Transfercase shifter broken (inside pan) 95 auto
Old Nov 26, 2017 | 04:36 PM
954runner95's Avatar
1995 4runner automatic v6
I'm doing a tranny swap since my old one had a c3 clutch in the transfercase get stuck open
Anyways, I noticed the shifter knob had no clicking on the transfercase shifter so I pulled the pan off to see what was wrong
1995 fo
any ideas on how to repair?
Old Nov 27, 2017 | 11:48 AM
rustypigeon's Avatar
-Remove valve body
-Remove spacer on the lever shaft using a chisel. (This is on the same side as the PNP switch, but on the inside of transmission)
-After you remove spacer, you will see a locking cylinder on the shaft. Drive out the pin and shaft will then slide out the side of transfer case.
Order a new shaft seal and spacer along with your new Manual Valve Lever.
Last edited by rustypigeon; Nov 27, 2017 at 12:01 PM. Reason: Realized this was the transfer case, not transmission.
