-Pilar Replacements?
  71. how should I lift my 4runner
  72. 1986 5-speed 4x4 22r basket case. Worth it?
  73. torque specs
  74. Remove rotor from hub
  75. Odd charging circuit problem
  76. My 92 2nd gen
  77. OEM Toyota ball joint part # question
  78. Starter sticks and VERY rich/rough start when cold
  79. 22r to 22re swap idle problem
  80. so I got my first 4Runner! What should I do to it?
  81. 88 4Runner isn't running right after taking it Offroad and going through some mud
  82. 86 4runner, rough start and no idle
  83. Broken sway arm mount point in frame
  84. 1992 toyota pickup 4x4 3vz a340h trans DIES
  85. Sudden Loss of Power to Engine (92 pickup 4x4 22re)
  86. Brake upgrade t100 question.
  87. front sup/lift question
  88. EGR P&E vacuum ports don't create vacuum
  89. Coolant temp gauge question
  90. 86 4runner radiator replacement
  91. No fuel to the Cold start injector?
  92. SR5 gauge cluster swap problems
  93. Auxiliary AIr Valve Stuck open on 1988 3VZE 4Runner
  94. Goodbye Yota bretheren.
  95. 22RE - Put power steering belt on too tight. What damage could have been caused?
  96. Locker in the front or the rear?
  97. Head Ground Bolt Brokem
  98. 1988 22re 4Runner Starting Issue
  99. IFS upper arm stuck
  100. Ball joint press & torque question
  101. Pictures w/ ?s about hub/ cv axle/ hub spring?
  102. new to toyota questions
  103. 1987 Toyota
  104. Exhaust manifold area hiss (NEWBIE)
  105. 3.4 swap
  106. 1991 Back Door Dash Light
  107. Good budget 4" Lift?
  108. Need help with gasket ID
  109. 1988 4runner
  110. 1991 3VZE with standard trans bellhousing bolts
  111. 94 pickup knocking
  112. Best options for treating undercarriage rust on my 1990 Pickup?
  113. 87 pickup running problems
  114. 93' 3.0 code 71/idle issues
  115. 1990 4runner MT swap
  116. Wires destination
  117. My 1993 4runner 3vze A340H rebuild/mods show & Tell w/ LOTS OF PICS!
  118. Heavy steering when wet
  119. 1990 3.0 a/c
  120. 1988 Toyota 2WD - Rear brake hose tee stripped, what to replace with and where
  121. Newbie with 'new' 1993 pickup
  122. 1993 Pickup speedometer issues
  123. Plz help
  124. Brake to hub bolt torque
  125. Cd install kit
  126. 1988 Toyota Pickup 22re need help troubleshooting some issues
  127. crankshaft cleaning
  128. 92 4-runner oil in intake...
  129. Sensor identification help
  130. '94 5vz Swap Engine High RPM Vibration
  131. Do I grease this after cleaning? Or replace anything?
  132. 88 22R does not want to idle
  133. Manuaal to Auto swap
  134. 91 4runner 3.0l v6
  135. 3" bj spacer lift only 1.75"?...
  136. Ome leaf spring shocks suggestions
  137. Rain. Cranks But Won't Start. HELP
  138. 3VZ rebuild question
  139. TV adjustment 87 toy weber carb?
  140. 91 4runner STILL NO SPARK
  141. Knock sensor frustration!
  142. 87 Turbo Digital Dash Troubleshooting
  143. 2LT Diesel help
  144. Trans Swap Question? PLease help!
  145. Parts Store
  146. Regular guy with regular tools gear swap (Lots of pics)
  147. New 3VZ-E AISIN Oil Pump - Wrong Size O-ring
  148. No start issue need help ASAP
  149. Fan shroud replacement, ebay?
  150. Is this normal: 22re Dash oil light
  151. Diff and gear question
  152. Ignition problems
  153. Speedometer sensor 83181-35051
  154. 3vze rough idle, no power, no power brakes
  155. 3vze idle problem
  156. 91 2.4L Pickup Failed Emissions
  157. Window slipping off of manual regulator
  158. 91 pickup custom rear bumper (pic heavy)
  159. No brakes
  160. Quick question concerning an exhaust gasket replacement.
  161. 1987 4runner strange occurrances...
