PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 [232] 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 86 Pickup Turbo Parts Needed
  2. cheapo canadian tire "cherry bomb" muffler
  3. CV Axle Assembly - Where to buy?
  4. power windows broke after removing alarm system
  5. Looks like my axle is leaking...
  6. Topless is the only way....
  7. Where to get bodylift for 4runner with auto trans?
  8. Anyone own a Toyota Crawler with an Automatic Tranny?
  9. newb question
  10. very dumb question
  11. 3vze vacuum hose diagram for reference
  12. Toyota service manuals
  13. 4wd vacuum hose location question
  14. Chilton's Manual Leave A Lot to be Desired
  15. sound like headgaskets?
  16. Code 25 95 4Runner
  17. 86 22re turbo with prolems.
  18. Just finished 3VZE V6 head gasket replacement - How it went...
  19. Engine swap from 90 to 92?
  20. Removed steering stops
  21. mechanical speedo problem
  22. Idle problems
  23. Vallve Cover Baffle
  24. New Meats had to share!!!!
  25. just got a 93 runner
  26. 22R-E Temp Sensor threads
  27. rearch springs?
  28. 3vze constant high idle.
  29. Need help on water temp sensor locations
  30. Speedomter cable oiling
  31. Repalcement 1/4 Panels, What'll Work?
  32. Used diff....Will it fit?
  33. Crankshaft sprocket removal
  34. lift qusetion
  35. 2ndgen 4runner clutch probems
  36. any big brake kits? i mean really big!
  37. Nearly new '88 4x4 (warning to dial-up viewers!)
  38. rebuilt engine burning oil
  39. locking hubs doh help
  40. moving to vegas, any maintenance tips?
  41. Driveshaft removal
  42. O2 sensor wiring
  43. Marlin crawler bumper problems, customer service
  44. running 10w-30 v.s 15w-50 motor oil
  45. Brake Problem? Please help, this is serious.
  46. Low Fuel Level/ Check Engine Light
  47. Coolant leak from passenger side rear of engine??
  48. Can you build to be a family hauler AND a mud slinger??
  49. ebrake switch - info/picture needed
  50. what size tires fit on 2nd gen 2wd
  51. Headbolt Dilema
  52. Truck is popping out of 1st and 3rd - tranny time?
  53. 22R owners..He says emissions parts are missing..what do you see
  54. A-arm and tire rub?
  55. Ticking from the engine compartment...
  56. Where's your oil pressure at?
  57. negative side of coil 3.0 efi/tach hook-up
  58. For the BJspacer and bracket lift guys a question.
  59. 94 4runner seats front and rear
  60. Replacing torsion bars
  61. replacing headlights, or add more lights on bumper
  62. here is the deal....
  63. Rear Differential Breather?
  64. Front Bushing Missing
  65. Ngk or denso plugs?
  66. Hard windshield visors & door window smoke vents?
  67. Intake Removal
  68. Unused switch: what to use it for?
  69. Overhaul or just replace timing chain?
  70. 4Runner has trouble holding speed in OD
  71. stupid rear window
  72. 1988 V6 truck, cannot move transfer case shifter???
  73. Contantly getting stuck while wheeling, don't know why.
  74. Theft Protection
  75. 1988 22re swap with a 1988 V6 3.0
  76. What to buy now? Got some spare money to blow.
  77. fried the R&P
  78. Softtop question
  79. 2WD grinding sound from front end.
  80. help needed, low gear/motor beef up
  81. Throttle Body.. hoods up.. need help.
  82. where to buy complete brake rebuild
  83. Need Help
  84. Rear Shock or Springs
  85. Delay wipers
  86. Front wheel drive without rear driveshaft??
  87. 22RE front oil seal size?
  88. Coolant in exhaust, recommend me a shop in SoCal...
  89. 1993 4runner failed SMOG in CA, HELP..!!
  90. lug nuts
  91. OBDII plug is on a 1993 Toyota 4Runner?
  92. This is why I'm done buying parts thru the internet....pic
  93. ideas for covering a lot of land in my 94 yoter (been cross country 5x in 6 months)
  94. Talk about timing...
  95. need help tranny swap
  96. Bad Brakes
  97. O2 sensor debate...what's the skinny?
  98. Factory Vac lines...
  99. Truck wouldn't turn over
  100. think there's any hope??
  101. Where can I buy a CAT cheap?
  102. Does Seafoam restore old gas?
  103. Will I be able to fit 36-38's with...
  104. 3.4 swap problems
  105. *SNAP* Rear Axle sheared off at 45mph and tire went for a ride!
  106. Rear window issues caused by rusted channel guides?
  107. Headlight Issues!
  108. VALVE TAP .. distracting and embarassing
  109. cheapest place to get oem style front and rear bumpers??
  110. New or good used differential abs speed sensor
  111. Suspension help for my 93 4Runner
  112. Got new sliders on my 4Runner!!
  113. Add-A-leafs....how tough
  114. Lost Lug Key, Cant Get Wheels Off.
  115. 22RET Smokes, rebuilt?
