PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 1987 PU Front Right Grinding Noise
  2. 1993 4runner cutting out
  3. Good compression - losing coolant through #6 cyl
  4. 1st Gen 4runner: Rear Heat/AC anybody know anything aboutt it?
  5. 91 Runner Instrument Cluster Racket
  6. How to remove/replace fpr/fpu vsv (95 4runner)
  7. How Cold Start Injector System Works - 22RE
  8. EGR Temp Sensor Location
  9. 1987 4 Runner fuel injection
  10. 94' 22re struggling under load
  11. 86 Toyota; No blinkers, gauges, and battery dies
  12. 1993 4runner aftermarket keyless entry writeup?
  13. Engine Ping
  14. Dash lights and turn signal relay
  15. Which stud do I need?
  16. 1989 3.0L oil no pressure
  17. Is it worth it to fix this? (Body damage)
  18. Cold start injector switch repair with pics
  19. rear end noise before, worse after rear lift
  20. tacoma rear end
  21. What's this
  22. Still piecing together 22re
  23. Slipping A340H Auto Trans in 3rd Gear, 1993 V6 4x4
  24. Installed new battery, now relay clicks.....period. .....no crank
  25. Engine starts and then dying
  26. Toyota Parts
  27. Idle issue
  28. Body parts interchangeability- 93 v6 to 94 22RE?
  29. vacuum component identity
  30. loose power steering belt
  31. Right turn signal buzzing
  32. went into a ditch, now can't get out of park and won't start
  33. Need a 3.0l Guru
  34. Blue cable runs from engine compartment to behind heater control? It’s in the way...?
  35. Does the shifter need to be greased?
  36. Radiator fan replacement
  37. R1F1 and A.D.D. Tech Questions
  38. blower
  39. occasional passenger side noise..
  40. four runner 88 v6
  41. Highway Screech/Vibration
  42. 3.0 engine mount question
  43. advice for undercoating
  44. 4WD stuck/binding, 4runner barely moves, even in neutral!!!
  45. Need help.. Random vibration.
  46. Will 96-2000 4runner seats go in a 87 pickup
  47. Radio Security Idea Help
  48. Clueless Wire Identification
  49. Coolant leaking from the engine block
  50. Rebuilt 3VZ-E Burning Coolant!?
  51. New to the website need help!
  52. 93 Pickup 4x4 indicator light issues
  53. Help with piecing together 22re
  54. STOLLEN!!!! 1989 Pickup
  55. Head swap '95 22RE HELP! I WILL GIVE YOU COOKIES!
  56. 93 Pickup Rebuild
  57. Still confused on my sense wire
  58. manual windows to automatic
  59. 1987 2WD bed WILL fit an 1988 4WD pickup
  60. 1989 toyota pickup LH tail light not working
  61. 1991 4runner CHECK ENGINE LIGHT HELP
  62. clutch problem
  63. 1994 pickup 4x4 22re rear brake shoes
  64. clutch problems
  65. Front/rear differential fill plugs for 93 pickup
  66. My 1987 2wd drive project. Fixed up, stolen, and now fixing it again
  67. Ranger seats in a 87 pick up. Couldn't stop myself. (LONG)
  68. What's interchageable between 4runner/pickup?
  69. 1986 pickup 22ret 4x4 Terrible Gas mileage
  70. Sloppy Steering help
  71. 4WD won't disengage.
  72. New to me Rig, 3.0 problems.
  73. 1987 4Runner - Restoration and Preservation
  74. Looking for info that I should learn on my truck
  75. Need help
  76. 94 4runner 4wd issues
  77. Rear window issues
  78. Softopper
  79. Bellhousing dust cover
  80. w55 5spd in a '93?
  81. ARB vs Aussie locker front and rear?
  82. Rear engine seal leak- Toyota Tundra SR5 2005
  83. '95 t4r rusty gas tank
  84. ‘86 Pick up 22RET 5spd
  85. Idle lower after adjusting alt and PS belts
  86. Is my Catalytic Converter bad?
  87. Exceleration problems
  88. My 1986 toyota four wheel drive truck
  89. Need direction for 94 22RE
  90. High Beams Not Working with Low Rang Headlight Harness?
  91. 22re factory turbo
  92. bumper ext plug
  93. 1989 Base Fender will an SR5 fender work
  94. 22re code 22
  95. Not enough heat!
  96. 92 RE Squeal, not at first start up but at startup after a 25 mile drive?
  97. 92 RE Squeal, not at first start up but at startup after a 25 mile drive?
  98. 22re Cold start up / thermostat ?
  99. Tow 13 ft Scamp with 22re?
  100. 1992 Toyota Pickup 5spd manual 22re power lag
  101. New (old) 94 Yota Pickup
  102. What is this part? First-Gen 4Runner
  103. 91 4runner making weird whining sound
  104. Welding a receiver to an Addicted Offroad frame reinforcement Kit
  105. 88 pickup timing
  106. New here! 88 pickup - need to replace upper ball joints, drivers side CV - what else?
  107. Alternator trouble Gm CS 144
  108. What is this part?
  109. Need some help please!
  110. '89 Pickup Manual Shifting Problem
  111. Voltage regulator?
  112. Transfercase shifter broken (inside pan) 95 auto
  113. 87 22R carb timing
  114. Has anyone swapped cloth seat covers for leather?
  115. Delete lspv on 87 4x4 pickup or fix it?
  116. New head gaskets now my Toyota is shooting flames out of the throttle body
  117. 93 3.0l start running rough, smoking and smelling like an old lawnmower?
  118. Flex Plate
  119. 4runner diff crunch
  120. Blazeland or Total Chaos
  121. 1992 22RE Trick to tighten alternator belt?
  122. 1986 pickup been sitting-what to do?
