Shift improve kit for auto?
Old Dec 23, 2007 | 08:45 PM
James Dean's Avatar
Does anyone know of someone that makes shift improve kit for the automatics in a second gen 4Runner. Or if there is something you can alter in the valve body to tighten up the thing. I know they are made for every chevy, ford and dodge tranny out there. Has anyone come up with something for us import guys? Especially when that tranny is so known for it's power loss.
Old Dec 23, 2007 | 09:05 PM
WCorbett's Avatar
Ya theres one out there called the r150f. Doin the r150f swap is the best way to make it shift better.
Old Dec 24, 2007 | 07:12 AM
slater442w30's Avatar
screw a 5 speed, here is some help
http://www.prweb.com/releases/2005/11/prweb315450.htm
Old Dec 24, 2007 | 09:19 AM
turtle jim's Avatar
Poor man's shift kit.
Disconnect transmission "kick-down" cable from throttle body.
Pull the cable all the way out and fasten it in this position.
You'll get a much firmer shift.
Old Dec 24, 2007 | 10:21 AM
881stGenRunner's Avatar
^^ so youre saying to have the kick-down cable always taught?
Old Dec 24, 2007 | 10:26 AM
bigtrucknwheels's Avatar
hahaha, that sounds awesome. why not just use ECT Powar all the time?
Old Dec 24, 2007 | 11:09 AM
turtle jim's Avatar
Position of kick-down cable controls line pressure in trans. Relaxed cable, soft shifts, taught cable, firm(er) shifts.
power button raises shift point about 500 rpm's
Use both and get a more firm, delayed shift.
Try it !
Old Dec 24, 2007 | 01:32 PM
SoCalWheeler71's Avatar
Warning about the ECT power button- it disables the TCC lockup, so don't do that unless you have a BIG trans cooler. The A340 trans for the 3.0 has a 2800rpm stall converter that is designed to work with the TCC lockup to keep the heat down.
Old Dec 24, 2007 | 02:00 PM
swerks's Avatar
whats the down side ?? what does this do to the tranny in the long run ? there must be some price to pay
Old Dec 24, 2007 | 07:29 PM
skife's Avatar
pull the valve body off, put a heavier spring behind the accumulator piston.
you'll get much much firmer shifts.
Old Dec 24, 2007 | 11:49 PM
zachb55's Avatar
Originally Posted by slater442w30
very helpful and to the point post, awesome! any other companies providing anything similar to these guys kits?
Thanks poster!
Old Dec 25, 2007 | 12:22 AM
Dare44's Avatar
the 5-speed swap is still going to always be better than an auto, even tho i just bought an auto, but if ur looking for straight performace than the manual tranny is the way to go
Old Dec 25, 2007 | 05:35 AM
FredTJ's Avatar
Of course there is a downside:
Line pressure that is too high will lead to shifting shock and consequent engine power loss due
to the greater effort required of the oil pump; line pressure that is too low will cause slippage of
clutches and brakes, which will, in extreme cases, prevent the vehicle from moving. Therefore, if
either of these problems are noted, the line pressure should be measured to see if it is within stan–
dard.
Fred
Old Dec 25, 2007 | 05:38 AM
mt_goat's Avatar
These guys did mine:
http://www.importperformancetrans.com/
Merry Christmas
Old Dec 25, 2007 | 05:51 AM
FredTJ's Avatar
Originally Posted by SoCalWheeler71
<SNIP>
Wrong, the stall speed is 2200 rpm.
Fred
Merry Christmas !
Old Dec 25, 2007 | 06:00 AM
FredTJ's Avatar
In almost every off road type environment the auto will perform better than a 5 speed (ducks as he opens up the can of worms again). Simply go to any type of off road comp and see what most of 'em are running, especially in the rocks..
Auto's rule in the rocks.
We take hard obstacles and make 'em look easy, the manul people take easy obstacles and make 'em look hard
Fred
Old Dec 25, 2007 | 06:07 AM
CJM's Avatar
CJM
Go through IPT, they do excellent work! They worked on my 84 vette and did a very good job.
Old Dec 25, 2007 | 08:01 AM
mt_goat's Avatar
Warning about the ECT power button- it disables the TCC lockup...
Interesting, I didn't know that. Thanks for the info.
Merry Christmas
Old Dec 30, 2007 | 06:58 AM
James Dean's Avatar
My lockup works fine when I have the ECT on. Goes thru all the gears fine and then you see the rpm's drop another 10-15% when the lockup engages. Other than slightly higher rpm why would the TCC not being on cause overheating? I have a 200-4R behind a built buick 3.8 V6 in a Nissan truck that has a manual Lockup option (can turn it on or off) and my tranny temp runs the same. Is this different in a Toy tranny? I do have a cooler though.
Dale - Did you see a difference in performance (power, economy) when you had IPT do your tranny or did it just give you firmer shifts? I think my tranny shifts fine when I have the ECT on. That's alot of money just for a tighter shift. Especially when Chevy, Ford, and Dodge shift kits are only $100-$150 and only take about an hour to do.
Old Dec 30, 2007 | 06:59 AM
James Dean's Avatar
