g52 transmission question regarding axial movement??
Old Sep 30, 2015 | 11:12 PM
hiluxinargentina's Avatar
first of all thank you for looking at my thread. I need some advice regarding what is normal when working inside a g52 maqnual trasnmission.
here is a brief rundown the steps I took to get to my question
I had a leak from the input shaft seal
pulled transfer case
pulled functional g52 transmission, rusted pilot bearing falls out
clutch looked rusty, pulled it, sent it to be rebuilt
huge mess, clutch dust, oil, looks like rear main seal is leaking, pulled the seal
spent 2 weeks cleaning everything down to the nuts and bolts
I see input shaft has some play to it, not alot as seen in some youtube videos but some.
I see the input shaft tip is worn from the bad pilot bearing
I have a mechanic take look
He says he's seen worse pilot bearing wear, wouldn't worry about it, I am not totally convinced, he agrees that the bearing is a little loose (able to wiggle up down left right)
I decide to change the input shaft bearing and input shaft seal and pilot bearing
I opened the transmission, cleaned all that was part of that process and set aside.
a friend said regarding the input shaft tip, he has a buddy in a machine shop that can
fix the tip like new for $300 pesos ~US$18.75 vs a new shaft for $1800 pesos (I live in Argentina)
Please look at my video and tell me if these movements seen are out of the ordinary or if they are normal. I have read that a bad pilot bearing can cause problems further up the line which is why I am inquiring. Total noob here
Do the input shaft roller bearings seem worn?
How about the rear bearing, is that normal?
thank you
chuckross1957
Jun 28, 2019 10:19 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
ripp96
Jul 25, 2015 02:32 PM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
akaphilly
Jul 9, 2015 02:34 PM