  162. Random stalling on startup?
  163. 22re strange top end noise
  164. 1st gen runner manifold take down???
  165. Zuk mod ?
  166. 22re timing chain jump?
  167. Shudder when braking (already replaced rotors and drums)
  168. '93 22RE flatlined now won't fire
  169. Windshield wipers come on when going through water
  170. Oil leak only with extended highway driving
  171. Has anyone used a "seatbelt repair" service?
  172. How to clean and adjust iacv
  173. Read so about Code 52 I feel like an expert...but still can't make it go away
  174. Intermittent idle drop
  175. Delete solenoid resistor
  176. 93 3.0 no check engine light
  177. 86 pickup with missing header bolts - how to fix
  178. Over heating, gauge says yes but reality says no???
  179. 1991 pickup. Bj spacers in front; what for rear?
  180. 94 3.0 overheating
  181. Time for a brake upgrade...a little help please
  182. Clutch Repair 86 4R, any favorite tools?
  183. 92' 5-Speed California 22RE Vacuum Diagram
  184. time for some good brakes...a little input please
  185. back door control switch?? 1st gen 4runner
  186. Oxygen Sensor help
  187. 90' 22r 2wd - Rythmic Vibration at Speed
  188. 3.0l spitting oil out of valve cover vent.
  189. Stock 22RE needs just a little more
  190. Old idle air bypass
  191. Introducing myself
  192. 23 Spline Tcase options
  193. Disconnecting and removing "Clutch Start Cancel" button
  194. Front drive shaft
  195. heater core please help!!!I have
  196. No Compression in 2 Cylinders
  197. 1989 toyota 22RE. 4cylinder
  198. old style iacv
  199. Front wheel bearing preload with A.D.D.
  200. 86 Toyota pickup 4x4 crank no start
  201. Drivetrain noise
  202. V6 ifs gear and locker question
  203. Almost always gated out of first gear from a stop
  204. 91 Pickup CEL Issue
  205. Should I replace other parts while doing wheel bearings?
  206. ARB Bumper Mounting after SAS
  207. 22re ecu/wiring issues
  208. can't shift after new headers installed
  209. Clunking in reverse
  210. 1992 yota 4x4
  211. Newbie help
  212. Please Help Me Identify this Belly Pan Location
  213. 95 SR5 V6 Speed/Odometer Issues
  214. Working on transforming my 86 4rnr
  215. 95 4runner 2wd v6 speedo cable and O/D blinking
  216. Speedometer swap on a 89 PU
  217. help! 22RE Vacuum issue?
  218. 22r. I think?
  219. Ac compressor bad bearing?
  220. Emissions Test Results 1993+164,000+3.0
  221. 22re 2barrel carb to 4 barrel
  222. Quick questions about A/C and heat
  223. Dash away,dash away,dash away all....
  224. Truck Stalls when in gear and I hit the Gas
  225. 22R Timing
  226. rear end chatter???
  227. 87 Totota Pickup 22r
  228. Coolant lose- bad head gasket or cracked head ?
  229. sr5 cluster swap issues
  230. 3vzfe Code 52 - Knock Sensor & Alternator Question
  231. Code 41/52 3VZe
  232. 22re coolant loss
  233. Crankshaft bolt help!!!!
  234. Ball Joint lube
  235. 3.0 to 22r engine swap question
  236. Water in intake. How screwed am I?
  237. What connection is this + Injector + Vacuum Related EGR Questions.
  238. 91 4x4 Project. "wrinkles"
  239. Damaged and dangling vacuum tank
  240. Introduction and Intermittent Start Issue - '90 SR5/MT/V6
  241. Brake booster vac lines dealer only ????
  242. Help! Not running on all cylinders.
  243. CEL Says too rich and too lean??
  244. Idle Speed Changes with Temperature
  245. 88 ecu question
  246. Ecu and harness for 3.4l swap
  247. Rough Idle and hissing noise problem.
  248. New owner of an 87 4runner - need some help!
  249. Pitman Arm Question
  250. Suspension lift kit??
