Vibrating and rattling unengaged...
Old Apr 8, 2007 | 08:00 AM
thegreydog's Avatar
Just got done with a HG. Now only after warmed up, idling in "Neutral" no brake or clutch, the truck has bad pulsing. The timing chain is lined up, the timing is set, the valves have been checked and tightened. Once it is put in gear and I let off the clutch, the vibration stops immediately regardless of speed. I can feel the vibration in the steering wheel as well as the dash. The vibration causes several rattles throughout the truck and is annoying as hell. Before I lift it and put 33s to hit some trails, I am trying to get the bugs worked out.
Thanks and Happy Easter
Old Apr 8, 2007 | 08:43 AM
TNRabbit's Avatar
Bad harmonic balancer?
Old Apr 8, 2007 | 07:00 PM
thegreydog's Avatar
Someone has had to have seen or had this happen before. Very bad vibration in neutral, no clutch, no brake, as soon as gear is engaged the vibration immediately ceases. What changes with the engine when in gear?
ashamsuddin
17
Jul 22, 2024 03:59 AM
zytra
Jan 24, 2019 03:16 PM
Flightguy
Oct 2, 2015 05:34 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
JPV
Sep 28, 2015 03:15 PM
