Power Steering Idle Up Question
Old Oct 2, 2024 | 02:17 PM
Omak90truck's Avatar
Hi. I’m working on getting the power steering idle up to work properly. The original valve was shot and leaking power steering fluid. I replaced the valve, and connected the vacuum lines to the plenum, but I didn’t see any effect. I know where to connect the two vacuum lines to the plenum, but I haven’t seen anything specify which line goes to which connection. Does it make a difference, or can either side of the valve on the power steering pump connect to either point on the plenum?
Old Oct 2, 2024 | 02:59 PM
scope103's Avatar
It doesn't matter. The valve on the pump is just on/off, connecting the plenum to additional metered air.
You might consider getting a straight coupling. Hook the two lines together, and by pinching turn the connection on and off to see what happens to your idle.
UsaTuff
May 31, 2010 04:07 AM
Jerbou71
May 16, 2010 04:28 AM
gsxrguru2
Jun 19, 2008 04:19 PM
TMIB
Apr 26, 2007 12:13 PM
Elvota
Feb 3, 2006 07:34 AM
