91 Toyota pickup ignition switch, key will not turn!!??
Old Jul 16, 2015 | 09:04 AM
Hamonacracker's Avatar
Ok I have a 91 Toyota pickup dlx and I have been driving it for at least a year and a half now and not long ago it started having problems where the key wouldn't turn but I would play with it for a few seconds and it would turn!!! But now It won't at all, I was as a convenience store to get a drink and a snack and I come back out at try turn the key and it wouldn't I had to play with it for at least 5 or so minutes and it finally turned but, I woke up this morning and it wouldn't turn at all and it still has not showed any signs of it wanting to turn. I've read a few forums saying to lube the key and ignition and I have tried that!!! Any other tips or tricks anyone can give me on how I can get my key to turn???? Much appreciated!!!👊🏼
Old Jul 16, 2015 | 11:14 AM
v_man's Avatar
Might be an urban myth , but I heard tiny metal shavings build up in the ignition cylinder over time , from the key, so maybe get some compressed air in there , blow it out? Other than that, it's pretty easy to get into the ignition , just remove a few plastic bezel pieces and maybe you can see something blocking it ...
Old Jul 16, 2015 | 03:01 PM
Ok thanks I will try when I get he chance!!!
Old Jul 16, 2015 | 03:12 PM
taller1's Avatar
Is your key old and worn? Does it work in the door?
Maybe try another key
Old Jul 16, 2015 | 11:40 PM
wyoming9's Avatar
Red face
It might be to late but like all rotating metal parts it does need lube from time to time
As well as all the other lock cylinders
Old Jul 17, 2015 | 03:46 AM
erndog's Avatar
I had mine blocked because a small piece of plastic inside hung up on the tumbler.
Old Jul 17, 2015 | 06:40 AM
Team420's Avatar
Go to the dealer with your registration or title in hand, have them cut a new key for $5 (DO NOT COPY YOURS) profit, thank me later
Old Jul 17, 2015 | 08:33 AM
Odin's Avatar
On key and lock cylinders Tri-Flow is your friend.
I've never had a dealer make me a new key but I probably should.
I have had a locksmith make me a fresh key before. I believe all they needed was the number off of the key cylinder. Some manufacturers put the key code in different areas though. From a looks standpoint it probably won't be an exact match to the Toyota key but the cut should be identical. If they're the ones who have to physically look On Your Car for the number the cost goes up quite a bit.
Copies will always be ever so slightly off. A copy of an original should only be made off of a key that's hardly ever been used as it just adds to the imperfections.
A copy of a copy.. when I was a kid most locksmiths refused to do that.
Aleeex_u
Jun 5, 2016 06:52 PM
alfonz33
9
Nov 16, 2015 09:21 AM
Gamble_STi
Jun 27, 2015 07:54 PM
paxanders
Jun 21, 2015 06:29 AM
infinityisfive
Jun 16, 2015 06:51 PM
