Loosing Stuck Bolts
Old Dec 19, 2007 | 01:42 PM
YotaZW23's Avatar
Loosing Stuck Bolts
I am replacing my front right axle. When I came to step where you have to loosen the 6 axle shaft-to-differential housing nuts I could not break any of them loose. I tried a breaker bar, soaking them in WD-40, and I still can't break them loose. Any ideas? I would hope to try and get this done tonight. Thanks.
Old Dec 19, 2007 | 01:56 PM
HOOLIGAN 4 LIFE's Avatar
Try Heating Them Up With A Small Propane Pluming Torch. The Diffrential Material Will Expand Faster Than The Bolts. Usually Works Like A Charm Every Time. ( Do Not Heat Them Up Untill They Glow Just A Few Seconds Or So. Just To The Point Were There Nice And Toasty).
Old Dec 19, 2007 | 01:58 PM
TORTIS's Avatar
when i did my truck, i had to use a 24" breaker bar, and a 4' piece of pipe. used a pipe wrench to hold the shaft. have fun.
Old Dec 19, 2007 | 02:42 PM
shaeff's Avatar
heat, PB blast, and a breaker bar.
Old Dec 19, 2007 | 02:48 PM
infiltrator's Avatar
hmmm heat, i never thought of that.... :]
Old Dec 19, 2007 | 02:56 PM
shaeff's Avatar
woops, i'm not sure how this got doubleposted (especially so far apart)
so i'll add to what i stated before- heat around the bolt that needs to come out, as the surrounding metal will expand, thus making it easier to remove.
for nuts, heat the actual nut evenly, as you want IT to expand and turn easily off the bolt/stud.
Old Dec 19, 2007 | 02:58 PM
isaac338's Avatar
i'm not sure of the shaft-to-diff bolts, but remember that some bolts in the front driveline are splined and you can only turn the nuts.
edit: yeah, i'm sure. the CV to differential tulip bolts are most definitely splined on the bolt, so don't bother trying to turn the bolt - you won't get anywhere. turn the nut
Old Dec 19, 2007 | 03:00 PM
tc's Avatar
tc
Yep - make sure you are turning the proper side!
Old Dec 19, 2007 | 04:51 PM
YotaZW23's Avatar
Thanks for all the responses! I was able to use heat and a breaker bar to break them lose. Thanks again.
Blamalam
Mar 12, 2022 07:34 AM
JAmdor3
Aug 11, 2015 10:53 AM
rustym
Aug 7, 2015 10:39 AM
TJWilly
Jul 31, 2015 02:05 PM
pyramid
Jul 30, 2015 10:05 AM