  116. How far do I go??? I need reliability and gas Mileage
  117. Shes done!!!
  118. Lower Control Damage
  119. new 2 me 86 runner. school me
  120. sway bar endlinks
  121. b-day coming up, ideas? -_^
  122. Name a peace of glass for me
  123. Wheel Back spacing questions
  124. Swapping '86 22r for '82 22r
  125. 22RE rebuild
  126. warm engine 500rpm
  127. Removing doors without readusting alignment?
  128. after market fender fares
  129. Interesting Oil Test Shows Royal Purple at the Top of the Heap
  130. hard brake line woes
  131. windshield trim removal
  132. '86 with blown head gasket... Need advise
  133. My new 91 4runner
  134. damn squeeling is driving me nuts!
  135. Engine Swap HELP!
  136. CRUISE CONTROL Hook Up
  137. Toyota Wrenches???
  138. Lower Radiator hose
  139. motor swap, vacuum line question
  140. Weatherstriping
  141. Steering Alignment. Costs & What's done?
  142. setting pinion bearing preload
  143. ECT sensor for '86...asking opinions
  144. LCE Headers for 3vze
  145. Lost Brake fluid
  146. 92 4runner V6 Rear ABS light on constantly
  147. 86 4runner wierd sound from rear
  148. Long term Damage?
  149. Shocks
  150. Thanks for the help, '94 gone..'03 now
  151. Power Loss 91 runner
  152. single cab and ext. cab doors??
  153. new intake install
  154. rough idle, rougher when cold, and popping during deceleration
  155. lockright arrived, parts missing!
  156. I think i want to buy this 86 4runner, tell me what you think!
  157. Cruise Control swap?
  158. does the 3vz have TVIS?
  159. i need some help asap
  160. Some may be interested in this
  161. brakes
  162. at a loss on head gasket
  163. Follower Pawl Part number Request
  164. ITS ALIVE!!! Littlerunner lives again
  165. These "codes" of which you speak?
  166. will 88 buckets fit in an 89 pickup
  167. Photo Required - AC Controls etc. on 87 Dash
  168. The Turbo is Alive...with some problems
  169. Toyota recomends 1.7 quarts? 2 quarts not to hole yet?
  170. Toyota Shutter Question
  171. REALLY quick rim q
  172. grant wheel?
  173. Stole my cat!
  174. Hooking up RIDING LIGHTS. Help please
  175. weird problem with my 3VZ
  176. will small amount of air work itself out of clutch system
  177. Overcooling issue - 91 V6 Auto
  178. Rear Shock Relocation
  179. Water Pump 22R - which impeller? 62mm or 69mm
  180. Annoying squeek from front drivers wheel well
  181. Replacement clutch suggestions?
  182. Towing
  183. It is happening again...
  184. Brake q
  185. CV Boots on an 87 IFS
  186. Yota In the Spring Rain(56k Be warned)
  187. Tail lights
  188. A-arm bushing replacement
  189. wiring to ignition
  190. cb radio poor signal, tuning?
  191. 1990 4Runner V6
  192. 1992 4x4 problems...
  193. hooking up a CB radio?
  194. pedal bracket culpit of it all
  195. 22RE - little help identifying some gaskets
  196. opening circuit relay. What and Where is it. toyota efi's
  197. Cab bushing replacement - torque value on nut?
  198. Cryo VS Forging
  199. 3vze MLS head gaskets!!
  200. rust on an 86 4R should i buy it?
  201. Excessive blow by, needs a rebuild, what weight oil will get me home?
  202. 87 truck...Carb to EFI swap..Few ???
  203. 95 4Runner exhaust options
  204. My New Light Bar & Hi-Lift Holder
  205. Paitning chrome grille and bumper black? photoshop help
  206. trying to figure out whats wrong:02 Sensor
  207. Why does it die? intake...
  208. What kind of brake pads are OEM?
  209. wheres it going
  210. Need AC Heater Fan Control Panel
  211. Diving into front brakes/ hub -- insight?
  212. air compressor ideas
  213. best place to get a new flywheel
  214. 93 4Runner speaker replacement questions
  215. IFS Diff Identification question
  216. Wheres the wheeln pictures?!?!
  217. Has this happened to anyone? im somewhat shocked...
  218. 2nd gen mudflaps
  219. axle size?
  220. Valve adjustment Stats
  221. rough country
  222. Rotating #4 cylinder to top position? (22R)
  223. Building a "Strong" IFS as well as Rear End.
  224. 33-12.50's????
  225. 22RE reassembly sequence and can you name this part?
  226. Wiring Harness on a 3VZE motor question
  227. Maybe of interest to someone
  228. Photoshop please?
  229. Glutten for Punishment
  230. what does "dana" mean and does it apply to 2nd gens?
  231. what to do with the 92?
  232. Rusty Auto Hubs
  233. 1990 Speedometer Cable
  234. Name this part
  235. gas tank sending unit
  236. Longblock 3VZE in Phoenix
  237. IFS Diff side oil seals
  238. u bolt flip kit shock questions
  239. Exhaust manifold compatability?
  240. Wheel Backspacing for 88 P/U
  241. Opinions on swapping to a 22RE
  242. Camshafts not aligned?
  243. New Engine for 89 4runner
  244. New owner, steering clunk question
  245. Wanted 4runners and pickups
  246. Buying A 1989
  247. timing belt
  248. 3.0 won?t get to operating temperature
  249. Compatible Rear Coil Springs
  250. 22re to v6 tranny
