- Crossover pipe issues
- 2jz bl?
- Seal Dust, 90313-93002
- Seats..Again
- Worried about my locking hubs (after conversion) and rotor/hub discussion
- ECU repair
- Total Chaos Mid Travel coilover question
- Help with possible ignition problem!
- Limp mode, 93 3VZE
- Rod knock?
- calibration on the factory tacho (92 v6)
- 2x electrickery issues. 92 v6 4runner
- 3" body lift and why I should not do it.
- 3vze 95 acceleration/vacuum leak?
- Gearing questions for 3.4 1990 4R AT SR5
- New (used) 94 pickup 4x4 SR5
- 1992 4x4 Steering column upgrade
- Help! Carb re-build fail
- YES Another "'86 4x4 22re running Very hot" thread
- 3vz-e AFM mod
- Conversion of ADD to Manual system
- Problem under a load
- 4 cylinder brake rebuild thread
- Towing 87' Xtra Cab
- Testing rear window power switch (up/down)
- Not another no start post!
- Rocker Disintegrated - now what?
- 88 22re Hard/Stall Start
- replacing the factory o2 sensor with aftermarket
- Door panels needed
- Help! Toy 8 inch zip locker 5.29 problems
- Which speedo and park brake cables with body lift?
- OEM front wheel bearings or after market?
- 1995 4runner 3.0 wont start after replacing knock sensor
- Mystery problem!
- Torque specs for 4wd ball joint castle nuts
- Another brake upgrade/repair question
- 22re double check
- PLS HELP Clutch Start Cancel Button
- 86' Hilux Issues - help!
- 1990 4 runner elec fan turns on and drains battery
- 3.0 dies when pressing gas on cold start
- 1993 3.0 2WD Front Brake Upgrade Question
- Steering column upper/lower covers
- Why does my truck smell like gas??
- W56 Transmission Assembly Help!
- T100 or Pickup?
- CV Joints / Bearings Ball joints??
- 1990 Door Locks "sticky"
- thoughts on a diy louver type bonnet scoop for 4runner
- HELP! Transmission trouble 91 4-Runner
- How to repair
- Valve Clearance
- What is this??
- 22rte bad turbo
- Engine Removal
- Modified 3vze, CA smog failure with solution
- '92 4rnr A/T tranny jerking into gear
- Please help clutch problems
- Overheating issues with my 94 3.0L 4runner
- 87 4x4 pickup
- locking hubs, is there a differance?
- 87 IFS BJ Spacer lift - rough ride
- 94 4runner won't turn over
- Can anyone identify these gaskets?
- 93 22re 2wd - several issues.
- 3vze shakey idle, exhaust smell, exhaust gurgle
- Electrical concern on my 94 pickup 22RE
- knock sensor - location quick question
- Replaced CV shaft. Lock ring and washer will not fit.
- 4wd part broke
- 2nd Gen 4runner cheap lift
- 1994 toyota sr5 pickup
- 92 3vze stalls easily with clutch
- Broken rear differential cover bolt
- 95 4Runner sputtering and low idle
- Missing bolts on valve cover?
- 94 22re starts and dies.
- Help identify a part and stop oil leak
- SUPER still clutch
- Shift Knob and Shaft Just Spin??
- My gen2 DIY snorkel (lotsa pics)
- check engine light on
- Frame swap compatibility
- 4 runner 88 22re engine noise help!
- very rough idle, clicking or knocking sound
- Hard to put into gear sometimes, read and tried everything on the forum
- EFI EFI fuse 15 Amp continues to break on my 91 22re.
- 94 Pickup Rocker Panel / Sill replacement time.
- 1988 4Runner makes high pitched squeal going up hill
- Trans, diff, and transfer case specs
- Confusion with my yota!
- 88 4 runner fuel tank replacement
- timing with modded engine
- Cooling fan broke while driving
- Jasper 22re Reviews
- Motor noise?
- Tire down size..
- power loss under load
- Random Idle 3vze
- 91 4Runner transmission fluid change
- Oil problems on 86 4runner
- Code 14 3vze
- Driver side front motor noise under valve
- Fuel pump turns on when jumped.
- 2nd gear mysterious grinding - fixed??
- Gear driven Tcase for V6 Pickup?
- Is this runner fixable?
- Please Help! 3vze Coolant Waterfall. Yes, I've Searched.
- fuel pressure regulator leaking
- Complying with Cali Emissions
- 1992 4runner, hard to start when cold but not when warm
- Attempting the ISR mod... need help!
- U bolt brackets
- Proper name for an '88 4WD part
- Please help with 22re mystery
- 94 4wd pickup brake line coupler leak
- Thermostat housing coolant leak
- 3vze distributor seals leaking
- Another hot start problem 😩
- '92 4Runner SR-5 with 21mm REAR Stabilizer Bar??
