90 4runner timing belt jumps
Old Jan 13, 2013 | 08:13 PM
Dspohr's Avatar
I just bought a 1990 3.0L automatic 4 runner not running, I was told it needed a timing belt. When I got it home I took the timing covers off and when the marks on the cams were lined up the crank was out about 8 teeth so I lined them up and it started up, the next day I drove it to work and it ran fine, went out after work and when I went to start it it made a wired clicking noise so I tried cranking it again and the belt had jumped, thinking the belt might of been stretched I replaced the belt,water pump, tensioner, and idler got it back together set the timing and it ran great for a few days then the next day went to start it and it made the same clicking sound then the belt jumped again. I took the top cover off the belt is still tight but it's out on the crank again. Any ideas on what could cause the belt to keep jumping??
voiddweller
19
May 2, 2016 09:10 PM
vasinvictor
Jan 20, 2016 12:39 PM
layifioren
10
Jul 6, 2015 02:26 PM
crazypaint
Jun 23, 2015 03:27 AM
infinityisfive
Jun 16, 2015 06:51 PM
