PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 [166] 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Buick 215 ci/3.5l V8?
  2. Let's hear some recovering/towing stories
  3. Inertia Switch - Does this exist in First Gen FI Rigs?
  4. What the heck is this thing?!?!
  5. 91 Long Bed Suspension Upgrade/Custom Camper Top?
  6. Just installed a cherry bomb muffler
  7. 4 inch IFS lift and spacers?
  8. 88 4Runner with big plans
  9. Can someone tell me where these wires plug into??
  10. 91 Toyota 4runner 4x4 problem
  11. Vehicle Inspection?
  12. 2nd alt for dual battery?
  13. Stock Leaf Springs
  14. 35s, 5.29s and lockers front and rear!!
  15. Front Shock/strut upper bushings
  16. SR5 Gauge Cluster Swap - How-to, with pics!
  17. 1986 4runner/a/c hose
  18. Crane Hi-6s/LX-91 problems
  19. brake plumbing question
  20. SR5 gauge swap question.
  21. new motor using oil
  22. BIG 3 wire upgrade?
  23. 22re low idle, AFM??
  24. Slider Questions
  25. Window regulator rear hatch??? Where to buy?
  26. 88 knock sensor in a 92
  27. Getting rid of my 86
  28. 22rte starts up then dies after a couple of seconds
  29. 3.0????
  30. 93 4Runner New 3.0 for sale Virginia
  31. Can you identify this wheel?
  32. Auto gear shifter really sloppy.
  33. lift questions
  34. While trying to figure out why my A/C wasn't working...
  35. Lift or soft top? What would you do?
  36. Holy Crap, 17 mpg?
  37. chasing down this idle demon
  38. Dash Lights
  39. Oil filters
  40. Pinion nut tightened on its own?
  41. Cold Weather Wonders
  42. Your carb problems solved
  43. Smoking Engine
  44. 1987 toyota extra cab 350 swap, should i trade?
  45. 22RE hesitates on accelleration when cold, smell like raw fuel
  46. speedometer cable question
  47. 2" suspension lift?
  48. Will the W50 bolt upto a 22RE?
  49. IFS front housing twisting
  50. Storage Boxes...
  51. regear question?
  52. Ubolt Flip KIt
  53. Code 7 and 11
  54. Nice mod?? (Jeeper comment)
  55. What are the hoses on the bottom of the PS pump?
  56. 91 4 runner rear window wiring
  57. sudden idle drop. 1989 22re
  58. Post pics of your regular cabs
  59. Any HD CV axles for IFS????
  60. Auto to manual swap
  61. First gen hard top
  62. Just stopped running - think it's fuel related
  63. Power steering belt twisting at the bottom when engine is running
  64. will a95 4runner 3.0L A/C fit into 2.2L 4runner?
  65. Gear time
  66. Factory Alarm diagram??
  67. Rich and Lean mix at the same time??
  68. annoying rattle in front end???
  69. Hyper Extened CV joint
  70. Electrical problem. Please help!
  71. eletric fan mod yes or no?
  72. timing chain alignment help!
  73. Is there any disadvantage to running a crankcase breather on a 22r?
  74. kyb gas adjust shocks good buy?
  75. Burning coolant after head gasket (3VZE)
  76. Damn, found cancer on my baby.....not sure how to deal with it(pics)
  77. T-Chain Slap..
  78. W56A, or W56B???
  79. Good starting point for troubleshooting...
  80. Girlfriend's New Truck!!
  81. Scion Seat Install... AGAIN.
  82. people with 4" sus. and 3" bodly lift
  83. need to see some pictures....
  84. hey guys need some advise on setup please
  85. If your 22RE uses Antifreeze then read this
  86. Brake Issues
  87. New ISR idea!
  88. key switch wont turn
  89. 1992 4Runner - Rusted Rear Brake Line.
  90. Really need help hestitaing and stumbling!
  91. pulled the top off and busted the A bolt sensor thing. Options?
  92. Pan Hard Bar Bolt Removle
  93. alignment shops and spacers?
  94. newbie question 92 4runner please advise
  95. smittybilt bumper
  96. SuperBleeder scores BIG at the salvage yard today!
  97. 88 22re
  98. Tach question
  99. Anyone make solid yellow side marker lights for 3rd gen pickups?
  100. Heavier Flywheel Question
  101. Torsion Bars
  102. New Clutch won't work
  103. Valve cover gasket ? for 92 3VZ
  104. Started some rust removal today...
  105. HELP!!! not getting fuel.....
  106. Exhaust manifold removal/installation tips
  107. New to me v6 5spd has no power...
  108. 22r HELP
  109. Will these shocks fit?
  110. Best place to buy a rebuilt/reman 3vze?
  111. Running board removal help
  112. more TPS issues and higher idle
  113. ENGNBLDR questions
  114. 4x4 Not working.
