Your carb problems solved
Old Apr 8, 2009 | 03:32 AM
Tony Battista's Avatar
Exclamation Your carb problems solved
Here are alot of questions answered for me and im shure some of you about the 1984-86 carb on the 22R made by Aisin.
http://www.bluebassdesign.com/boonin/carb_faq/
just have one question can my 4runner run with out the idle-up diaphram?
Old Apr 8, 2009 | 09:40 PM
desert-rat660's Avatar
toyota solved the carb problem with injection
Old Apr 8, 2009 | 09:43 PM
algranger's Avatar
YEah and added a whole new, more complicated array of problems
Are you talking about removing the whole idle up diaphragm or just disconnecting it?
Old Apr 9, 2009 | 05:38 AM
injection is easy and it wont stall out when rock crawling
Old Apr 9, 2009 | 08:25 AM
talking about i dont have an idol up diaphragm and i need to switch out my carbs from a webber piece of junk to a stock 85 carb and it did not come with the idol up diaphragm. and if you read the article you can fix the problem of stalling while going up and down steep hills by using a drainage hose running from the bowl to a container so when the bowl fills up with gas it goes out the hose instead of flooding the engine.
Old Apr 9, 2009 | 10:00 PM
Just Learning's Avatar
well, i have a holley with all of the hill climbing stuff and it work really good, fuel inject is good to but dont starve the pump, i really think the way to go is propane, but then if you go for, oil pan baffle plates, ps my stock , then replaced with weber really did not work well , the set up i have now works really good
skoti89
Sep 11, 2015 07:46 AM
ddg71
Jul 24, 2015 01:24 PM
keithporter83
Jul 24, 2015 07:37 AM
Yota.Jay
Jul 23, 2015 08:08 PM
