New motor start up
Old Oct 13, 2015 | 07:12 PM
Mattluke1's Avatar
New motor start up
Just installed a new re manufactured 3.0l in my 94 runner,timing belt was installed by builder , I only installed homonic balancer and all other pulley belts and exhaust ,intake and distributor, befor I put front cover on I made sure that everything was on top dead center with it all lining up , so the other day I finished installing spark plug wires cap rotor battery , so now I'm ready to fire it up and it runs like crap, missing back fires , rechecked the timing and I'm dead on so I need help any ideas
Thanks
Old Oct 13, 2015 | 08:17 PM
dropzone's Avatar
Fossilized
Positive you have the plug wires hooked up in the correct order?
Old Oct 13, 2015 | 11:55 PM
wyoming9's Avatar
Red face
Leak in the intake manifold
Distributor off a tooth
You did go with all new tune up parts then the quality of those has gone down hill.
Vacuum hoses installed wrong You did go with new hose ??
Bad day at the engine rebuilder it does happen!!!
Old Oct 14, 2015 | 06:00 AM
Mattluke1's Avatar
Tripled checked spark plug wires, at one point when I tried starting it it back fired on the left side of the intake, where the spark plug wires come across the front ?
Old Oct 14, 2015 | 08:04 AM
Mattluke1's Avatar
Just checked my throtel body air intake and found it is cracked at the throtel body would that cause a vacuum problem
Old Oct 14, 2015 | 11:10 AM
kcaudill's Avatar
The crack is not supposed to be there, so yes it would cause a problem
Old Oct 14, 2015 | 07:05 PM
Mattluke1's Avatar
Now after I tried starting the motor, I broke down a tore the front end off , to my amaze the timing belt was off one pulley was dead on and the other was at ten o'clock, so that is why it would not run right, to my understanding is after you install your timing belt you should rotate the motor at least 2 revolulation and the then check TDC again, my fault for trusting the machine shop that put the motor together, a lesson learned
Old Oct 15, 2015 | 11:23 AM
kcaudill's Avatar
you got lucky then
old87yota
Oct 25, 2015 02:15 PM
punks_is_4x4
Aug 21, 2015 01:35 PM
Koolbananass
Aug 12, 2015 01:59 AM
TDonkey
Jul 26, 2015 10:14 AM
cgilley
Jul 25, 2015 10:55 PM
