PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Weird symptoms 3vze
  2. NO fuel to the 22r carburetor
  3. 1989 Toyota 4x4 3.0 rebuild questions
  4. Surface rust
  5. 91 pickup engine issues
  6. 92 pick up FULL TUNE UP NEEDS?
  7. 3vze power loss after warming up
  8. 22re misfire under load. Think I tried all the usual things.
  9. need some wiring help
  10. When battery is connected my engine tries turning on!!!!
  11. 92 turn signal problems
  12. Oh boy not another 22re missfire thread
  13. Buzzer sound on startup
  14. 92 toyota pick up 2.4 5spd 4x4 problem??
  15. Code 14, 52, and radio volume
  16. 22RE Surging Idle and Low Drop (revisited)
  17. Pulling my hair out: Auto to Manual Transmission swap issues
  18. Super simple carb question
  19. Igniter Problem (Well maybe)
  20. Timing experts please educate me
  21. Hosed by shop for lock right install, need help figuring out locker issue
  22. 92 pickup Tube Bumper
  23. 1994 T100 PS hose assy.
  24. New engine needed or fixable?
  25. Reverse light problem
  26. '93 4-Runner - shifting issue
  27. Rear main seal ?
  28. 87 4runner daily driver
  29. Water Pump Copper spray gasket and studs?
  30. Rear link mount separating?
  31. HELP!!! 94 runner 3vze problems!!
  32. 86 pickup only using third and reverse
  33. Just bought a '94 pickup. Break in a noobie
  34. 87 4runner Headlight Control-Switch Plug
  35. Help finding CV Joint bolts?
  36. 88 4Runner try's but won't start
  37. What to look for after extended open loop safety mode 22re
  38. tires?
  39. New motor start up
  40. Need help please: 91 4Runner Load Stereo Killed Electrical System
  41. In need of a wiring diagram
  42. '87 4runner - Manual tran. won't shift after warming up
  43. 93 service manual link broke??
  44. Weird powerloss issue, fuel or sensor related maybe...
  45. check engine
  46. 95 4x4 4Runner 5 speed swap
  47. Wheel size question
  48. 3.0l engine plate
  49. Help Identify Connector (Auto Wiring harness)?
  50. 87-88 Dash cap
  51. Difference in dashboards?????
  52. 1986 4runner 22re Fuel system gurus please help
  53. Overheating HELP!
  54. A/C conversion: what will fit?
  55. Bad alternator or something else?
  56. Alternator not charging battery
  57. Bumpers for my 1994 Toyota Pickup
  58. Blower Motor/Resistor/Switch Questions
  59. Power Window/Locks quit working..
  60. Let's talk lifts
  61. How to Make Old Carpet Look New
  62. check engine light / EGR system
  63. Clutch and brake pedal bracket cracked
  64. 94 4Runner rear lock cylinder
  65. Toyota fix up
  66. 130 Amp Alternator and Wiring Job - 1988 3.0 V6
  67. Weird Starting Issue
  68. Aftermarket Tachometer Won't work
  69. Rear Locker Play
  70. rear disk conversion.
  71. Transmission Trouble...
  72. Bad vibrations - introduction and some issues
  73. brake upgrade questions
  74. 95 4Runner head problems HELP!!!
  75. 87-88 shifter plate console
  76. VIN Number
  77. Front locker going out??
  78. Trying to diagnose 1st gear shifting grind problem
  79. headlight conversion
  80. 3.0 Fuel Rail Issue
  81. 3vze VAFM problems that need answers!!!! Raaaaahhhh
  82. What is this sensor?? (3.0)
  83. What do these do?
  84. 1990 surf 2lte radiator specs and alternatives..
