BJ spacers installed (pic)
Old Jan 15, 2013 | 02:11 PM
oldblue's Avatar
Tell me what you think. I'm stoked about the outcome, i got the perfect stance i was looking for. Didn't even touch the torsion bars. Still have to install the diff drop, but i'll do that at work and not on my back. Took the sway bar off instead of lowering it. I just need some longer shocks. What would ya'll recomend for shocks? Wish i had money for new wheels... I also added a picture of when it was stock, small tires and fresh wax job!
Attached Thumbnails BJ spacers installed (pic)-lifted3.jpg   BJ spacers installed (pic)-clean.jpg
Old Jan 15, 2013 | 05:36 PM
toyota4x4907's Avatar
Beautiful! Anymore pictures? She looks very clean!
Old Jan 15, 2013 | 07:51 PM
racersg's Avatar
That looks nice! Great job.
Old Jan 15, 2013 | 08:14 PM
Toyota~Boy's Avatar
I used 1992 ford bronco front shocks and 87 Chevrolet truck rear shocks. The bronco shocks are a direct bolt on and are perfect for the BJ spacers. The Chevrolet shocks are slightly different. You must make your own bushing for the lower mount of the shocks. By the way I'm using Monroe shocks from my local NAPA. Costed around 50-70 bucks for all four and seems perfect.
Old Jan 16, 2013 | 02:32 AM
oldblue's Avatar
Interesting, i like the price!! Did you have to make bushings for the front and rear, or just rear? and what did you use to make them?? I might have to try this, much better than $200 plus on rancho's
Old Jan 16, 2013 | 02:33 AM
oldblue's Avatar
It's been crappy and rainy here, so no other pics right now. I'll get some more good ones up soon. There is talk of snow in georgia tomorrow!!!!!! Maybe i'll get some 1" Georgia blizzard pictures!!
Old Jan 16, 2013 | 07:49 AM
Toyota~Boy's Avatar
Only the rear will need modified. I just used a knife and cut the original bushing until it was large enough to fit over my bolt. If you look at the specs of those shocks they are perfect for the BJ spacer lift. They have just the right amount of travel.
Old Jan 16, 2013 | 08:03 AM
Yamiryder's Avatar
I'm interested in this. I just put on BJ spacers and need new front shocks for sure. Do the bronco shocks come with new hardware that works? I'm in PA and rust is a real issue. Also, are these for a full size bronco or bronco II??
Old Jan 16, 2013 | 08:13 AM
Toyota~Boy's Avatar
I'm in WV man rust is same here. The shocks are for full size bronco. And yes mine came with all hardware
Old Jan 16, 2013 | 12:30 PM
Yamiryder's Avatar
Sweet. I might try that. Better than extended shocks or spacers.
Old Jan 16, 2013 | 03:24 PM
kawasakilewis's Avatar
i work at napa i looked at the specs for the bronco shocks and they are almost 3 inches longer when they are fully compressed. you do not need 1.5 extended shocks for 1.5 spacers becase the distance is not equivilant because the spacers are out at the end of the control arm and the shock isnt. not saying it would not work but i would be careful especially if you have low-pro bumpstops or something because you may overcompress or turn your shock into a pop can.
Old Jan 16, 2013 | 04:35 PM
can you post up some shocks and part #s for him ?
Old Jan 16, 2013 | 07:28 PM
truckmike26's Avatar
Clean truck.
Old Jan 17, 2013 | 04:56 AM
What do you need
Old Jan 17, 2013 | 05:54 AM
Front shocks for bj lift
Old Jan 17, 2013 | 06:27 AM
i tried looking them up before and theres like nothng that would be good. i would honestly just usevthe spacers because its not that big of a difference
Old Jan 17, 2013 | 06:28 AM
Toyota~Boy's Avatar
I have had no issues. My shocks have been on for over a year and yet to this day I have had absolutely no problems. So that's just my opinion. It's your guys truck. You make your own decisions based off the info you gather here lol.
Old Jan 17, 2013 | 06:31 AM
Swimmerboy2112's Avatar
You can get the longer shocks from some of the vendors on here. I used ProComp ES9000's when I did my BJ spacer and add a leaf lift.
Old Jan 17, 2013 | 08:45 AM
22R4EVR's Avatar
I would recommend the bilstein 5100 http://www.shockwarehouse.com
work great for jumping around and give you that extra travel when you need it and make sure you relax your torsion bar to get that smoother ride feel now that you have the height.
Sep 4, 2015 09:27 AM
Scotto6591
Sep 1, 2015 03:24 PM
terminator
Jul 27, 2015 07:13 PM
Yotoder865
Jul 9, 2015 07:51 PM
bryan34w
Jul 6, 2015 05:53 PM
