Can anyone identify these gaskets?
Old May 1, 2016 | 07:17 PM
FinallyOffRoad's Avatar
I got a full upper and lower gasket set for my 1988 3VZE and I can't figure out what some of the gaskets are for. My set didn't come with any kind of list as to what it included. Can anyone identify these gaskets?
Two metal crush ring looking things and then one rubber o-ring with a spring in it that looks like a camshaft ring, but it's not
Old May 1, 2016 | 07:35 PM
millball's Avatar
The green ones are exhaust sealing rings.
The brown one is an oil seal of some stripe, maybe for the front crankshaft seal??
Old May 1, 2016 | 08:04 PM
Trents3.slow's Avatar
Yes. The top pictures is for sure exhaust cross over pipe or down pipe rings and the other is a crank seal. Probably rear main seal. The bottom picture looks like a thermostat housing seal. And the little ring gasket next to it has me stumped.
Old May 1, 2016 | 08:31 PM
MudHippy's Avatar
Definitely not the rear main. So if it's not a camshaft, then definitely the front main. The 2 in the bottom pic are none of the above. I've never figured out what the bigger triangular one is, definitely not thermostat housing. And the smaller round one I've never seen before.
Old May 5, 2016 | 08:22 AM
Thank you for all the responses, fellas. I'll be sure to label them. If no one knows what the paper gaskets are, then I guess they aren't important enough to replace
I figured I'd just leave this here so you guys can see how my top end rebuild is going.
Old May 5, 2016 | 08:33 AM
Flash319's Avatar
The big paper looks like egr modulator gasket?.? The little one is for the flux capacitor.
Old May 5, 2016 | 09:08 AM
...what EGR..
Old May 5, 2016 | 09:32 AM
Aaahhhh! The flux capacitor! How did I over look that?
Old May 6, 2016 | 07:05 AM
az1320's Avatar
top to bottom
front crank seal - brown
exhaust gaskets- blue/green
egr gasket- triangle
round gasket---- nothing silicone can fix...lol
Old May 6, 2016 | 09:05 AM
Grego92's Avatar
My guess for the round paper one is oil pan drain bolt....hard to tell how big it is.
Old May 6, 2016 | 09:10 PM
MudHippy's Avatar
Probably.^^
Wrong.
Old May 6, 2016 | 09:29 PM
I would contact the company that sold the gasket set and ask them " WTF IS THIS!??!"
Old May 9, 2016 | 06:52 AM
I don't know how I didn't realize it before. The round one definitely is the drain plug gasket. We just use a little different looking ones at work, but it is the paper Toyota drain plug gasket.
Old May 9, 2016 | 11:05 AM
ThorInc's Avatar
^^^This^^^
foppert
May 3, 2016 06:46 AM
Centaurus
Apr 30, 2016 03:48 PM
ToyotaMD
Apr 28, 2016 05:01 AM
smithra1979
Apr 27, 2016 04:40 PM
brycetryce
Apr 27, 2016 03:57 PM
