PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 22Re 4wd ecu into 90s 2wd 22Re
  2. Need Help for Hose Part Number
  3. Oil leak from under intake manifold area.
  4. Code 25 that comes and goes depending if the engine is warm.
  5. R150 (2wD) Can I couple a transfer case to this transmission?
  6. 1990 4Runner 3.0 4WD A/T ECU Pinout
  7. 5vzfe
  8. Crack behind Cam Gear?
  9. A/C Idle-Up diaphragm in FSM?
  10. Thank you
  11. Engine electrical nightmare
  12. 4WD Problems... :(
  13. Torsion bar trouble
  14. Locker help
  15. New truck, check it out! Will need some suggestions :)
  16. Torn CV Boot. What else should I do when I replace it?
  17. Weird air cleaner bracket?
  18. Code 42 on 3.0 4wd
  19. need help 22re pops,backfires during acceleration
  20. Clutch hose
  21. '88 Toyota 4Runner front break calipers OEM brand?
  22. 1988 SR5 special edition?
  23. Hard to find switch
  24. 90 pickup diagnostics issue
  25. QUESTION: Boot Compression for Camper Shell
  26. 22re runs rich pull vacume line runs smoother
  27. 1st & 2nd Gen SR5 Chrome Fender Lip Moldings Interchangeable?
  28. 87 turbo digital dash cluster for sale
  29. '95 3vz-e black smoke (rich) - uplugging maf
  30. Emissions Removal?
  31. Oil leak from under intake manifold area.
  32. First 4WD clutch
  33. Unknown wire on 3vze help please
  34. 1993 3VZ-E Distributor Replaced-Won't Start
  35. 86 pickup interior
  36. 22RE - Finishing up rebuild
  37. Transmission advice
  38. 22re rough idle vacuum issue maybe???
  39. 1987 toy pickup turbo parts??
  40. 1992 Pickup -- Intermittent Speedo
  41. 85 4Runner 22RE Starts then Dies Immediately
  42. 93 Pickup 22RE skipping only at higher speeds.
  43. Windshield Sun Shade for 1989 Pickup?
  44. 94 truck 22R-E No spark
  45. Whats your favorite small mods on 84-88 trucks and 4runners?
  46. Intermittent CEL and Error Code 52 (No Signal from Knock Sensor)
  47. 1994 Toyota Pick Up gear indicator cluster swap
  48. Chrome plating for Plastic Parts?
  49. Custom bikini top from Killer Toy Tops
  50. Ac 1991 toyota 3.0
  51. 86 pickup. Switched to webber manual. Only 1 owner 87k miles OG.
  52. 93 4x4 fuel line from fuel pump issue.
  53. Frame issue
  54. New project getting started body lift question`
  55. Rotella users: T4 or T6?
  56. 22re occaisonal crank no start
  57. 95 4RUNNER 4X4 Conversion
  58. 3.0 91 Pickup hot start issue
  59. Loose Shifter Rattles on 1989 Pickup (Automatic)
  60. 93 pickup no start.
  61. 3.0 91 Pickup hot start issue
  62. 3VZE Check engine light only while driving, reduced power
  63. 90 4runner v6 intermediate no crank start issue
  64. Installed Aux Fuse Box
  65. Warm No-Spark Condition, Possible Sensor Issue
  66. Burned up my rear diff bearing (actually caught on fire)
  67. 3.0 swapped with the 3.4
  68. 95 4RUNNER T-Case Adapter
  69. 1986 Toyota Hilux LN65 2L
  70. Adding sunroof
  71. 1986 Toyota Hilux LN65 2L
  72. Method wheels?
  73. 89 toyota pickup 4x4 v6
  74. Poll: Should I dye my soft top blue?
  75. 1986 Toyota pickup RWD Carburetor
  76. AC manifold parts
  77. Auto Transmission Rebuild
  78. 1993 4runner #3 Cylinder Miss Fire
  79. Need SOLID advice on F150 Spring swaps
  80. Help with 1987 toyota truck standard shortbed-turn signal harness
  81. 1986 Toyota Hilux coolant/anti-freeze
  82. 1994 60/40 seat cushions
  83. Rear window lock
  84. 1991 4runner swap running rich.
