94 lost of power
Old Jun 15, 2024 | 04:42 AM
tigerhays's Avatar
94 lost of power
I am in Galveston, Texas, and I'm looking for some advice on my '94 4Runner. It used to be my daily driver, but one day after leaving work, it suddenly lost power as if someone flipped a switch. Now it will only reach 40 mph, and it takes a while to get up to speed. All cylinders are at 160 psi compression except for one, which is at 155 psi. I've installed new plugs, wires, and a distributor. Additionally, there's a new sound that started, similar to a loose belt whining.that started when ever whatever flipped the switcha
Old Jun 15, 2024 | 04:45 AM
tigerhays's Avatar
it also has a new clutch assembly its not slipping or reving up it did show a code 12
and it idles like a sewing machine i do not suspect head gasket
Old Jun 15, 2024 | 05:01 AM
snippits's Avatar
Which engine? Put a timing light on it to make sure the engine did not jump timing.
Old Jun 15, 2024 | 06:23 AM
tigerhays's Avatar
timing
3.0 everything is in time
Old Jun 15, 2024 | 06:49 AM
akwheeler's Avatar
a timing light won't tell you if both cams are in time with the crank. or if the harmonic balancer is coming apart and the timing mark is walking around.
pull the timing covers and line up the marks like shown in the service manual.
Big
Jul 15, 2018 04:28 PM
TinyTruck
Jul 17, 2005 07:22 PM