- W56 main shaft center bearing
- Pedal goes to floor, at a loss
- CO Emissions troubles
- 92 Pickup Bad Idle and Popping exhaust
- Timing chain kit
- Prerunner rear axle swap questions
- EGR temp sensor
- Steering Knuckle and Hub Assembly
- 95 4runner Cold Start Mystery
- 1995 4runner Gear Drive Tcase Swap
- Rear lockers - potential issue for 3.0L v6 3vze
- straight axle lockouts on IFS 4runner
- 3.0 ground
- 86 toyota no dash lights and wont start
- axle bent?
- Loose CV axles what to do. 1987 4x4 pickup
- Park brake cables
- 1988 4runner 3.0 liter, no power to fuel pump
- 89 toyota truck, any input?
- looking for a few parts.
- Help-22re randomly wont start when hot or stumbles and dies
- 1988 4runner Clutch replacement
- 86 4runner won't run right, please help!
- Getting Frustrated - 22re 4Runner
- Removing the power steering pulley
- PCV valve and O2 sensor
- 22r knock on deceleration
- ARB bumper
- Torsion bar adjustment
- A/C Idle up VSV
- 3VZE Stored Codes and MPG
- Towing advice
- 22re studder problem not stumble
- 3.0 rear main seal housing
- New truck clutch change tips an advice
- Clutch start cancel button
- sealant on top bolt of oil pump 22RE
- 22r emissions
- 1988 4runner build . Carb setup .
- alternator battery drain help
- Exhaust recs for a 2nd gen?
- Stumbles and dies
- 92 Pickup Battery Won't Charge
- Motor noise
- Need help finding part.
- 1987 Rear Bumper End Caps
- power steering pump tight after rebuild
- 1991 Toyota pickup
- Wheel bearings/drive shaft
- 94 Pickup seat swap
- a340f trans
- To rebuild or not to rebuild.
- 1989 Toyota 4Runner Fuel Sending Unit
- 89 Pickup 3.0 Mechanic
- no oil in filter
- What locker is in my 7.5 IFS???
- 1988 4runner
- Stolen 95 Runner
- Surging idle
- Need new seats
- Unknown shudder 94 runner 3vze
- Thrust washer for wheel bearings.
- Head to Timing cover hole off. What can I do?
- 92 22re won't start!
- 22re leaking coolant from back of timing cover.
- Timing keeps jumping
- When to do? 1993 3.0 Valve Adjustment
- Snapped cv shaft end
- 4cylinder to v6 differential question
- 1988 4runner
- tps switchup?
- AFtermarket mini truck fuel gauage
- code 42 speed sensor
- Nerf Bars for 1992 4Runner??
- 1990 4runner roof rack question
- Learning the 22RE engine
- 22RE misfire; electrical issue?
- 22RE Odd miss at speed
- 89 22re dies when temp rises?? Please help
- How to reinstall 4wd shifter
- 22RE TPS Questions
- heater pipe block
- 3vze cold idle/drive
- 22RE Idle Surge
- fuel filter to fuel rail line replacement
- 87 4runner Chevy 63s Question
- Going to scrap an 85 Celica Supra- What parts can I use on my 86 1st gen 4runner?
- 1992 pickup, weird acceleration/power
- New 4runner project
- Stripped AT pan drain plug hole...options?
- fuel pump runs, engine is off, help!
- top dead center
- No compression in 3 cylinders 22r
- Gear Ratio
- Spark plug wire unplugged/Head gasket job
- Distributor won't seat all the way
- 1995 Toyota T100 Speed sensor /Shifting problem
- 22re Poor Gas Mileage
- I think I broke something wheeling...
- Will a v6 radiator on 22re cause worse MPG?
- 1994 flatbed cargo ideas?
- 1989 Toyota Pickup 22RE, battery
- thought i had a blown hg, but what is it?
- Gearing/Rpm question
- Back in a 4Runner ! CV boot keeps tearing -whats up
- introduction and questions!
- Dual USB in 94 pickup
- V6 carrier swap
- '90 4 runner 22r noxious fumes in cabin
- power doors keep unlocking??
- Motor swap
- New 94 4runner
- Timing chain slack ...is this normal ?
- Overheating Issue
- Crack dash/ will this cover fit 0.o
- LSPV boot - can I leave off?
- 1993 4Runner SR5 V6 project.
- 22re cylinder head replacement/timing chain adjuster help
- 1st Toyota, 1st Post, 1st question
- 1990 Toyota 4WD Pickup With Blown Head Gasket
- 3vze power steering idle up valve delete
- Noise coming from Drive Train/Tranny area
- t100/tundra rear end weaker than v6?
- How to remove broken brass threads?
- lower radiator hose
- Thanks!! Yotatech rocks
- Help me find a Coolant Leak.
- Positive front camber help!
