Lost Brake fluid
Old Apr 13, 2007 | 06:11 PM
Lost Brake fluid
My brake pedal sinking when I hold it long. I kept refill new fluid every 3 days.
I couldnot find any leak in front or rear brake. If Master cylinder's fluid leaked into booster, can the fluid damage the booster ?
Old Apr 13, 2007 | 09:01 PM
longhungsilver's Avatar
Yes it can... Did u check at your break peddle where the rod pushes into the master cylinder?? any weaping around there?
Old Apr 13, 2007 | 09:17 PM
thook's Avatar
Could be just an internal leak in the master cylinder like a damaged seal. Try bleeding it to see if it changes anything. Just don't press in all the way on the piston until it bottoms out. That will damage it, if it's not already.
jasonty
41
Dec 23, 2018 01:00 PM
fountain
Dec 31, 2015 06:08 AM
JHalcyonM
Aug 4, 2015 01:19 PM
Poppie51
Aug 2, 2015 11:29 PM
Poncho0206
Jul 10, 2015 06:21 PM