  85. Vibration at 40mph
  86. Runnin rough
  87. A340H Transmission Overheating
  88. 3VZE Top End Rebuilding, Distributors, and Setting Timing
  89. Shift Knob Emblem
  90. Best suspension lift
  91. 84-88 steering wheel in a 90?
  92. 2nd gen 4runner advice on body swap.
  93. In frame rebuild
  94. NOS CD changer installation
  95. 88 needs a complete rear window channel replacement
  96. Emissions System for the 22RE
  97. 1986 Toyota Pickeup xtra cab 4x4 - exhaust pipe (upper)?
  98. Looking for fender support and R wheel liners
  99. 1987 Transmission Relay
  100. 1986 22rec 1ton exhaust & different y pipes
  101. Automatic slips and shakes in 1st gear
  102. Huge power loss after CA smog repairs
  103. Air conditioning question, proof of concept
  104. 1990 22re No Power in Cab
  105. 1986 converted auto to manual need help with reverse light..
  106. 22r Electrical Plugs
  107. Hooked up Battery backwards, now truck wont start
  108. 1989 3VZE Rev limiter/sluggish
  109. 1993 22RE 4WD Clutch Confusion
  110. Door handle doesn't open from the inside? Try this one simple trick!
  111. 1995 22re throttle body?
  112. Aisin Hub Clutch Question
  113. Just got my 86 4Runner. Best place for oem/aftermarket under the hood parts?
  114. PS coolers
  115. Timing issue
  116. 4Runner stalling in gear, help!
  117. 86 4runner Driver Door Doesn't Stay Open (Door Check)
  118. A/C compressor???
  119. On the road again...
  120. Anyone with a 95 4Runner and Oak interior?
  121. Idle bouncing after new injectors/EGR delete
  122. Rod bearing specs
  123. Rod bearing specs
  124. Rod bearing specs
  125. 92 Pickup A/C Clutch Contact Disc - Shim ?
  126. 1993 Pickup manual hubs with TRD 'Beadlocks'?
  127. Heavy weight flywheel (30 vs 35lbs)
  128. 1990 lift question
  129. 86 22RE Charging/Alternator issues on motorhome
  130. Two cracked fuel tanks in three months
  131. Big ol’ backfire after “fixing” timing
  132. 92 Pickup Body At Hood Hinge Torn
  133. G54 Transmission 5th gear keeper ring broke
  134. G54 Transmission -5th gear keeper ring broke, 5th gear moving freely
  135. Coolant sensor issue
  136. 1994 4Runner 3.0 Kickdown cable
  137. Long post but Please, please, PLEASE help me with my ball joints. 1987 4runner
  138. Low/rough idle
  139. Hazard Lights switch
  140. Denso alternator rebuild.
  141. ADD delete.....
  142. Kill Switch
  143. 86 Pickup hesitation on acceleration, and gas cutting in and out
  144. I need Fusible Link/ '93 4Runner 3.0 Help!
  145. Speedometer problem
  146. "limp mode" after timing belt replacement
  147. Is this an OEM alternator or aftermarket?
  148. mysterious extra blue connector in stereo wiring
  149. Missing bell housing bolts A340H transmission
  150. (Hi, I'm new here)Meet Charlotte. I bought her from a dude living in her in the woods
