2ndgen 4runner clutch probems
Old Apr 17, 2007 | 11:13 PM
91muddog's Avatar
I have a 94 4runner 3.0 5spd.
in order to shift into gear the clutch must be mashed all the way to the floor, even a little bit off and it acts as iff the clutch pedal isnt depressed at all.
i am thinking the slave cylender needs to be bled?
is there anthing else that could be wrong?
the clutch grabs good once it is in gear, my guess is it has recently been replaced.
Old Apr 17, 2007 | 11:29 PM
Ringmaster's Avatar
Get someone to help you bleed the slave cyl.
How many miles on it?
If problems still exist, maybe replacement of both the master and slave cyls. is in order.
Old Apr 17, 2007 | 11:41 PM
91muddog's Avatar
183,611 miles on the truck.
Old Apr 18, 2007 | 04:18 AM
pete f's Avatar
"pete f passed away quietly in his sleep on July 13, 2008
Check your clutch pedal bracket. I just broke mine and had same kind of problems. Check your pedal height if it isn't 6 inches off where the floor angles up . Mine measured 5" when bracket broke. If it's broken your not getting full push on the rod . Check fluid in Master it should be clear .Mine was dirty so I changed both master and slave.Gravity bleeding was the way to go for me.Open bleeder@ slave I used dot 4 fluid and just kept pouring it in master[don't let it run down low and get air @ master] and I did it for an hour , after an hour closed bleeder clutch was 100% ...good luck
Old Apr 19, 2007 | 08:33 PM
91muddog's Avatar
thank you, i still havent had a chance to check it out, hopefully thisweekend i will..
does anyone have any other ideas??
BTW PETE: toyota uses Dextron ATF in thier clutch hydralics.
Old Apr 19, 2007 | 08:43 PM
MudHippy's Avatar
NO SIR, THAT'S INCORRECT. NOT ATF.
Heavy Duty DOT 3 Brake Fluid ONLY
If the pedal height is correct, make sure the pedal freeplay is between 5-15mm.
Old Apr 19, 2007 | 08:49 PM
91muddog's Avatar
i origionally heard about the dextron atf in these forums, i checked my chiltons manual and went to the shop and checked AllData, both said the clutch fuid was dextron I/II/III
Old Apr 19, 2007 | 08:58 PM
SacRunner's Avatar
x2 I've been through 2 pedal brackets in 4 years (at $400, installed, each) and I had the same issue before hand.
On a separate occasion, with the same symptoms, it turned out my pressure plate was shot; some how it wasn't replaced the last time the clutch was replaced.
Old Apr 20, 2007 | 10:01 AM
pete f's Avatar
Mud hippy's right. DOT 3 or DOT4
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
