Door locks
Old Jan 4, 2013 | 09:57 AM
IHI6FAN's Avatar
Door locks
I have searched but haven't had any luck finding info on my question. So I will see if one of y'all can help. I have a 86 4runner an the doors will not lock if you lock them an shut the door now if I lock them an hold the door handle up they will lock but my ignition key will not unlock them
Old Jan 4, 2013 | 10:56 AM
scope103's Avatar
Power locks? The doors "unlock themselves" if you close them with the key in the ignition; you could have a bad key-detection switch.
Does you ignition key turn in the lock? If it won't turn, the key (or the lock) is bad. Just because the key works in the ignition doesn't mean it's a good copy (the ignition lock could be really loose.)
Old Jan 4, 2013 | 12:56 PM
yotasonaplane's Avatar
Does your runner have power locks? If not I think thats how they're supposed to work, maybe a way to help from accidently locking your keys in the car. My 85 is the same way. And I've also had seperate keys for locks and ignitions before but I'm not sure if that was factory or not.
Old Jan 4, 2013 | 02:20 PM
IHI6FAN's Avatar
Manual locks an I was curious if it took a separate key for ignition an doors. I only have a ignition key.
Old Jan 4, 2013 | 02:38 PM
scope103's Avatar
Mine is a '94, but back in the day many cars (and trucks) with manual locks required you to hold the handle "up" (open) when closing to keep them locked. I'm guessing you don't have the original owner's manual, so perhaps someone with your vintage truck can educate me.
I suspect that it came from the factory with a single key, but some time in its 27-year life the ignition lock might have been replaced. Most locksmiths can rekey the door locks to match the ignition, but removing the door locks is non-trivial. This might give you some insight: https://www.yotatech.com/forums/f116...t-work-254772/
Old Jan 4, 2013 | 04:18 PM
slow-mo's Avatar
That's normal.
In it's original condition, the ignition and the doors locks are keyed to the same key.
As was mentioned, either someone has replaced the ignition lock, therefore the keys will not unlock the door lock, or there maybe damaged done to the door lock cylinder itself.
westonian18
May 1, 2020 06:38 AM
mussy01
Dec 13, 2016 08:20 PM
r3dfish
54
May 16, 2016 10:31 PM
shisha1999
Sep 20, 2015 11:44 AM
moonpie
Jul 31, 2015 11:58 PM
