- no coolant temp 3.0L
- Price for rebuilding differential 1992 pickup 2wd
- Macanic needed
- Code 52, engine running terrible
- Oil cooler plug up size
- Wiring Schematic vs. Actual Wire Routes
- 88” Toyota pickup 22r-e
- Recommendations for Toyota Ignition Switch replacement
- 1988 Pickup Lift Recomendations
- Surging/running rough 22re
- Searching For: Weatherstrip Assy, Back Door Glass, Inner Part #: 68170-89114
- 87 4Runner tail light wiring
- Hood Sticking in the Middle
- 4WD not working consistently
- Backspacing...
- 1994 diagnostics box
- 86 22r PCV Problems... ? Please help
- Whats is this line for?
- Rear Door Lock Actuator removal; I need help!
- New Restoration-Quality Upholstery for our 4runners and trucks!
- Shock torque specs
- Help needed
- Cracked block
- Temporary Converson 4WD to 2WD?
- Rostra Cruise Control- 1990 4runner SR5, 5MT.
- Starting issue
- What is this part??
- Need help
- Where can I buy this product?
- Should new pilot bearing slide on input shaft?
- core support bushing
- Neutral Saftey Switch 1988 P/U with Automatic
- Passenger wing window
- 2nd Gen Interior Fuse Block ID
- Head gasket replacement
- rebuild head vs engine swap
- Why leak from shifter
- kanati 35/10.5/15 mud hogs 93 4runner
- Power connection to main 80A fuse unit
- 19888 P/U With Automatic Transmission.
- Funky brakes troubleshooting
- unsuccessful lower intake manifold swap
- 22R to 3RZ swaps and W56/59Trany questions
- 22RE Performance
- 88 vs 89 22RE help
- 1992 Toyota 3.0 Flooding Problem
- Searing Injectors - Whats the Secret?
- 87 4Runner Tailgate Weatherstripping
- Releasing rear seats
- Digital to Mechanical Speedo Info | 1986 Pickup 4.3 Swap
- 1986 Turbo No-Start
- cracked intake manifold
- New Rear Wheel Bearings Toast After <500 Miles
- Coil spacers
- valve cover / timing chain
- 1993 3vze won't idle without disconnecting either PCV or brake booster
- 1988 4 runner coil ignitor
- 3vze EGR delete with AC question
- OEM front mud flaps for a 92 Pickup 4WD DLX?
- '94 DLX stall issue(revised)
- LE v6 ac on 22r?
- BJ spacer + bracket lift travel
- 93 T100 3vz-e idling issues
- Thinking about manual swapping my 4runner. Need some input
- 1993 V6 R150F VF1A T-case mounts???
- Clutch Slave Cylinder Throw Distance??? 93 4runner
- What is a hood 2nd gen 4runner suspension upgrade?
- Finishing My 1988 Toyota Pickup Camper Setup (Living In My Truck)
- headlight bumpers? slides?
- Oil cooler opinions 3vze
- 3.0 bogs down after letting off the gas
- Efi tripping out
- Toyota re22 1996 injectors dont open
- Speedometer shows 2X
- 22RE Rough idle problem fixed
- Can i salvage this 22re timing cover or get a new one?
- Oil pan installation success
- Need part number/name of door catch.
- 3vze Rough Idle When Cold
- Dimple in head surface
- crank but no spark
- No spark
- Solenoid Connectors bad A340E transmission
- After replacing transmission tail shaft bushing truck will not go in gear.
- timing for rough idle
- 3vze piston and valve opinions
- Power Steering Idle Up Question
- Clutch Lines
- 1993 3.0 v6 not passing smog and misfiring(?)
- 1986 2wd pickup exhaust system and brake cables
- Would bigger wheel cylinder bore cause more rear braking?
- proper fastener lubrication
- 1995 3vz-e head gasket thoughts
- 1994 pickup front grill/corner light plastic inserts
- 1990 4 Runner Transmission problems
- valve cover plugs
- 95 4runner 3.0 code 25
- Headliner
- Experienced mechanics in the dmv area
- destroyed bumper mount
- instrument panel disassembly
- 89 truck OBD1 code 21 after running for months with code 11
- Wheel cylinder kit has different spring
- How to replace front speakers 1994 Toyota 4Runner
- Has anyone replace their tail shaft bushing "vibration"?
- 87 4runner Dash Vent selector not working.
- torque specs generally
- water pump stud removal
- degreasing best practices
- My '93 Pickup Dually Manual Swap
- Oil Burning 3VZE
- 88 4Runner 3.0 OD issues
- Sway Away Instructions
- Surging 3.0
- 22-RE Coolant Over Pressurization
- 93 22RE Manual (A/C Problem)
- 89 4runner, auto, 4wd not working
- Headers and exhaust made truck slower, 3.0 toyota
- 22re Injector/ECU issue
- 1992 Power Steering Pump Replace or Rebuild?
- Manual Tranmission Shop Tigard Tualatin Area
- AC Evaporator Clogged
- Help with 3in rear springs please
- 1992 Toyota pickup truck with automatic
- Code 25/Code 26 1990 p/u 22re
- water pump leak
- Bunch of ???'s new to me 22RE
- Misc. Wire underhood
- Debating giving up on the yota, suspension advice
- 1994 Toyota Pickup 4x4 manual 22re CA Smog CEL code 27
- 3VZE Crank no start Issue
- 1994 22re can’t hold idle
- Cluster Swap Trouble
- Rear three-point seatbelts for 4Runner (not the same old post)
- Frames
- 1992 Toyota Pickup 3VZE No Check engine light in On position
- Egr temperature sensor differences by years?
