3vz T4R high idle
Old Jun 18, 2024 | 06:23 PM
teapot007's Avatar
Question 3vz T4R high idle
Having some issues with my 4runner, it's a 95 4x4 standard trans, 3vze. It's idling at 1500 rpm on start up and when warmed up. Doesn't drop at all. When I turn the AC on it drops to 1250. not sure if they're related, planning on pulling off the throttle body after work and checking the coolant lines in the bottom to start. any tips would be greatly appreciated. Thanks!
Old Jun 19, 2024 | 02:40 PM
MattEnTheHat's Avatar
Does your temp sensor work (the gauge on the instrument cluster)? I'm not sure if that directly controls the idle dropping down, but it's the first thing I'd check.
If you want to just directly adjust the idle it's super easy - there's a flathead screw on the throttle body just before where it mounts to the intake manifold. Clockwise to reduce idle.
Old Jun 19, 2024 | 05:58 PM
teapot007's Avatar
Thanks for the response, my temp gauge works. The idle screw is fully threaded, still a high idle. I replaced fuel filter today and swapped a few hose clamps and the idles sitting at around 1200, but it surges. Bounces about 50-100 rpm repeatedly. Gunna run to town later and grab a TB gasket so I can pull it off I think. Sometimes it sits right where it should, it’s not constant. Kinda confusing me
OutlawMike
May 10, 2022 08:41 PM
Markarino
Feb 18, 2013 03:01 PM
FoCo_4_Low
Jan 26, 2012 06:45 PM
danieltycholaz
Dec 14, 2010 09:54 AM
headgasket
Jan 11, 2008 07:54 PM
