overdrive light bulbs
Old Nov 28, 2011 | 10:16 AM
gottadog's Avatar
I can not find the damn bulb that I need. Anyone familiar with them? They are small bulbs with a twist type connection and a little colored rubber cap over the bulb. I can't find them at any auto stores or online.
Old Nov 28, 2011 | 10:22 AM
gottadog's Avatar
What are they called?
Old Nov 28, 2011 | 10:30 AM
James Woods's Avatar
I believe the one you are talking about is a 74 wedge bulb, it pulls out from the twist lock base.
Old Nov 28, 2011 | 10:46 AM
gottadog's Avatar
Thank you James. No parts store knew what I was talking about or had any in stock. I've ordered them.
Old Nov 28, 2011 | 04:55 PM
gottadog's Avatar
Cancelled my order, I found some and they are wrong. Too big. The stock bulbs in the twist lock bases are very small, I pulled a bulb out and it ressembles an led in size. So thats what I did. I bought 2 leds from radio shack, they are bigger and are the style that mount on the dash and be just about flush. They fit in the hole the twist lock base covers perfectly. Just fed the wires in the hole, and pushed em in to recess em'. Used my meter to determine positve and negative and soldered the leads to the board.These have flexible wire instead of the led's with hard leads. They had a few colors in the 12v leds. I got red for the off light and green for the overdrive light.
Toyota wanted 11 Dollars and change per bulb. No way I was paying that.
http://www.radioshack.com/product/in...ductId=2062568
http://www.radioshack.com/product/in...ductId=2062569
Old Jan 5, 2012 | 03:48 PM
worshipmentor's Avatar
BRILLIANT!!!!!!!
literally!
I have the same problem and after looking at them for a while I pulled the bulb from its base and came to the same conclusion: and LED bulb will work perfect! I will get some and post pics of the replacement process.
Old Jan 22, 2013 | 02:01 PM
mugen2008's Avatar
Originally Posted by worshipmentor
BRILLIANT!!!!!!!
literally!
Would be cool to c those pics. My od light is out and I know od kicks in.
chuckross1957
Jun 28, 2019 10:19 PM
AkitaDog
Sep 1, 2015 08:05 AM
Esibnitsud
Jul 30, 2015 08:21 PM
rushw
Jul 18, 2015 01:46 PM
madxman21
Jul 9, 2015 10:26 AM
