hard brake line woes
Old Apr 15, 2007 | 07:11 AM
GLHTurbo's Avatar
picked up a 91 v6 4x4 ext cab and the brake lines are rotted in several places..have a few questions:
i have a 1990 2wd reg cab 22r parts truck, are these lines the same? fittings, tube diameter etc?
anyone ever purchase pre bent lines from the dealer? if so, how much do they go for?
and for those who ever made their own, do you know what size straight tubes i would need to replicate each tube?
thanks in advance!
Old Apr 15, 2007 | 08:17 AM
TNRabbit's Avatar
www.marlincrawler.com
www.wabfab.com
Check out sponsors our for replacement brake lines.
Old Apr 15, 2007 | 09:23 AM
isaac338's Avatar
it'd probably be a hell of a lot cheaper to buy a coil of line, some flare fittings, and a flare fitting tool. and that way you'd have extra line and fittings and the right tool to fix brake lines in the future.
Old Apr 15, 2007 | 10:26 AM
GLHTurbo's Avatar
www.wabfab.com
thanks, they both have the front lines that go from the frame to the caliper hose it appears...how bout the one that goes across the rear axle? or the ones going from the firewall to the rear axle? etc etc, are these available prebent anywhere?
Old Apr 15, 2007 | 10:27 AM
BeaterToyota's Avatar
The hardlines on my '88 rusted through about 5 years ago, right above the gas tank. I replaced both of the front-to-rear lines with OEM pre-bent ones. They were about $30 each from the dealer.
Old Apr 15, 2007 | 01:37 PM
Elvota's Avatar
My local Auto Zone had straight lines with various fittings. Marked Import, Domestic, European, etc.
They all are 3/16" line, but very in flare style and threading. Bring in a soft line from your vehicle and match it up. From memory, it's 10x1mm. The flare is specific to Toyota (maybe Nissan also)
Cost was cheap, but you are limited to the pre-cut lengths they sell. I had to ask the parts guy and he just let me go in the back and look through them all to find the ones I needed. I don't think if you ask them to look for them in the computer database they will show up.
Old Apr 15, 2007 | 02:39 PM
GLHTurbo's Avatar
i think your right on the size elvota...thanks... once this noreaster passes I can get under the truck and see whats up.
Debating if its worth investing into this truck... 91 ext cab v6 4x4 5spd non-ac 165k
Old Apr 15, 2007 | 05:32 PM
pete f's Avatar
"pete f passed away quietly in his sleep on July 13, 2008
I just bought brake lines for my hydralic clutch th3y were 3/16 and paper was printed japanese , Then I bought pre-bent lines from toyota I like that better because they came with chafe gearon tubing
Old Apr 15, 2007 | 05:33 PM
pete f's Avatar
got lines @autozone and tag had japanese written in enlish
Sep 4, 2015 09:27 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
skoti89
Jul 8, 2015 12:05 AM
bryan34w
Jul 6, 2015 05:53 PM
