Tranny, O/D light, speed sensor?
Old Dec 8, 2011 | 06:31 AM
ashleyham12's Avatar
I have a 94 4runner, 4x4, automatic, V6. I bought it just a few weeks ago knowing that the speed sensor was out. Now that it has gotten colder, it has a slipping feel to it. When I accelerate, it stalls some in the first couple gears and then takes off. Sometimes the O/D light flashes as well. Could this all be related to the malfunctioning speed sensor?
Old Dec 9, 2011 | 05:10 PM
rustypigeon's Avatar
Yes, a malfunctuoning speed sensor can cause shifting problems. The computer uses Throttle Position and vehicle speed to determine which gear to select. Pull the codes of the computer. If your OD light was flashing you should have a stored code.
Old Dec 9, 2011 | 07:17 PM
chrisorbics's Avatar
Hi
Hi, check your speedo cable that goes into the transfer case. Mine was broke and the od light would flash when I was driving sometimes. It shifted fine though.
BeMiceElf
Oct 10, 2015 09:40 PM
Iceman4193
Jul 15, 2015 04:48 PM
madxman21
Jul 9, 2015 10:26 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
wilbertd
Jul 6, 2015 07:39 AM
