PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 [102] 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. EGR Filter?
  2. Code 14 fun (3vze)
  3. Vacuum Hose Re-Routing?
  4. 86 SA 4runner, 83 truck springs in the front?
  5. 92 4runner Stinger Brushgaurd/ Bumper and Lights
  6. New 22RE (700 miles) having trouble after sitting for awhile
  7. Never Sell Your Truck!
  8. 94 4runner to 91 Pickup Power Window Swap?
  9. loud screaming noise when cold
  10. Gas smell up front
  11. 89 yota pickup and 95 motor
  12. Header identification: NWOR?
  13. 22RE Poor Fuel Milage
  14. 4Runner - RPM cut off in low range
  15. Post pics of your TG winch plate based bumper.
  16. oil leak
  17. 1990 toyota pickup4x4 22r to 22re, and wreck repair.
  18. Name this part!? 90 3vz engine electrical
  19. How are my compression numbers?
  20. 02 sensor question
  21. 1990 v6 3VZE pickup starts, but dies
  22. Metallic noise in clutch or transmission
  23. Throwout bearing or input shaft bearing???
  24. 22r coolant pipe behind engine
  25. 1st gen runner tailgate removal
  26. egr operation,poor idle
  27. Alternator Locked Up?
  28. Speedo Cable Installation
  29. Wiring in Electric Temp gauge... lighting help
  30. Shifter slipping?
  31. 88 4runner header
  32. 3VZE engine wire routing?
  33. 90-95 4Runner Auto Shifter Console - How Do I Replace The Bulb?
  34. 91 pickup sway bar bracket bolt size?
  35. Coolant disappeared but no leak!!?!!
  36. 5sp swap... no 4wd light or reverse lights
  37. 86 4runner bright light and stereo issue
  38. 95 4runner trans problem *searched...no luck*
  39. Spare tire removal...
  40. disc warpage?
  41. why can't I find bilsteins for BJ spacers up front? 10'' compressed?!!
  42. 86 yota sas
  43. Quick Question: Separating Engine from Bell House
  44. 86 22re wont start after alternator and water pump replacement.
  45. Buying 1986 4runner today
  46. junkyard 3vze timing belt removed, out of time
  47. 88 4runner sloshing
  48. Cold Start Comparison
  49. Where do I gof from here?
  50. Venom Super Flow Fuel Injectors?
  51. Replacing power lead to under hood fuse box
  52. ugghh...replacement Diff. problems.. any ideas
  53. 300 bucks to spend. What to buy for 87 4r!
  54. CV/front axle/front differential removal...
  55. 1st 4Runner gen cup holder
  56. 3VZE knocking when applying and releasing gas pedal
  57. Freezing inside windshield
  58. 91 Pickup headlight retrofit to HID projectors
  59. Blazeland lift, need steering parts. Total Chaos heim upgrade?
  60. reading codes without a scan tool
  61. 4wd not engaging...
  62. 93 4runner 3.0 with CEL 21
  63. 1/2 ton or 3/4 ton 63s whats the difference for flex?
  64. 5.29 rear pinion bearing
  65. Not happy with the stock height/looks of my 89 2WD pickup
  66. how important is to have a thermostat?
  67. Rough Road Fabrication 4Runner Mid Travel Setup
  68. Cold Start injector
  69. Welded 4.10s question
  70. No Brake Pressure at first.
  71. Using Carling Contura Rockers to Replace Factory Window Switches
  72. grinding 2nd and 3rd
  73. Want center brake light for '90 truck
  74. Any pics of 86 green A/C button?
  75. Lots of Oil in Intake!
  76. 22re rear end w/ mods or V6 rear end for ELocker
  77. Replace 22re after head gasket issue?
  78. 87 Window problems-help plz
  79. E-Brake doesnt work sometimes
  80. Transmission leak and shifting problem
  81. Write up on replacing heater core with A/C?
  82. loud ticking noise in 95 4runner
  83. 95 4Runner front and rear diff ratio question
  84. Question about code 71 and yes, I've searched
  85. Brake shoe drag?
  86. running horrible please help!!
  87. how do I check A/T codes
  88. No cluster, tail or running lights.
  89. custom grille mod
  90. Exhaust Manifold Question
  91. automatic transmission problem
  92. Help! My 4runner's turning against me!
  93. Another Rear window issue
  94. Windows hard to roll up when cold
  95. Transmission cooler question
  96. Need advice on transmission!
  97. Tranny, O/D light, speed sensor?
  98. 1st Gen 4Runner: Removing Blower Motor without removing HVAC box?
  99. What sensor makes engine idle fast on cold starts
  100. Long bed
  101. Figure this one out Guys! Noise issues
  102. 2L-T Surf Exhaust build advice.
  103. Clutch ticking
  104. Couple questions.
  105. I lost my beloved truck, but got a replacement.
  106. 94 4runner solenoid problems
  107. 22RE O2 Sensor wiring help
  108. Heater Core flush advice 90 3vz 2 door model
  109. odd fuel problem
  110. Switching to 4:88's at home
  111. 3.0 engine removal help
  112. 95 4Runner Build/Rebuild
  113. Windshield glue?!?!?!!
  114. Fuel Pump Issue
  115. how to remove window trim on first gen 4runner
  116. 22re Rebuild Finally Done With Picts.
  117. code 52 on 91 runner 3.0
  118. Where is the OBD port in 1994 4Runner
  119. Anything in Auto Tranny to Look at While Engine's Out?
  120. New carb issues
  121. 4x4 will not engage
  122. Rubbing noise up front when turning cold
  123. 22RE leakage question
  124. 88 3vze cold start injector fuel line $120??
