Blue cable runs from engine compartment to behind heater control? It’s in the way...?
Old Dec 14, 2017 | 07:26 PM
uraceulose's Avatar
The upper driver side vent right under the vent windows duct has been missing. I found an oem replacement and bought it. The mounting screw looks like you have to drop the parking brake handle to get at? And there is a blue cable that is pretty taught that runs from the engine compartment to the rear of the heater control unit it appears. This cable runs exactly where the duct needs to go, it is tightly ran right in front of the opening for the vent that is right behind the driver side of the heater/AC control panel.
What does this blue cable do and can it be re routed or moved and under more ‘tension’?
Thanks for any help,
Donnie
88 ext cab 4x4 5 sod
Old Dec 14, 2017 | 08:51 PM
mholme's Avatar
What does the blue cable end in the engine connect to, the heater control valve?
Old Dec 14, 2017 | 11:01 PM
uraceulose's Avatar
Thank you for the reply. Yes I’d does. I actually was able to get it by putting it on “cold” then pushing the cable upwards and I got lucky the duct popped right onto the main plenum now I’ll tape up the other end in the morning and be good to go.
MrHunterman12
Dec 31, 2010 10:37 PM
UKMyers
35
Jun 13, 2007 09:50 AM
slamigo
Jan 18, 2007 09:04 PM
richardyc
Jul 25, 2003 09:47 PM
L33T35T 4Runner
12
Feb 16, 2003 12:26 PM
