- Auto to Manual Hubs - What do I need?
- Almost A Bumper
- Help!! 4Runner wont start after radiator flush
- 3.0 to 3.4 swap 94 4runner
- truck about to die
- Strange warmup problem
- 1990 4Runner...Is this a good deal?
- 88 4x4s electric window switch not working
- E-Brake question
- She's almost done - Front end drop!
- IFS lift question
- 88 4runner pully problem
- Newb Question
- Help! Sudden Loss of Power 3.0
- '82 22R in '88 4Runner (EFI)
- 95 3.0 Best Head Gasket
- How hard is to change T-stat?
- Can't get more than 30mph uphill!
- weber help?????
- Shift improve kit for auto?
- Power Steering
- Would you guys rock these tires?
- 1994 truck question (normal operating temp?)
- drivetrain noise...
- Hard to shift t-case
- Wabfab Shackles - Bushings!
- What will happen
- coats. and. locks.
- Compression test numbers on a 91 runner
- First post, got a bad problem
- 35s on 4inch ifs lift
- manifold red hot
- Gear Driven T-Case w/ Syncros? + Harebrained idea
- Where is all the gear lube going? Found it!
- Flat bottom - auto and IFS
- exhaust question
- 94 22re will not start, little help please
- Steering Freeplay Adj. Nut HELP!
- Shock Length (I've read a lot of threads)?
- 22re block HELP!!!!!
- Well I guess it's time to do the 3.0 ISR mod. Help please?
- heater slow warm up?
- Gas mileage on 22rte?
- how difficult (and how long) to replace both bumpers
- Help
- heater lights
- SR5 convertion
- Marlin Crawler
- Brakes Making Weird Noise! Help Please!
- replacement for inside fuel door? - question for slacker
- stupid noobie cant figure out timing prob...
- Lt4 & 6 speed swap (1995 4runner)
- Fuel Injector Interesting Problem
- Heater fan ??
- Lock for gas tank cover
- info needed on lockers and LSDs
- Spare Wheel
- Air Filter Change
- broke air mass meter - is there a way around it?
- Diff. Seals
- 93 22re pickup issues
- Drip rail molding application
- Here it goes..another lift thread...86' runner
- Do you consider your 4-runner a truck?
- this is NOT afuel filter replacement question
- how to raise warm idle
- Hesitation after water
- my son and i
- Dome light and dash heater select light broken
- Engine Swap
- Tips on stuck leaf spring bolts
- 3.0 Torque versus Horsepower
- blown head gasket in 4runner...what are my options?
- How many miles on your A/T?
- Just Seafoamed
- head
- Power? Torque? Big Problem ( Long )
- timing belt replacement
- Starting problem ???
- 88 v6 4x4 pickup high cold idle
- Steering Lock
- Wheel Lock!
- anyone use a detachable steering wheel
- 22RE engine bog
- 1st gen weather enclosure
- need help
- Spark plug gap
- over heating problem
- head gasket ? sorry
- 1994 truck tranny question (stick)
- 1" Body Lift Shifter Vibrating
- Marlin Crawler Bumper
- Lift and tires dilemma - help me choose!
- Exaust +
- clutch question
- CV Axle Installation Help
- Bed length on a '94 DLX 4WD Extra Cab?
- Couple specific exhaust questions..
- 1994 4runner wheel chatter in snow
- O2 & Hg
- Decal Removal???
- So it is winter time.
- Fuel injecter harness
- Hi-Flo Cat
- Loosing Stuck Bolts
- 3VZ-E rev limiter?
- What you can expect from insurance comanies (be prepared)
- 89 22re Exhaust Manifold Stud Thead Pattern - PIC
- New to the site
- Question about wheels need some advice
- 3VZE Head Gasket Questions
- dash and console replacement?
- 22re timing chain
- add-a-leaf or spring helper?
- The Death of Total Chaos
- Transmission Trouble
- major coolant leak
- Lack of Power on Acceleration
- Post pics of modified lower valances
- better 2wd trannys for 22re?
- 92-95 4wd grille
- The Motherload of Problems (Condensed)
- Another 3.0 Bites The Dust
- O2 sensor location 22re
- Idles erratically at cold until it warms up on '89 3.0
- 86 4runner - parts list for lift - anything else to add?
