22RE Rough Idle
Old Jan 5, 2013 | 11:17 AM
smackay's Avatar
22RE Rough Idle
My 1992 4Runner just started idling rough, especially at cold start. Plugs, cap and rotor were replaced about 3,000 miles ago; valves were adjusted at the same time. The engine has 265,000 miles on it, but runs well above 2,000 RPM. Where should I start with troubleshooting? Any suggestions will be much appreciated.
Old Jan 7, 2013 | 10:59 AM
mYnAmEiSmUd's Avatar
It could be a number of things...
look for vaccum leaks
short diag port and look for codes (http://www.4crawler.com/4x4/CheapTri...es/index.shtml)
Throttle Positioning Sensor, TPS, In need of adjustment (http://www.4crawler.com/4x4/CheapTri...#TPSAdjustment)
Consult Factory Service Manual (http://personal.utulsa.edu/~nathan-buchanan/93fsm/)
Good luck. Hopefully other more experienced members will chime in.
Old Jan 7, 2013 | 03:48 PM
Terrys87's Avatar
Check your fuel filter, and I would do the Seafoam treatment. Clean out the mess caused by the EGR. Make sure all vacuum lines are clear and flowing, especially off of the Plenum.
Old Jan 8, 2013 | 07:46 PM
smackay's Avatar
22RE Rough Idle
Thanks for the input, folks. I will take these suggestions up this weekend.
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
montanatruck
Feb 26, 2017 07:07 AM
Sep 4, 2015 09:27 AM
v_man
Jul 23, 2015 04:01 PM