  85. 1988 4runner wiring/injector troubles
  86. Timing Chain Job and questions.
  87. 1990 3vze has no 02 sensor
  88. Timing issue 1994 22re
  89. Hard to find 1990 3vze wiring diagrams
  90. Installing '89-'95 Dash Pad
  91. the teenager takes a twirl
  92. 93 bed
  93. Basic 87 toyota questions
  94. Idle Miss/ Code 11 on 86' 22RE Pickup
  95. 84-95 xtracab rear window rubber deal
  96. Can 22re 4runners daily drive on steep hills ok?
  97. 91 Pickup gauge cluster swap ?s
  98. 87 4WD Pickup Engine harness pinout?
  99. Unknown bracket
  100. Auto Transmission Skipping 2nd Gear
  101. HELP ! 89 IFS Clunking noise in front end
  102. Help with ADD wiring after 3.4 swap
  103. What Sealant is recommended?
  104. 87 pickup 22R acceleration problem
  105. modification of exhaust 3.0L
  106. 22RE Surging Problem
  107. Clutch Pedal Adjustment w/ Pics
  108. Wiring plug behind stereo
  109. 88 Door panels
  110. Radiator hose clamps?
  111. 89 Pickup Parking Brake Light Comes on Intermittently
  112. Help identify leaky hose part
  113. Drivers foot well pic
  114. New here and need a little help please!
  115. 3.0 rev limiter need help plz
  116. 94 22re sr5 4Runner clutch and shifting issue
  117. Any precautions when installing ECU?
  118. Where to buy the Idle Air Valve Coolant Hoses
  119. 94 22re Strange Engine Noise (video!)
  120. g52 transmission question regarding axial movement??
  121. 3.4 supercharged swap flooding!! Help!
  122. 22-RE Ram Air!
  123. 1990 pickup 3.4 swap radiator overflow mount issue
  124. Automatic Brake Reliability? (1986)
  125. Can't bleed front drivers caliper
  126. 22re high idle after shifting into neutral
  127. Dropping rear hatch glass in junkyard?
  128. 88 toyota pick up 22r check engine light
  129. Noob help. Is the 3vze that bad? To keep or sell '90 pickup 3vze 4x4, 160k, manual
  130. 89 3VZE idles rough lacks power
  131. 94 4Runner with back door open and glass stuck UP
  132. Crankshaft Pulley Bolt Removal Problem
  133. Opinions needed...
  134. Identify this hose
  135. 88 v4 4runner vs 89 v6 as daily driver.
  136. please help me! Problem opening trans case G52
  137. Does my carburetor need a rebuild?
  138. Maf interchangeable???
  139. rear lift options
  140. T100 CV shafts in a 1st gen 4runner
  141. newb looking for help. 91 4runner lift to fit 40in tires
  142. HELP! 89 4Runner 22RE Auto, no injectors!
  143. 90 pickup 3VZE rough idle, rattling... air noise problem
  144. BLAZELAND LT IN 87 4RUNNER INSTALLED / CV comment and Question.
  145. Older Pickups vs 2005+ Tacomas
  146. 22RE Surging
  147. 22re blown head gasket with rust
  148. 89 4 cyl 2.4 problems. please help!!!!!!
  149. 22re funky idle
  150. Need 6 lug on a 2WD rear axle - only option to swap axles?
  151. How do I remove the speed sensor from the transfer case?
  152. needing cheap set of shocks for 86 ifs with 4" lift 4x4
  153. power steering problems
  154. Knock Sensor replacement 3vze
  155. Leaky 93 pickup v6
  156. Buying a Long Block. Any Suggestions?
  157. any difference between the 1987 22R and the 1990 22R?
  158. 88 exhaust options?
