Motor noise?
Old Apr 25, 2016 | 08:23 PM
Murfy101's Avatar
Motor noise?
Hey guys I have a 94 3.0 v6 4Runner with 188,xxx miles there is a noise that just started and is there from start up and doesn't go away or get worse either, it is on the drivers side front of the motor kinda sounds like under the valve cover its like a tapping sounds not a tick but a tap lol really tho, I did some research and found that I might need a new lifter shim? First Toyota so I'm clueless on what problems I will run into and such. Any positive input is welcome thanks guys!!!
Old Apr 25, 2016 | 09:01 PM
MudHippy's Avatar
Description too vague. Impossible to diagnose from here. Could be a bunch of different things.
BTW, none of which are very likely to be lifter related.
Old Apr 25, 2016 | 09:41 PM
Murfy101's Avatar
What else would you like to know? Motor runs fine doesn't get worse or better over time, going to do a fresh oil change this weekend so maybe that will help? Idk everything else is fine no check light, no loss in power or anything.
Old Apr 26, 2016 | 03:02 PM
MudHippy's Avatar
The only things I might want to know are...where you at...and do you want me to come take a look at it for you? NW Oregon or SW Washington? I'm not even going to try fixing it from here. But I might be willing to take a short drive.
Old Apr 26, 2016 | 04:10 PM
Murfy101's Avatar
I live in Ohio
cars-guy
66
Jan 26, 2019 08:38 PM
edlopez88
Jun 1, 2016 10:30 PM
Dave co
Apr 18, 2016 11:16 AM
nekchris
Apr 11, 2016 02:43 AM
Brandon Dodson
Mar 28, 2016 06:12 PM
