Freezing inside windshield
Old Dec 10, 2011 | 02:43 PM
1994toyota's Avatar
Hello everyone, I have a 94 toyota pickup with the 22re. The problem is that the inside of the windshield will freeze up over night after I get home from work. Is it the heater core that is leaking? I would think you would smell some coolant if it was leaking. When I get out I leave it on warm, feet position, with the blower pulling air from inside the cab. Any suggestions on why the inside is freezing up? Thanks Brad
Old Dec 10, 2011 | 03:59 PM
Marc's Avatar
Stop pulling air from inside the cab. It's full of moisture.
Old Dec 10, 2011 | 04:31 PM
FourwheelinVT's Avatar
X2 you're recirculating moist air everyday instead of pulling in drier outside air.
Old Dec 11, 2011 | 03:45 PM
slacker's Avatar
yep .. move the heater control to "fresh"
Old Dec 11, 2011 | 04:31 PM
nv4runner's Avatar
Turn on the AC to dry the air even better. Most domestics automatically turn on the AC when you turn on the defroster.
Old Dec 11, 2011 | 04:52 PM
BMcEL's Avatar
You could also have a small windshield leak. The windshield on my '80 leaks and it does the same thing. I'd be willing to bet this is the actual problem.
With the heater running, the air inside the cab should be warm enough to prevent icing whether it's on vent or recirculate.
Old Dec 11, 2011 | 07:07 PM
JohnVH's Avatar
before you shut it off put it onto floor also, that helps keep moisture off my windshield most the time.
Old Dec 11, 2011 | 08:07 PM
sidebarr7's Avatar
Yes I would check the winshield for leaks.
Old Dec 11, 2011 | 08:58 PM
bob200587's Avatar
Are you sleeping inside and breathing out moist air that freezes on the inside of the windshield?.....
Old Dec 12, 2011 | 04:57 PM
1994toyota's Avatar
Thanks for all the info it has not been cold the last couple of nights to see what happens after running on fresh air.
Old Dec 12, 2011 | 05:03 PM
BMcEL's Avatar
Running the heater on vent while you're driving probably isn't going to make a difference if it happens when it's parked. Once you open the door to get out, the air in the cab mixes with the outside air anyway.
There has to be some serious moisture in the cab for the windshield to fog/freeze just sitting there. Again, that leads me to believe you have a windshield leak. Just sayin.
Old Dec 12, 2011 | 08:01 PM
peow130's Avatar
I had this problem, i had left my air on outside air, and it had snowed so much that dry snow actually came in through the vent and hit the windshield.
Old Dec 13, 2011 | 06:51 AM
slacker's Avatar
THAT is only 1 reason, why you shoud buy my smoothie
Old Dec 13, 2011 | 07:17 AM
tj884Rdlx's Avatar
i had this happen to me a few weeks ago.
first thing you can check, if you're a kook like me, is taste the condensation on the glass. if it's sweet, it's antifreeze and you've got a bad heater core. (you can also just wipe it with a paper towel and see if its smeary-greasy, or turns the paper color)
if it's not the heater core, it could be the condensation collected by the a/c system is not draining out. (this was my problem)
make sure the drain tube is clear and draining adequately. the a/c on recirc does pull moisture from the cabin air, but it only "moves it" to the collection pan. if the moisture isn't evacuated from the car through the tube it will just keep recondensing on the glass at night.
then lastly, it could be a leak around the windshield somewhere. cold temps makes things shrink. shrunk seals can become leaky ones!
good luck!
kawazx636
Oct 6, 2021 03:03 PM
puddlepirate
Jul 30, 2016 06:29 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
bryan34w
12
Sep 30, 2015 02:50 PM
beltcutter
Sep 30, 2015 06:14 AM