  159. Mud flap brackets
  160. How necessary is the bvsv?
  161. Auto to trans engine harness
  162. 22re turbo 87 4runner
  163. Questions- Housing & Diff install- 1989 2wd 8 inch where 1991 2wd 7-1/2 was
  164. Need help ASAP!!
  165. Fuel leak
  166. 95 T4R Quest to Pass Emission Part 3: Pair Valve Troubleshoot
  167. 1st gen tube bumper
  168. Transmission Won't shift 1990 4x2 Manual W46
  169. Part availability headed into the future
  170. Softtopper
  171. EFI.. Fuel pump, igniter, or what?!?
  172. Does a 22re cylinder head have alignment dowels?
  173. Mild grabbing/grinding when downshifting after gear oil change
  174. yeah, another {blanking} idle issue
  175. 2WD truck with two U-Joints- Are they both the same size ?
  176. Throwout bearing issue
  177. 90 2nd Gen 4Runner Keeps Breaking Mufflers
  178. Rancho RS5000 on a non-lifted 2WD?
  179. 3VZE Running Rich, slight high idle. LOSING MY MIND trying to troubleshoot.
  180. 1988 Cali VSV is broken
  181. Lower shifter boot
  182. Vafm
  183. Leaf spring question
  184. Best shocks for our little trucks
  185. 22re misfire/stumble under load
  186. Anyone know best way to replace inner CV Bolts?
  187. Winter prep/Block heater
  188. Speed sensor broken off in transfer case.
  189. SAS Planning Help
  190. Turbo on the Pan American Highway
  191. Has anyone seen this? Recommendations?
  192. Chassis Rumble
  193. Dash Lights Come on When Brake Pressed
  194. New clutch slipping
  195. Identify this plug
  196. Testing ECT (engine coolant tempt sensor) OHM reading confusion..
  197. 1986 Toyota Pickup Engine Knocking
  198. What part of the Exhaust system is this?
  199. Marlin Crawler ASCO Master Cylinder?
  200. 22R replacement carb
  201. 22re multiple coolant leaks
  202. CODE 52, Knock sensor gurus please read.
  203. Rear window defrost wiring.
  204. Can't find pinouts for this ECU
  205. I think this cylinder head is bad.
  206. Rebuilt 22RE cranks but wont start.
  207. 4 runner without tail lights
  208. wanting to restore 1986 pickup
  209. High NO, trying to test EGR before replacing cat
  210. 89 P/U, new motor, barely cranks and won't start, code 51??
  211. 22re with flowmaster super 10 CAB DRONE
  212. simple misfire solution??
  213. 4 hole injectors 22re
  214. What Fan and Shroud For 89 4runner 3.0 sr5 3VZE?? HELP
  215. Code 31 and sputtering
  216. Body lift question
  217. Bed Shell/Cap compatability between generations
  218. Electrical issues? Where do I start
  219. Obmi's Build & Questions
  220. Best leaf springs
  221. Rear Suspension Set Up to Complement Blazeland LT
  222. 87 climate control light
  223. 22re metal rattle noise coming from engine (timing chain?)
  224. Igniter Heat Sink Idea?
  225. Cleaning CSI
  226. identifying transmission, shifter bushing
  227. 1989 Pickup Cluth/transmission issues?
  228. 4Runner Owners with converted ACs opinions wanted
  229. I need help asap!!!!!
  230. Finding Parts Number
  231. Twin sticks with factory parts?
  232. Is my timing chain bad?
  233. 1994 4runner No Spark Help
  234. 22re running on three cylinders
  235. Starting Up My Truck After 5 Years
  236. Brake help
  237. Need a quick identification on connector in radio area
  238. pre 90 cup holders...
  239. 3vze Timing belt off by 5 Degrees BTDC
  240. 22re cold start injector question
  241. 93 22RE -- Help me fix another misfire
  242. New to the "Old School" 4Runner
  243. PLEASE HELP!?!?!? No fuel 22re
  244. '91 v6 4runner electrical gremlin
  245. Thanks for all the help
  246. How much do you think your Toyota is worth??
  247. 1st gen 89 4runner interiors interchangable with 2nd gen 90 4runners?
  248. 3VZE to 22RE Swap
  249. Replacing fuel injectors connectors ?
  250. Bad master brake cylinder? Well damn
