Shift improve kit for auto?
Does anyone know of someone that makes shift improve kit for the automatics in a second gen 4Runner. Or if there is something you can alter in the valve body to tighten up the thing. I know they are made for every chevy, ford and dodge tranny out there. Has anyone come up with something for us import guys? :cry2: Especially when that tranny is so known for it's power loss.
Ya theres one out there called the r150f. Doin the r150f swap is the best way to make it shift better.
screw a 5 speed, here is some help
http://www.prweb.com/releases/2005/11/prweb315450.htm |
Poor man's shift kit.
Disconnect transmission "kick-down" cable from throttle body. Pull the cable all the way out and fasten it in this position. You'll get a much firmer shift. |
^^ so youre saying to have the kick-down cable always taught?
Originally Posted by turtle jim
(Post 50703060)
Disconnect transmission "kick-down" cable from throttle body. Pull the cable all the way out and fasten it in this position. You'll get a much firmer shift. hahaha, that sounds awesome. why not just use ECT Powar all the time? |
Position of kick-down cable controls line pressure in trans. Relaxed cable, soft shifts, taught cable, firm(er) shifts.
power button raises shift point about 500 rpm's Use both and get a more firm, delayed shift. Try it ! |
Warning about the ECT power button- it disables the TCC lockup, so don't do that unless you have a BIG trans cooler. The A340 trans for the 3.0 has a 2800rpm stall converter that is designed to work with the TCC lockup to keep the heat down.
whats the down side ?? what does this do to the tranny in the long run ? there must be some price to pay
pull the valve body off, put a heavier spring behind the accumulator piston.
you'll get much much firmer shifts. |
Originally Posted by slater442w30
(Post 50702969)
http://www.prweb.com/releases/2005/11/prweb315450.htm Thanks poster! :xmas1: |
the 5-speed swap is still going to always be better than an auto, even tho i just bought an auto, but if ur looking for straight performace than the manual tranny is the way to go
Originally Posted by swerks
(Post 50703261)
Line pressure that is too high will lead to shifting shock and consequent engine power loss due to the greater effort required of the oil pump; line pressure that is too low will cause slippage of clutches and brakes, which will, in extreme cases, prevent the vehicle from moving. Therefore, if either of these problems are noted, the line pressure should be measured to see if it is within stan– dard. :) Fred |
Originally Posted by SoCalWheeler71
(Post 50703242)
<SNIP>
The A340 trans for the 3.0 has a 2800rpm stall converter that is designed to work with the TCC lockup to keep the heat down. Wrong, the stall speed is 2200 rpm. :) Fred Merry Christmas ! |
Originally Posted by Dare44
(Post 50703588)
Auto's rule in the rocks. We take hard obstacles and make 'em look easy, the manul people take easy obstacles and make 'em look hard ;) :) Fred |
Go through IPT, they do excellent work! They worked on my 84 vette and did a very good job.
(Post 50703242)
Warning about the ECT power button- it disables the TCC lockup...
Merry Christmas :xmas1: |
(Post 50703242)
Dale - Did you see a difference in performance (power, economy) when you had IPT do your tranny or did it just give you firmer shifts? I think my tranny shifts fine when I have the ECT on. That's alot of money just for a tighter shift. Especially when Chevy, Ford, and Dodge shift kits are only $100-$150 and only take about an hour to do. http://www.jamesdeancreations.com/Sa...aint%20006.jpg |
