Cut out the crossover on the 3.0?
Old Apr 20, 2007 | 09:58 AM
jriebe's Avatar
Hi,
Has anyone out there tried to get rid of the exhaust crossover on the 3.0?
I am planning to take out my crossover and just run exhaust on both sides, I am thinking that it will cut down on engine heating and will allow better air flow. My only concern is that it will cause an O2 sensor issue.
Just curious if anyone has come up with a creative solution to this problem.
Thanks,
Jon
Old Apr 20, 2007 | 10:03 AM
elripster's Avatar
I have not done that but would like to do so someday. Just make sure the two pipes come back together before the O2 sensor and you should be fine.
Frank
Old Apr 20, 2007 | 10:06 AM
jriebe's Avatar
I was considering putting the o2 sensor just ahead of the cat about midway back in the exhaust, but I am concerned that the added wire length will add resistance to the circuit and will change the readins the o2 sensor is giving out...but I dunno.
Jon
Old Apr 20, 2007 | 10:24 AM
elripster's Avatar
Well, moving it back could cause slight latency but I have a hard time seeing affect drive-ability. I *think* the sensor is heated so that shouldn't be a problem. As long as all the exhaust passes by it though, it will read accordingly.
Not if you split so only one bank ran by it, that would like cause some problems, you might run too rich which clogs cats and hurts MPG.
Frank
Old Apr 20, 2007 | 10:26 AM
thook's Avatar
Lost of people have. There are tons of threads on it with lots of ideas. Just search the term crossover pipe.
tobylab
Jan 18, 2016 07:06 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
e_richard
Jul 30, 2015 06:50 PM
tobylab
Jul 12, 2015 12:53 PM
crashburnoveride
Jul 10, 2015 06:39 AM