  123. Rear towbar for 86 4runner
  124. fusible link
  125. Interior Restoration
  126. 2nd gen 4runner hardtop convertible?
  127. 22re N/A pistons in 22ret ?
  128. AC belt necessary for 3ZVE?
  129. 87 22RE Injectors not firing
  130. 22re injector pulse while engine off
  131. Power loss
  132. cranks but wont fire 1992 3.0l pickup
  133. Very poor compression test, good leakdown
  134. Jackhammer noise in 4wd turning on a steep road..
  135. oem stant thermostat 180 or stant superstat 180
  136. Flipped my 4runner, What should I do?
  137. Grease
  138. DIY: vacuum leak check with a vape
  139. '95 T4R issue with low power, sounds like out of fuel
  140. Engine swap questions
  141. Leaky block heater
  142. Throttle problems
  143. seat swap
  144. How hard is it on the vehicle to recover someone?
  145. High idle won't kick down
  146. vacuum hose order
  147. 94 hi-lux
  148. R151 Transfercase Lever retainer assembly
  149. vss in combination meter
  150. Chain transfer case part ?
  151. Rough idle
  152. 87 cat delete
  153. Emergency Help
  154. 92 22re runs then shuts off
  155. 93 4runner with 3.0L head gaskets
  156. truck ran great,parked it overnite started it and was missing and runs terrible. what
  157. Cold natured and bad dead spot off idle
  158. 93 4Runner.......((HOT)) Rear Window Motor!? WTH???
  159. Hard Cold Start, Wont hold idle
  160. 87 4Runner 22RTE Won’t Start All of a Sudden
  161. 2nd Gen 4Runner LED Tail light experiment
  162. idling at 15mph
  163. Mystery stud
  164. 3vze Flowmaster Model?
  165. Windows won't go all the way up. And comes out of track
  166. T100 no 4wd even after manual hub swap
  167. Engine smoking after rebuild
  168. Truck surges only while in 4wd.
  169. 3.0 stalling
  170. bad brake booster, how can I tell
  171. Bumper swap 3-piece for 1-piece
  172. Lock-Right Locker - Advice?
  173. Rear End
  174. 2wd to 4wd conversion
  175. Just lost my clutch
  176. 1990 coil and distributor died
  177. 87 pickup. Can I add a passenger side mirror
  178. 94 3.0 I Got Leaks, They're Multiplying!
  179. I need help with a volley of codes (95 3VZ-E)
  180. 87 pickup horn doesn't work
  181. ignition coil resistance of rav4 2002
  182. 1988 4x4 pickup prepurchase advice help
  183. Kill switch Question..
  184. 87 pickup no heat. Heater core or water pump?
  185. 75w90 LIMITED SLIP?
  186. Radio antenna
  187. Back tailgate window stuck after mild trauma...
  188. cyl #5 no injector pulse
  189. what does the RN stand for after 22 R-E
  190. 4WD ADD connector. From Actuator to where?
  191. Toyota 4Runner first gen 22RE sound
  192. power steering pump 22re inlet replacement
  193. CEL Help
  194. 89 3VZE stalling and idle issues
  195. Two Temp Probes/Sensors around Thermostat - 22RTE
  196. body mount bushings 2nd gen
  197. exhaust crossover delete
  198. 1995 4runner all gears slip except 4Low
  199. Cant unplug wiring harness'
  200. Need some advice on what to do with 1993 3.0
  201. Timing cover leaking oil after HG/Timing Chain replaced
  202. 95 4runner leaking fuel
  203. Electrical issue
  204. Remove mice in truck/defend against mice?
  205. 95 4runner leaking fuel
  206. Help! 22RE grinding sound
  207. Replacement Mirror Insert Glass for SR5 Power Mirror
  208. 94 v6 overheating
  209. '87 pickup vent window weathersrip interchangeable between years?
  210. Dome Light: How it works and Troubleshooting - 22RE
  211. Help: 95 4rn with 3.0l with no power
  212. suspension and steering done
  213. Tell me about gaugues
  214. 22re spark plugs
  215. Horn Troubleshooting - 22RE Or other applicable models
  216. Combo meter
  217. Horn still not working after hours of troubleshooting
  218. Dome Light not on when Drivers Door Open
  219. performance upgrades
  220. 92 Heater Fix - Where does this Blue Plug Go?
  221. turn signal killing engine /95 4runner
  222. '89 pickup 3.0 to 22re swap help
  223. 3VZE Oil Leaking from Head Gasket
  224. Code 24 (AFM Temp Sensor) but my AFM checks out
  225. '89 Toyota Pickup Engine Swap
  226. 4Runner Tailgate Panel
  227. 2000 4Runner 3.4 v6 won’t rev up. Idles fine. has codes misfire 3 &4 , tps & lean
  228. Blazeland questions
  229. 22re idle problems
  230. spark plug check ?
  231. Cold start idle problems
  232. Lowering rear seat
  233. New 22RE motor, white smoke
  234. 93 2wd 22re headlight problem
  235. 84 22R with almost instant bogging, stalling out
  236. Scrap or rebuild 3vzE(also free parts)
  237. Keyless entry aftermarket?
  238. yotaman !
  239. tow package
  240. 2TR 4Runner 94 swap
  241. 3VZE Oil Cooler Gasket Identification
  242. 3VZE Intermittent Misfire... ? , No Code
  243. Guy at 22re performance gave me some unusual advice.
  244. Am i off a tooth?
  245. Passenger door window '84 4Runner
  246. HArd to get into gear
  247. James Dean Creations Decals Review
  248. Question on Reusing Rear Axle Bearings That Have Been Pressed Out
  249. 4.88 third member
  250. Shift Indicator in Shifter Assembly - Only one complex option left?