- 1989 pickup 3vze 4x4 manual ecu help
- 1991 Pickup 3VZE - neverending "won't start" saga
- About ignitor
- A/C Issues
- 22re knocking sound under acceleration
- Pedal bracket assembly diagram, reassembly instructions
- U Joints Exploded. Had to drive home. Drive Shaft is damaged.
- '87 Runner Totaled :( Need some replacement advice.
- Can someone measure their shaft for me?
- 94 4Runner door rattle - how to fix?
- Replacing windshield - install how many parts first?
- 1992 odometer and trip meter stopped working
- Overcharging issue
- Occasional rough idle
- 1993 Toyota Pickup 4x4 CV AXLE Replacement
- Hilux 92 4x4, 3vze engine , Tires Selection Advice
- Gauges failing 92 3.0 4runner
- 86 Long Bed 2wd parking brake cables needed
- Inspection?
- Symptom of rings not seating?
- 3VZE oil leak...at the end of my rope
- Why suddenyl 4 codes at once out of nowhere, and why CEL went away right after??
- Need some help with knowing which parts and interchangeable
- Need help finding new carburetor 1986 pickup
- 94 3VZE Crank No Start
- 93 4R 3VZE with zero compression on all 3 passenger cylinders
- ECU Help - 1992 3.0 M/T 4x4 ecu 89661-35710 burned Diode?
- 1994 toyota pickup 2 cylinder Code 71 EGR
- Finding wiring connections
- 91 4runner Interior Fuse Box Circuit Relay removal
- Molten distributor
- Broken Clutch Pedal Bracket 93 4runner
- What's up fellas I'm new here. 3.0 to 4.0 inline 6?
- 3.0 VZE will crank but no start unless pull started
- 1991 pickup, 3.0, Code 12. No spark, no start.
- 2nd gen 4Runner - Both rear passsenger power windows stopped working
- Not starting issue.. binding
- North Seattle mechanic for head gasket replacement
- Front end concerns
- 1st generation 1989 4runner 22re
- 86 Pickup A/C Wiring Help
- 89' 4runner sr5 V6 speedometer broken
- 1993 SR5 4x4 I.D. and Location?
- Rough start/idle after heat soak
- Throttle bogging
- What gear oil are you running in your R150f?
- 88 22RE CEL code 53 - why is there no info???_
- 89 4 runner 3vze ROUGH START AND IDLE
- 1993 SR5 4x4 A/C symptom
- 95 4runner won’t move after egr delete
- 1989 4Runner SR5 - Loud Clicking Passenger Front
- How ro drain A/C compressor oil
- Mechanical Engineer Living In Truck Video 2!!!
- '95 4Runner SR5 V6 issues
- 3vze fuel pump replacement recommendations?
- I need to borrow an SR5 headrest
- Are these r134 valves?
- Wite mistery? Ground?
- dome lite madness
- Intermittent Grinding Noise
- 22re stalled out now won't start
- 1993 Toyota Pickup 2WD Lift and Tires recomendation
- 1988 Toyota pickup 2wd 22r running rich Cali smog computer
- 3vze engine swap question
- Locked up 3vze 92 pickup 3.0
- 86 turbo missing middle coolant hose
- '87 Pickup Bench Seat Options
- AC Repair on 1993 3vze
- trailer lights on 94 pickup
- 88 Toyota pickup - "pull and turn" brake handle
- Warm engine 500 to <500 RPM idle and stalls
- 95 4Runner with 5vz fe New to yota
- Idle issues 94 pickup
- Should I rebuild my W56?
- Bolt-on Hood Struts for '84-'95 Pickups and 4Runners
- 86 Pickup no-cut Zuk mod spring weight and length
- First post, new to me 86 4Runner questions.
- ABS fuse question
- 1991 Toyota Pickup Auto Transmission Cooler
- Can 89-95 AFM sub for 85-89 AFM?
- Making a mod for the 1992 Toyota Pickup, need some specs.
- Power Steering Pump advice 1988 4Runner from a newb
- 1987 4Runner SR5 Build
- 1989 toyota pickup 2.4 4x4 EXHAUST
- 94 SR5 pickup now won't start
- 1992 Pickup Washer Fluid Tank Cap
- Process after rebuilt 22re
- 95 4x4 Grinding Noise, Spindle Bushings?
- 1990 pickup clutch fluid bleeding and pedal-on-floor issue
- 87 4runner 22re 5 speed re-gear question
- Help with desmog
- 3vze ticking
- Just bought new 93 pickup. What should I do first? AC Issue too.
- Anyone know what size and type of rims these came in?
- 87 4runner steering locks while driving
- Load Sensing Proportioning Valve (LSPV) different part numbers
- Diesel 4runner engine troubles
- Help me restore a salvaged 1993 Toyota 22-RE!
- 3vz T4R high idle
- Timing chain and ignition timing
- Front Blinker Wiring Help! on 1986 22RTE pickup
- Source for 138 dark gray metallic paint?
- brake pedal doesnt move after replacement of brake booster
- 94 lost of power
- ebay replacement radiator
- Help with 86 pickup please
- Ignition loss above 2k
- new water pump
- service manual for 94 pickup
- I am an old member -I need help finding what to do.
- 86 22r No start
- Brake feel really changed after hard braking