  125. 3VZ overheating
  126. Oil Pump Spline Timing Cover?
  127. 94 4runner won't shift to 5th
  128. Aluminum ARB-style bumper for my 1st gen 4Runner (Aluminess)
  129. Rubber shift boots for 86 4Runner
  130. 22RE engine help
  131. 93 4Runner won't start
  132. Converting manual windows to auto
  133. Front Brake Cable Replacement 93 4Runner SR5 (22RE)
  134. 4runner tailgate issues
  135. New Purchase: 90 Toyota Truck 4x4 Ext Cab
  136. coolant gauge problems
  137. '88 4runner - How are the wiring harnesses broken down?
  138. "A" Pillar > Interchangeability
  139. 84 22r in a 91 22re truck
  140. Urgent: Moonroof Assistance
  141. Hub bodies - auto v. manual
  142. Won't rev past 4300 when floored
  143. EGR Temp sensor code after header install (code 71)
  144. Disconnecting front driveshaft
  145. So it's true, I need a headgasket
  146. Where to get gasket?!?
  147. hard start AC compressor
  148. Evolution of 1st Gen 4Runner Decal :)
  149. Noise When 4WD Engaged
  150. 92 Toyota Truck, 22re wont start cold
  151. Check engine light won't rev past 2k
  152. Truck won't stay running
  153. rear end problems
  154. They stole my truck, then we found it...
  155. 92 toyota pickup won't start when hot
  156. 95 AT takes a while to shift into OD
  157. 89 4runner idle surging
  158. 94 4wd 4cyl starter issue
  159. 6 simple steps for pulling upper ball joints
  160. speedo cluster removal
  161. What springs are these???
  162. Uneven brakes
  163. Headers Save Head Gaskets?
  164. Scrapping a truck...what to keep...
  165. Power steering question...sorta...
  166. '90 4 runner sag, air shocks?
  167. Picture request: 3rd gen Tacoma rims
  168. driveline vibrations
  169. 1991 toyota 22re lower efi manifold question
  170. 3VZE speed
  171. front end maintanence
  172. 1ton Fender Badge?????
  173. 91 22re Intake swap onto a 85 22re question
  174. Pulled off my rear driveshaft and found this...
  175. Engine Stuttering 22RE 5spd
  176. heating issue
  177. 1995 3VZE won't start
  178. 22ret Vs. 22re
  179. New noise coming from front of 86 Pickup 4x4
  180. 1986 Toyota frontend rebuild question...
  181. E locker swap into abs truck?
  182. Rear Window Problems....AGAIN!!
  183. Timing belt install..witness marks
  184. Engine problem question
  185. head gasket/timing chain -- what else shoudl l do?
  186. 1995 4runner will not engage into 4wd
  187. 32s up front with 33s in rear. terrible idea?
  188. Rough idle but smooths out with strange problem
  189. 22RE rattling noise when decelerating
  190. Thanks To This Site/Forum/Members
  191. 22RE running rough at 2000rpms
  192. Valve stem seal question
  193. VSV for fuel pressure control
  194. Electrical Issue PLEASE HELP!
  195. New LCE injectors, now fuel pressure leak?
  196. stripped #6 sparkplug any suggestions?
  197. 89 22re vs 91 22re....Any major differences?
  198. Bleeding power steering pump.
  199. Replacement of power steering pump on '93 4 Runner
  200. Blower motor screws
  201. How to get better fuel mileage
  202. Another oxygen sensor question-94 22re CA
  203. 94 won't start, oil problems, heat problems/I'm new, hi!
  204. steering issues
  205. How to remove light
  206. 3.0 Plenum Removal
  207. overdrive light bulbs
  208. Changing fuel pump
  209. Bringing the 4Runner back to life!
  210. She's Alive (Very Pic Heavy)
  211. OEM remanufactured starter grinding noise?
  212. First timing chain, Help!
  213. 89 4 runner winter build
  214. Idle problems after AFM swap in 86 4runner
  215. 90 4runner 3.0 with a loud tick
  216. 1992 4runner wont run when hot
  217. I cannot break the cam gear bolts loose
  218. No start up, No electrical power
  219. 4x4 issue
  220. OBD-1: testing the test port?
  221. 88 22re engine cuts out
  222. 88 v6 into 91 v6
  223. Overheating question?
  224. Aftermarket FI timer switch?
  225. 22RE startup issue
  226. 83 22r to efi?
  227. 92 22RE will not start
  228. 91 pickup - 4WD TROUBLE
  229. Switching EGR vac diaphragms on 3VZ-E?
  230. 4wd actuator issues
  231. 22re Oil Level gauge not working!
  232. How much oil does yours leak?
  233. little vid of my 7m truck
  234. 2nd gen '02 TacoRunner conversion..
  235. 3vz starter problem
  236. 1991 won't start when cold!
  237. Bent Spark Plug, Missing on Cylinder 4
  238. good protective oil for fresh 22re's?
  239. 1st gen SR5 seats in a 1986 toyota pickup 2wd question
  240. Blew a hole in Rear Differential
  241. A/C on causes RPM drop and engines shakes at idle
  242. 1994 v6 3.0L 4runner - check engine light, low(ish) oil pressure, help please!
  243. 22rte idle/starting issues. Not your average issues
  244. 89 toyota truck....help with O2 sensors...
  245. Quick release doors
  246. Idiot question regarding header install.
  247. solenoid resistor jumped wire
  248. Crank but not start after engine swap
  249. Engine Rattles
  250. PS Fluid in PS Pump ~ Research has been done ~ Just a few Q's