  151. Exhaust Manifold
  152. Replacement windshield washer switch push button?
  153. 5-Speed Manual Transmission Build Issue
  154. Wiring harness/ engine harness
  155. ARB bumper
  156. STOLEN Near Sacramento 1988 Toyota Pickup
  157. ‘87 4Runner dies in reverse with brake applied
  158. Interior rehab
  159. Just need clarification on tran and diffs oil.
  160. Knock Sensor; Code 52
  161. Front emergency brake cable adjustment
  162. 1986 4x4 pickup project build
  163. Multifunction Switch
  164. SEM Vinyl Paint
  165. Old gasket removing how?
  166. Toyota diesel engine gaskets and sealer
  167. Buying new truck - opinions on what to look for?
  168. Replacing floor covering.
  169. rear leafs to front in my SAS
  170. AC tensioner help
  171. Rear Trailing Arms Bushings Removal
  172. How the 22R mechanical fuel pump works
  173. How the 22R mechanical fuel pump works
  174. Another 22re misfire!
  175. Replacement Radio
  176. Shopping for 4Runner / Hilux-Surf in Asia
  177. Supra AFM ID Help? (for those who have one)
  178. Motor oil dripping from exhaust manifold on toyota 2l2 diesel engine
  179. Rocker Panel Trim Clips for 87 4runner
  180. Transmission wont shift with T case in gear
  181. Knock Sensor Code
  182. Heater Core replacement help
  183. Power window issue
  184. 22r Stumbles on Deceleration
  185. Rusty Tailgate window regulator spring
  186. Help 22 re
  187. Shocked choice for an old 4runner...
  188. Stumped witha collant leak.
  189. CEL Throwing different codes
  190. Power steering inline filter placement check
  191. Code 41- TPS connection/fit question - 1993 3VZE
  192. Post your 4Runner top MODIFICATIONS
  193. '89 pickup exterior lamps
  194. Engine and gearbox installation on-90 4wd hilux
  195. 1990 pickup 3VZE strange behavior when idling
  196. Hard brake pedal?
  197. Weber 32/36 or 38/38?
  198. Harsh ride
  199. AM1 fusible link blows with alternator connected
  200. 22r
  201. 84 22RE Wont rev up. With video -PLEASE HELP!
  202. 94 pickup 3vze crank, no start
  203. Mystery Power Draw
  204. Stuck shifter bushing, 89 4runner 3vze
  205. Rear Window Switch works down not up, key works both ways
  206. 95 4runner 3vze ticking
  207. Clutch cancel switch
  208. 93 22re pickup radio noise
  209. 86' Toyota Pickup, Clicks no start.
  210. Starting Issue 1992 4Runner 6 Cyl
  211. 1986 22RE ignition system question
  212. Check engine light is out.
  213. Power issues
  214. TrailGear Front Bumper Install Question
  215. New to me '86, won't idle warm.
  216. The rest of the knock sensor plug
  217. can it be salvaged? 87 pickup
  218. Another tailgate window thread (1st Generation)
  219. 1986 22RE feels pretty gutless.
  220. "Snake oils"
  221. Converting from mechanical speedo to electronic - what am I missing here?
  222. 1987 4Runner Tire carrier problems
  223. Couple question- IFS diff related.
  224. 1993 4x4 Center Support Bearing Skid Plate Replacement Bolt Size
  225. 1993 4x4 Center Support Bearing Skid Plate Replacement Bolt Size
  226. Fluctuating RPM in GEAR After Oil Change - Code 14
  227. Brake Pedal goes to floor! Rear ABS?? I've researched for over a month!!
  228. LED Headlights
  229. Project STEEL BEANS Episode 02: Clutch master / slave cylinder / clutch hose swap.
  230. 93 Pickup 22RE starter click even after Relay retro-fit
  231. '89 2wd 22re base Jap made, front park lamps
  232. Anyone know what this trim piece is named?
  233. 1991 Pickup Sunroof Plastic Tab Broken.
  234. Belt broke, fan dangling
  235. 1993 t4r wiring diagram
  236. Altimeter/inclinometer
  237. Rebuild 22RTE
  238. Valve Cover Gasket Replacement & other maint..
  239. oil dipstick tube
  240. 1991 4runner 5vz-fe swap finishing touches
  241. Code 51 when revving
  242. Leaking water pump
  243. What size steel wheels for a 1990 4x4
  244. Aftermarket 3VZE Coil Fry My Igniter?
  245. 2nd Gen Diesel 4runner (Fuel Injection Pump Leak)
  246. g52 rebuild... looking for FSM
  247. Need Bypass sensor block help
  248. Having a bad sputtering issue
  249. eBay radiator and e fan?
  250. Toyota Sightings
