4Runner starts and dies after 2 seconds.
Old Jan 11, 2013 | 01:30 PM
Burkenixon's Avatar
So My 1995 4runner was starting up and dying in 2 seconds and now its just turning over trying to start. i'm thinking my fuel pump went out? does that sound like that could be the problem im at a loss at what it could be besides that. Also if anyone can give me a pretty good breifing on how to replace one that would be great. thanks guys
Old Jan 11, 2013 | 01:34 PM
Burkenixon's Avatar
also when it would start up for a couple seconds if i gave it gas it would die much quicker.
Old Jan 11, 2013 | 03:22 PM
Chooch's Avatar
Give the gas tank near the fuel pump a couple taps with a hammer and see if it works. Also check to make sure all your air and vacuum lines are hooked up and connected good. What engine do you have? Both engines create such a high vacuum, one tiny air line not connected will cause the engine not to start.
Old Jan 11, 2013 | 03:26 PM
Burkenixon's Avatar
its the 22re 4 cylinder. and thanks! ill give that stuff a try.
Old Jan 11, 2013 | 04:31 PM
scope103's Avatar
"Start up and die in 2 seconds" sounds like a problem in the COR/VFM circuit. It's easy to check; jumper FP to B+ in the diagnostic connector. If it runs then, you've found the problem.
(Don't drive with the jumper in ! The COR shuts off the fuel pump when the engine stops sucking air. If you get in a crash that breaks a fuel line, do you want the fuel pump to keep running? I didn't think so.)
Old Jan 11, 2013 | 05:33 PM
toyota4x4907's Avatar
Check the wiring and make sure the plug is snuggly attached to the Air Flow Meter.
sonic concepts
Aug 16, 2025 03:13 PM
91toybeater
Dec 27, 2015 07:46 PM
puffin04
Jul 10, 2015 09:17 PM
MadMax48
Jul 3, 2015 08:26 AM
slider417
Jun 22, 2015 10:18 AM
