Front wheel drive without rear driveshaft??
Old Apr 16, 2007 | 12:40 PM
Marc P's Avatar
I have been dealing with a vibration in the rear of my 95 4runner for a while now. Today I took the rear driveshaft off to help diagnose the vibration. Much to my suprise the truck will not move. I engaged the hubs, and have no movement at the front driveshaft. If I unlock the hubs the front driveshaft spins.
I have a V6 with auto trans.....whats the deal??
Old Apr 16, 2007 | 12:42 PM
4Crawler's Avatar
It should work. Has 4WD ever been used? Might want to check the A/T t-case shift linkage to see if it is moving OK:
- http://www.4crawler.com/4x4/ForSale/...tomaticTranny1
And if the truck is ADD-equipped, check out the system:
- http://rubicon.off-road.com/toyota/tech/add/
Old Apr 16, 2007 | 01:52 PM
GSGALLANT's Avatar
Yep, it should work. I drove around like that for a week or so.
Old Apr 16, 2007 | 06:02 PM
Marc P's Avatar
The 4 wheel drive has been working fine...I used it a couple weeks ago. I also manually shifted the linkage to be sure.
The ADD has been gone for a year..since the SAS
Like I said before, when the hubs are unlocked the driveshaft spins at the same speed as the rear flange.
I am just wondering if the tranfercase has some sort of load sensing clutch or limited slip.
Old Apr 16, 2007 | 07:26 PM
Marc P's Avatar
Found this thread....
https://www.yotatech.com/forums/show...ear+driveshaft
looks like I may have a problem with my transfercase.
Old Apr 17, 2007 | 08:23 AM
Marc P's Avatar
I hate broken stuff...now I have more things to fix. Anyone here in SD have a transfercase laying around??
Old Apr 17, 2007 | 08:51 AM
snap-on's Avatar
so your saying that if you unlock the hubs, shift it in gear, and look underneeth you see the front driveshaft turning?
The A340H is a hydrolicly shifted transfer case. Check your fulid levels, theres a seperate check and drain plug on the rear.
your gonna have a hard time finding just the rear transfercase for a A340H as they are kinda one piece. (not the best pic but you get the idea)
Old Apr 17, 2007 | 09:05 AM
Marc P's Avatar
I need to drain and fill the case tomorrow. I want to see the magnet. There is a samall leak at the speedo cable....maybe it is low
Old Apr 17, 2007 | 07:20 PM
Marc P's Avatar
I hope it is because it is low on fluid. Makes sense though...most of the time when I use the 4wd the truck is warmed up, and when I tried it without the rear driveshaft it had been sitting all day.
I need the $5.00 fix as now I get to have some driveshaft expenses.
Old Apr 24, 2007 | 04:38 AM
Marc P's Avatar
I changed the fluid in my T-case and topped off to the proper level, and trans fluid is good. The drain plug magnet was clean. I also checked the linkage. Tried it again today and was able to move slowly in drive/4 hi, but the engine was revving and there was no torque from the front wheels. In reverse or 4lo it would not move.
I then replaced the rear driveshaft and the truck sure acted like it was in 4wd??
I am at a loss.
Old Apr 24, 2007 | 05:36 AM
mt_goat's Avatar
That is strange...and there is no unusual noises?
Old Apr 24, 2007 | 05:42 AM
mt_goat's Avatar
There is a way now to put a gear driven transfer case or 2 behind the A340H, but it requires an adapter and some mods. Look here if you're interested:
http://www.pirate4x4.com/forum/showt...fer+case+mount
Old Apr 25, 2007 | 02:49 PM
Marc P's Avatar
Too much $$$ for the adapter, plus I would need to redo my new driveshafts...
Bump for someone who knows what the deal is...
Old Apr 25, 2007 | 05:25 PM
faubrunner64's Avatar
duals baby!!!!
Old Apr 26, 2007 | 06:05 PM
rajin's Avatar
remove front drive shaft it will help to clear some doubts
Old May 18, 2007 | 01:26 AM
deathrunner's Avatar
Get a gear drive with Marlin's 4.7:1 and that adaptor plate.
The output location shouldn't change much. Maybe 6" back? Unless your driveshaft is bottoming out already, that should work....right?
Old May 18, 2007 | 04:35 AM
Marc P's Avatar
I took the hubs apart, and found a ton of grease in there. I cleaned them all up and now things are working fine. I will test it on Sunday.
Old May 18, 2007 | 10:02 AM
dlbrunner's Avatar
Sounds like a hub problem.
I had the same problem with my cruiser, turned out to be a bad hub, no noise either, it was weird.
maybe a bad front diff, of axle? Broken Birfield?
