- 88' 3vze psp
- 92 4wd pick up manual to auto trans swap.
- Help A/t Transmisson Trouble!!!
- How To: GM 1 wire alternator to a 3 wire in Toyota
- OK to swap 75w-90 for 90w?
- Advice on Detroit True Trac or Lockrite in front diff?
- 1st gen 4runner vintage repair manual on microfiche/microfilm
- Buying rebuilt motor. What to look for
- Am I testing the A/C compressor properley
- Idle/other issues after headgasket replacement
- 94 pickup mud flaps, want pictures
- Rbig's 86 fix up then a question
- Slave cylinder??
- new here need help
- 3.4 swap knock!
- 1993 22RE High Mileage vs 1990 3.Slow low mileage
- parts
- Tensioner Pulley Bearing Replacement
- 22ret, sounds like coolant is bubbling after shut off
- Chinese 4Y motor - anyone every tried?
- installing back seat in an 87 4runner with the rear seat delete
- dakotawho's notebook of links, mods, etc.
- AFM in my fat little fingers
- 4runner replacement panels
- Creamy substance in intake. help
- 86 4runner over heating issues
- Speedo adjustment for 33's
- Engine warm up issues
- 99' seats to 93' truck?
- over heating
- 86 toyota 4runner
- Swapped the plugs, then.. what the??
- 88 4runner knocking motor
- Stiff gas pedal?
- Declared "Unsolvable" cold start screech...?
- Ecu and code problems!!
- 2 wire knock sensor VS one wire knock sensor 3vze
- EFI Fuse Trouble
- Cluster Swap Tachometer wire gauge
- Best Rear Spring Replacement
- '93 timing cover damage
- any way of fixing the fuel pump bracket?
- 1988 4runner 3.0 Downey headers going on. what to look out for?
- For those with LC coils...rubber isolator??
- 1st gen hardtop threads missing
- Rear Shock Mount Location Davez Off Road Rear Shock Relocate Bar
- Help identifying diagnostic connector
- Wheel grinding when cold - what could it be? 93 4Runner
- 1989 22RE turns over, spark but won't start
- My tuck and mud trips
- 22RE pushing coolant out the overflow, NOT A BLOWN HEADGASKET
- Can't Figure Out If Timing Is Off?
- just ordered the Sunwest automotive long block
- Head gasket identification
- trouble codes
- Looking for these 3 vacuum switches...
- 88 pickup 3.0 liter overheat
- 1 intake valve really clean- 3vze
- manifold bolts
- 2wd tran with transfer case
- how to identify a 5:29 diff ratio with it in the truck
- 88 toyota pickup 4x4 insatll tachometer HeLP!!
- 93 pickup Suspension Lift Kit??
- BJ spacers installed (pic)
- 3vze cold start injector advice
- Is it worth it to get a full valve job, machine heads, new cams on a 4runner w 180K?
- Stuck in 4x4, help
- starter relay? grounds?
- vacuum line?
- 1" lift blocks?
- 3VZ Problems
- 22r 5 speed transmission*need to sell
- Clutch issues
- EFI Short
- Grinding noise when turning sharply in 4WD
- 22re difficut to shift into 1st
- 1987 Toyota Pickup Project
- Brake Issues please help
- Possible HG problem looking for confirmation
- Cheapest parts .com?
- 3vze... died.
- Looking for 1991 toyota truck instrument cluster indicator light
- Power windows to Manual windows
- 89 toyota...good deal or basket case
- Electrical gremlin?
- Help with parts list!!!!
- Broken clutch troubleshooting help.
- 90 4runner timing belt jumps
- what plug is this
- 87 2wd fender flares
- persistent code 2 checked AFM and wiring - ECU fault?
- 1990 4runner SAS
- battery gauge dips hard when using any accessories
- 1987 22RET driving me insane
- Problems with 87 4x4
- Crackling/Crunching/Clicking/Whirring type noise at cold start/startup?
- Lunch box or Selectable Locker
- Gas mileage talk
- 4th gear (o/d) rpms higher than normal???
- 87 22re with a subtle whine
- 93-98 Automatic 2wd Transmission
- I need to try to break down to my head in one piece hopefuly
- bad water pump housing HELP
- 89 pick-up clutch master cylinder
- Smoking from under hood
- 1989 22RE Engine Compartment Fuse Diagram
- 89 22re pickup problems
- look--> Gearing Question
- project nightmare - 83-95 mutt
- Ok guys I have quite a few problems with my '92 Toyota 4×4 pickup
- What torsion bars will fit?
- Nice Cupholders for first gens!
- 95 4runner 3.0 High Idle bad MPG
- Charge/Brake Light On, Alternator OK
- Radiator low, reservoir above ful
- Fixing first Gen. 4runner seats
- 95 pickup starting issue
- 22RE: Bad mileage after headgasket/timing chain job
- front pinion bearing 30306
- Wheel/tire combo and bj spacers
- 22r carb error code 31 pls help
- Anyone having trouble starting their 22r/e/rte/2L-T engines (pics)...?
