Wheel Back spacing questions
I am getting ready to order a set of Rock crawler steel rims and I am not sure about the backspacing. I have a 94' 4runner with 31x10.5s I have only about 1.5 inches of lift. Should I go with the 3.75 spacing or the 4.5? Also the bolt pattern is 6x5.5 correct?
Thanks
Scott
Thanks
Scott
Yep i think they were. I am planning on getting the 15x8s just incase I go to 33x12s on the next tire change.
Any problems with 31x10.5 BFG TA/KOs on 15x8s?
Thanks
Scott
Thanks
Scott
Nope.
EDIT: now that I think about it, you might need to adjust backspacing for a wider WHEEL...anyone know for sure?
am i going to be looking at any back spacing issue's or anything with 29 bfg at's on 14inch rims on a stock 94 2wd pu? if need be i can lift it about an inch all around, but not much more. thanks
06-01-2021 01:51 PM
