Why does my truck smell like gas??
Old May 4, 2016 | 12:54 PM
dumpster84's Avatar
Exclamation Why does my truck smell like gas??
Like the title says, I can't figure this out. When I park my truck in the garage, it fills the garage with gasoline smell, very noticebale, but I can't find any leaks.
What the hell am I missing here? Kind of at a loss. I thought I might have been filling it up too high or something, but that's not it. Also thought I was flooding the carb, but that's not it either.
The smell is not very apparent in the engine compartment which seems to rule out the carburetor flooding or lines leaking.
Does anyone have any insight on this dilemma?
Specs:
84 single cab 4x4 sr5, freshhhh rebuild of 85+ 22r, desmogged using LCE components and Kawazx636 super awesome write up, rest is basically stock.
**Also just realized this is in the 86-95 section, sorry about that, but I'm sure it can still be relevant
Old May 4, 2016 | 01:01 PM
highonpottery's Avatar
Every carbed vehicle I've ever owned or driven smelled like gas. How long have you owned it? Have you checked the vent going to the charcoal canister?
Old May 4, 2016 | 01:17 PM
dumpster84's Avatar
I agree with you Highonpottery, all of my carbed vehicles/motorcycles seem to have the gas smell, but this is definitely more than that. Its a bit overwhelming in the garage and has me concerned.
I've had this old thing for a while, maybe 6 or 7 years. I'll check the charcoal canister again, but it doesn't seem to be the problem, if that was the case it would be more concentrated in the engine compartment, right? If I had to pick an area where it seems strongest, I think it might be back around the filler cap "area" but it's hard to tell.
Old May 4, 2016 | 01:29 PM
osv's Avatar
osv
i'd sure get under it with a flashlight and check the condition of all of the hoses and hard line, follow the entire fuel line path.
Old May 4, 2016 | 03:43 PM
angrydogtattoo's Avatar
check around the tank and the area where the fuel pump connects, recently we had a car do the same thing, couldn't see a drop anywhere but could smell it, fuel lines on top of the tank were bad, it would leak but by the time it ran down the tank it had evaporated, so no noticeable leak, my guess is it is tank related.
Old May 4, 2016 | 07:07 PM
akwheeler's Avatar
I agree with Angrydog. the hardlines coming out of the top of the tank are probably rusted out. may be the return line so when you're running it soaks the top of the tank.
Old May 5, 2016 | 11:36 AM
Definitely check all the lines coming off the gas tank, very possible one is weeping. Do you notice it more with a full tank of gas vs an empty one?
Old May 5, 2016 | 12:43 PM
dumpster84's Avatar
Thanks for all of the input on this fellas, I'm going to dig into it some more this weekend.
It seems more apparent with a full tank.
Hopefully I can post back with some more info or an answer to this.
Old May 15, 2016 | 04:44 PM
akwheeler's Avatar
did you find the leak?
Nineonerunner
May 5, 2022 10:20 AM
89hilux1
Feb 29, 2016 02:23 PM
Zpayne21
Feb 20, 2016 10:08 AM
Dakotaant
Feb 13, 2016 06:51 AM