- 4Runner starts and dies after 2 seconds.
- Symptoms of a bad starter
- BJ spaced IFS lift RELIABILITY
- 22re sluggish in low RPM's
- 87 4runner rear cv driveshaft with duals
- bodywork --- need ideas
- 86 Pickup Rear End Issues
- Fender swap
- i.a.t sensor location or wire color
- Starting issue
- weird electrical problem
- quick vacuum line question
- Smell Of antifreeze inside truck
- Just Lost 4MPG in a tune up
- JDM engine swap, transfer case different???
- V6 Misfire please HELP.
- 4Runner won't turn over
- wanted
- ecu replacement question
- Input shaft bearing
- 94 Pickup... Bumper Ideas?
- New Cupholder Idea
- Switched power
- Mounting 1992 front bumper
- 3VZ-E Poor Idle but no Indicator
- Knock or Tick? WHY?
- Swapping wing windows to a truck without them
- 94 4runner 3.0 v6 bad knocking
- what wheel spacers?
- Where does this plug go? 1993 22re
- 91 4runner no start/something spinning?
- Fresh 22re rebuild, oil POURING from the headgasket
- Aftermarket rear bumper for 91 4runner with stock tire carrier?
- Piston Slap 1990 4runner 3vze Rebuilder Recomendations
- !!!HELP!!! truck stopped running (broke down)
- 93 pickup suspension lift suggestions
- New guy with a troublesome 3VZE
- 2nd Gen Toyota 4Runner Shifting Issues
- Wrist pin?
- Rough idle/lack of power 86 pickup
- Newbie with a problem
- 3VZ-E Connecting Rod--Install Piston?
- Spray Paint inside cab?
- No more emissions - mods?
- Roar in right front end
- Wont pass emissions
- New to 4Runner, help
- Magnetic block heater
- Gear shifting/Engine speed????
- Building a sleeping platform...
- Traction control malfunction?
- Trans-generational Cluster Swap questions
- 93 pickup bumper
- Panhard bracket didn't change axle?
- Can a 1JZGTE Supra Chaser 30-40LE transmission fit on a 94 t100 automatic 2wd truck?
- What brand head gasket should i get
- bypassing fuel pump???
- V6 or 4cyl?
- 88 toyota 4runner starting issues...
- Head lights stopped working...88 toyo 4runner
- 1986 Toyota Coachman
- 22re misfire/stumble changed
- Oh oh, Houston we have a problem (Head Gasket??)
- Weird Electrical Problem, Need Help Quick
- 94 P/U Clutch Engagement
- Stock height replacement leaf springs
- 94 with NO LIGHTS AT ALL!
- help with idle/stalling problem
- 95 runner rear defroster/back up light bypass?
- Selling 1993 Toyota 4runner v6 manual
- Wiring nightmare. Anyone have any diagrams?
- 3VZE Timing marks not lined up
- 3VZE Throttle Body's
- Rebuild Electrical Problem
- windows rough going up and down/ tailgate latch sticky
- Quick 'Chirp!' at cold start, then not again until next cold start...
- Does anyone else miss their leaky slave cylinder?
- ignition problems on 89 4runner
- Fuel gauge ?
- 89' pickup coolant/idle issues...
- 86 X-Cab door pillar trim piece
- 93 sr5 rear hatch not opening...pic included
- How much does a 2.7 or 3.4 swap cost?
- Engine Rebuilder Inland Empire
- 22r exhaust pipe diameter. What size is ideal
- Brakes sticking really bad.........
- 89 3.0 waterpump checklist
- 22RE Rough Idle
- 1988 Overheating
- Shifty Shifter
- 22re bite the bullet
- Gear change 5.29
- Check Engine Light Code
- FJ80 E-Lockers Front and Rear
- Any luck with a full HID conversion?
- Battery AFM swap
- turn signal comes on when brakes are pressed
- Waterfall in my dash
- Timing Chain Bright Link and Spare Part Question
- Stuck in the block? Need help fast.
- 22-RE Wood??
- 22-RE Wood?
- 22re
- Door locks
- front bumper
- 86 5 speed grind in 2nd
- Spedometer, cruise control not working
- i need a part # or other solution
- ifs diff compatibility
- Just installed some MOOG coils in my 95 (Before and After pics)
- 93 Pickup 22re Exhaust (help)
- EGR temp sensor
- Dealership wants $150 for new speedo cable
- PICTURES INCLUDED/ Just bought 1986 1ton pickup
- rotted fuel tank pickups.
- 88 toyota 4runner not starting or no idle in cold start
- Driving w/ my EFI relay bypassed
- buying a rebuilt engine
- Wood bed photos/design
- OOPS! I did it agaaaiiiin, got lost in th...
- disgruntled employee slashed stts
- lower rad hose temp during winter
- 87 4Y won't start - Carbi pops and smokes
- Cooling system not building pressure
- front seatbelts swappable from driver's side to passenger and ...
- Auto hubs, cold weather, odd noise and clunks