- Conversion the 4RUNNER to a pickup possibility?
- a present from santa!
- Distributor cap
- Well...good bye YOTATECH. Not yet, but real soon
- 89 22re PICS almost done!
- Buying tires from 4wheelparts online?
- Does napa sell the correct windshield wiper blades?
- Brakes go from soft, to hard, and back.
- could someone do me a favor?
- semi-noob automatic 4x4 questions
- Best way to lube windows?
- Just cleaned my Surf petrol, *pics inside*
- Anyone want to donate a lower valence?
- shock question
- 22RE sick of the problems.
- T3 turbo swap
- total noob question
- 3.0 V6 cruise control
- 91 yota 4runner help
- gauge lights?
- 22r jumpy timing
- Rear Cargo Door Not Opening
- Swaping Manual hubs for auto lockers
- Hella Lights killed my alternator
- trying to lower spare tire w/ marlin rear
- steering gear question
- rear defroster doesn't work!!!
- a turbo for the 3.0 under construction?
- Tailgate cover
- St-St-St-Stuttering 22RE Engine
- Idler arm for 1st gen
- Replacing Engine Mounts on 1990 V6 4Runner
- O2 help
- Doetsch Tech 8069 Vs Monroe whatevers
- noobie snorkel question
- truck is at the shop for steering and plugs
- Need help and lots of it! Can't get hood open
- ct20 turbo housing???
- part out or sell whole? 94 sr5 4x4
- Exterior Rollcage Dimensions??
- 4WD won't engage ('95 4Runner)
- 86 turbo pickup engine management???
- DT Shocks
- Banjo bolts
- Performance Exhaust
- 3VZE to 22RE swap
- Cranks real strong - but won't start!!
- Power steering conversion?
- rear heater...removal or replacement?
- Several Problems with my 3.0, worth it?
- Snow plow on a 2end gen???
- Crank pulley
- Location of circuit opening relay - 94 4Runner
- I Need Electrical Help
- which goes first???
- questions on the 3.0
- Anyone using stock front seatbelts as rear shoulder belts in a 1st gen?
- brake problems, need help ASAP!
- 89 3.0 wont start
- ARB equipped front differential on ebay
- Throttle Cable Adjustment
- Steelie Owners...
- blowing 80amp fuse?
- New pro-comp shocks installed and clearance issue
- Hey eveyone! Want Ideas! 86 Runner
- Got New Bumpers!
- knock sensor issue
- 3.0 V6 electric fan
- Total Front Suspension Refresh
- Rear window in 88rnr won't go up/down
- quick question about my truck
- Gasket Sealant
- Dead 3.Slow
- Cruise Control Issue
- Interesting motor swap
- pinion flange problem
- New HG 22r, white smoke
- Belt Question
- Replace 60A Fusible Link with in line fuse?
- HELP?! Starter 2ndary wire?!
- Downey Suspension?
- Rear Bumper Replacement Suggestions
- urban snow wheeling
- 3VZE Starting "Malady" Followup
- polyurethane bumpstops/engine mounts for a 3.0?
- Windshield Rust
- Changing belts
- PowerTrax No Slip Install
- Fuel Pump
- Burnt valve
- How long to replace a 3.0 in a 94 4runner?
- Kick Panel speaker pods
- 91 4Runner: front heater doesn't work (no air)
- how do i fix a high idle?
- tach signal and idle and surge questions
- 2008 YotaTech calendars!
- engine stumbles while driving..
- Air Flow Sensor 1991 3VZE
- Exhaust?
- Centerforce vs. Marlin clutches
- Ok im selling my truck am i asking way to much?
- Clearance lights
- So, i got hit in my truck today...
- tie-rod adjustment problem
- Intermittent Wipers
- New here, 4Runner questions
- Need help! Can't shift?!
- no oil pressure after rebuild
- catalitic converter replacement pipe
- custom guages
- Kinda Odd Looking?
- 22R fuel pump
- idle surging
- advice needed
- 1st Gen 4runner Parts???
- 2nd gen 4Runner rear bumpstops
- Mirrors
- Coolant Leak
- 22re Bellhousing
- code 21 how to fix?????
- 5 spd oil fill/check plug...
- no rear heat <4runner>