  115. transmission question
  116. Changing wheel sizes
  117. Will not start once truck gets hot.
  118. Low oil pres after complete rebuilt 22RE
  119. oil pressure 22re
  120. Is My Rear Diff too hot?
  121. Spark Plug Wires
  122. ignition problems
  123. Timing at 20*
  124. Steering wheel pad Removal ???
  125. weird idling problem
  126. Getting vacuum to EGR at idle?
  127. "Budget" 3.0 rebuild
  128. Possibly my master cylinder?
  129. Dual Batteries
  130. Wheel interchange
  131. rear end question
  132. Matt16, Aussie question for you
  133. MPG's have gone up on the 89, very happy.
  134. Adjusting torsion bars
  135. 1 inch coil spacer 93 runner HELP
  136. Help Changed cold start injector no run anymore 3.0
  137. IFS guys
  138. plugging the abs sensor
  139. Starter Fixed, Thanks 4Crawler/Yotatech!
  140. My New Custom Front Skid Plate
  141. Does anybody have MegaSquirt base maps?
  142. un-lowering
  143. Mystery sounds
  144. I'm betting nobody's heard of this one
  145. finally ordered my sas kit from trail gear
  146. read this for a giggle clutch
  147. Hard to come out of 4WD
  148. crawl box t-case question
  149. whats the stock offset on 94 pickup?
  150. 89 yoda starter
  151. help on waterpump and timing belt
  152. Clutch replacement questions
  153. Clutch question
  154. 3.0 L Head Gaskets Help !
  155. Is this a rare 1988 xtra-cab pickup 4x4 SR5?
  156. Something squeaking when I reverse?
  157. speedo cable question......
  158. truck makes a clunking noise turning right.
  159. How do pull codes in an 86 22re?
  160. 1988 4 Runner 22re engine codes
  161. 91' 4Runner 3.0 Head gasket replacement HELP
  162. Think my truck can make it 600 Miles?
  163. Stock 89 runner radio, yup it's retro!
  164. gotta love free toyota parts
  165. 86 4Runner doesn't want to run when raining
  166. 1st gen 4runner Auto Trans
  167. A bit short on the t-case fluid...
  168. About to give up!!!! OVERHEATING!
  169. Factory 4.88 diff with tacoma e-locker?
  170. Bad brake booster?
  171. new bumper valance?
  172. HELP Strange moving Timing mark problem.
  173. Easily Removable Side Steps
  174. New cam time - what will I need?
  175. smashed my climate control faceplate..!arg.
  176. rear axle noise
  177. Fuel rail question
  178. where i can get some stock lookin body graphics?
  179. Rear Window Track Part Number(s)
  180. Help identifying part
  181. 3.0 Surging when breaks are applied
  182. recommend gear for 33x12.50 tires
  183. Let me see your black paint job.
  184. Brake pressure
  185. Head gsket
  186. Going into the heads for the first time.
  187. Free Carpet
  188. about to buy enginebuilder RV cam, some questions
  189. extending dif breathers quick question
  190. Driveshaft Delima
  191. Diff parts - Compatibility ???
  192. hub?
  193. Flowmaster muffler on my 2nd gen Runner!
  194. Help, way too much oil.
  195. Lots of Toys in my driveway
  196. Anti freeze through spark plug hole
  197. Auto trans question
  198. valve gurgle?
  199. Valve chatter extremely bad when warm.
  200. need a part anyone got one?????????
  201. Round peg, Square hole. Shifter Lever Problems
  202. head unit problem 94 PU
  203. 93 Toyota Pickup 22re overheating problem
  204. need some diagnostic help with code on 3vze
  205. 22r crank sleeve
  206. Check engine light
  207. 1989 pickup - starting issues
  208. 1st Gen 4runner Roll Bar Question
  209. How do I tell if my cv's are bad?
  210. My New Lights
  211. Sunroof Help
  212. EGR modulator filter
  213. my difinitive "running rough" thread
  214. marlin crawler rear bumper with 3 inch body lift
  215. Toyota Part #'s needed, please for Calipers
  216. Switching out gauge cluster with SR5 gauge cluster
  217. Anti freeze through exhaust
  218. '91 3.0 Chewed distrib. gear- New or used cam?
  219. Gauges are in....check.
  220. good bye 4Runner
  221. I screwed up on the timing chain
  222. do BMW rims fit?
  223. New Power steering pump pulley?
  224. Timing Chain Noise?
  225. 14 mpg?! 22RE
  226. what kind of lift kit is this
  227. EGR/Vaccum Question?
  228. need help deciding on tires for my 4runner
  229. Stalls out
  230. What angle will a runner roll?
  231. Ecu Problems? Need some help
  232. body swap ??'s
  233. Leaky heater core in the 91 PU...
  234. Toyota Inclinometer question
  235. Fuel Economey problems, 4runner cold start injector disconnect?
  236. 22r alternator problem
  237. 1986 toyota 4runner with a 22re engine cutting out badly
  238. 93 4runner and 95 pickup 4 sale
  239. hard to start - 10 seconds of cranking before it fires
  240. Difference between injectors.
  241. No Tail Lights HELP !!
  242. Building one truck from two?
  243. How hard is it to take a 4runner body of the frame?
  244. quick help with drum brake
  245. New to me! '89 Xtra cab pickup
  246. Injector wiring issues
  247. damn auto hubs
  248. 2 problems, may be tied together?
  249. Wheel Question
  250. Maintenance receipt porn
