ignition problems
Old Apr 5, 2009 | 11:32 AM
country lambo's Avatar
ignition problems
i gotta a 88 yota pickup just rebuilt 22re not good spark at #2 and#3 cylinders also runnin real rich any suggestions.
thanx
Old Apr 5, 2009 | 11:35 AM
scope103's Avatar
If you don't have good spark on a cylinder, all the unburned gas goes out the tailpipe. Is that what you mean by running rich? If so, check the plugs, plug wires, distributor cap.
Old Apr 5, 2009 | 02:44 PM
abecedarian's Avatar
The firing order is 1-3-4-2... 3 & 2 are on opposite sides of the distributor... so how are the distributor cap, wires, plugs, rotor? ... the bearings in the distributor shaft?
Are all the spark plugs' gaps adjusted properly?
Have you tried adjusting the valves?
Is the cold start valve leaking when the engine is running?
Old Apr 5, 2009 | 03:41 PM
desert-rat660's Avatar
sounds like u have some wires crossed
Old Apr 5, 2009 | 04:42 PM
j0hNnI's Avatar
+1 for adjusting the valves or checking the injectors ive had a problem like that in a honda that i used to have
Sleaker
Aug 26, 2020 06:03 AM
nickb3
Jul 21, 2015 10:00 AM
rushw
Jul 18, 2015 01:46 PM
Hamonacracker
Jul 17, 2015 08:33 AM
94whiterunner
Jul 12, 2015 07:15 PM
