Vacum lines to power steering pump
Old May 15, 2010 | 11:29 AM
Jerbou71's Avatar
What is the name of the screw in switch that goes into the bottom of the power steering pump. I broke off one of the nipples coming out of it when I was removing the pump. And can I get these at autozone?
Old May 15, 2010 | 02:33 PM
Marc's Avatar
You can just connect the 2 lines together if you want.
They just cause the idle to go up when you use the steering, you probably won't even miss it.
Old May 15, 2010 | 03:36 PM
iamsuperbleeder's Avatar
power steering idle up valve maybe?
also, I'd just cap the lines off before I hooked the lines together; if you just hook them together, you'll get a high idle
Old May 15, 2010 | 04:52 PM
xxxtreme22r's Avatar
man I was just gonna ask the same question, doing a PS swap today from manual and was wondering where to put these lines on a carbed turck, but I guess I am not gonna need them.
Old May 16, 2010 | 04:28 AM
rodgertheshrubber's Avatar
i broke one on mine and super glued it back on. worked very well
smthwsn357
May 1, 2024 07:28 AM
Sep 4, 2015 09:27 AM
jon.r
Jul 11, 2015 03:34 PM
87turboPA
Jul 9, 2015 05:58 AM
skoti89
Jul 8, 2015 12:05 AM
