- Axle Snap Ring Needed?
- transmission leak Help
- 1987 new engine wont pull itself into driveway
- Problem with front CV axles 89 4runner
- speedometer and odometer dosent work
- hoping not a headgasket
- REpair or REplace: engine trouble 1987 22RE
- 3vze doing rod bearings
- 4WD light stays on??
- P/S pully fell off!
- manual to auto cab swap
- rpms rise when clutch is depressed in nuetral
- New Member First Post
- '94 Pickup Transmission Urgent help
- No Spark Condition_ Questions about testing
- damage to number 4 and 5 spark plugs
- 87 pickup center console
- Auto to manual hubs?
- 91 Toyota 4 Runner with a 3VZ-E has a miss, rough idle, won't start in cold weather.
- top hose hot bottom still lukewarm......
- Spits and Sputters
- How To: 84-88/89 Pickup/4Runner Sun Visor with Mirror Swap
- whining? noise, driver side around 25mph
- nother shock question
- There's a gas light!?
- Bad Starter Or Ignition Switch ??
- 86 4Runner turbo diff upgrade?
- Invalid VIN
- Broke shock hoop , help me put it back together better.
- No spark from coil when hot.
- pickup towing mirrors install
- I need more leg room
- '86 4runner 4Y fuel consumption
- bought truck with problem 22re,, replaced engine....problem still remains. UGH HELP!
- lots of problems
- my truck locks when in 4wd hi and turning help!!
- 1990 Runner No Cold Start/No Turnover
- guide to removing plenum in 94 4runner 3zve 3.0 v6 4x4?
- 4WD Wont Stay Engaged!!! 92 Pickup
- 88 4Runner no power - fuel pump?
- intermitaqnt fuel leak - 95 t-100
- 3zve please help me locate a gasket number 1994 4runner 4x4
- Warm 22re runs super rough. No problem when hot or cold.
- Sulfur smelling exhaust, idle issue after spark plug & plenum remove/install
- OME Part # verifications?
- sr5 gauges
- Fuel sending unit questions
- Guess this plug!!!
- Cranks but no start.
- Rev and/or idle issue 22re
- truck sucks in tahoe- difficulty running at altitude
- free truck head gasket
- 1994 4runner making a grinding type noise in front end
- Pictures of 3rd Gen Stock hitch receivers please?
- Little pipe coming out of cab into engine bay
- Lower radiator hose leaking, please help.
- Body lift removal
- 1994 3.0 4x4 4runner with bad fuel leak where rubber meets metal fuel line
- 3vze head gasket debate. Engnbldr vs LCE
- 3vze hydraulic to spring Tbelt retrofit?
- 1987 22RE PCV valve grommet replacement
- 3.0 V6 jumping time.
- Truck won't start. Please read before giving me hell....
- 1994 toyota pickup v6??
- '94 V6 RWD Auto 4Runner transmission and thermostat issues
- Ac idle-up VSV, stuck?
- Rear axle housing bent?
- ignition system interchangability.
- Code 52 at 2000 - 2500 RPMS but not at 3000 HELP!!!!
- rocker arm and cam repacement
- "Wandering" mixture screw
- 88 4runner fuel sending unit
- compression numbers
- 1994 V6 4runner headlight/taillight issue
- Radiator Cap?
- Help me Figure this out front sus Spending spree
- 86 truck wont run
- 88 4runner no heat an running cold
- 94 v6 pickup cutting out help!
- Wideband o2 sensor?
- 3vze knock sensor bypass
- Hi Steer Arms and Marlin 25mm upgrade
- Ok, Now I really need your inputs re head gaskets and more
- 22re bolt Question
- 86 4Runner rear window key/license plate light switch location?
- Thermostate Test Q
- 1990 2wd 22re pickup exhuast setup
- 6 ABS Codes, Where do I start?
- 1987 4runner 22re throttle body idle screw
- 94 4x4/22re Truck running rough post rebuild, possible head gasket?
- coolant leak after replacing radiator
- No crank issue
- Battery, brake and transmission temperature warning lights all on at the same time
- wired connector next to intake (Identify)
- Auto to 5speed questions
- Forest Green Metallic (6J7) pic request
- Clutch wont engage
- Dealer Temp sensor no 4x4???
- 3VZE Idle Problem After Warm Start
- fuel smell in exhaust, smoke, and fouling plugs after head gasket repair and headers
- Confused with electrical problem with alt replacement, 89 22r
- IFS steering, Idler arm Help?
- Clutch pedal bracket reinforcement pic request
- trans kicking out of 4th.
- ADD diff different from manual?
- headgasket...cracked block...other
- EFI swap?
- 86 Pickup coolant overflow issue-Head Gasket?
- Homemade Coolant System Pressure Tester!
- Why is my engine revving up and down at idle?
- Tcase output bearing?
- fuel door lockcylinder
- Removing tailgate window
- cold weather issues
- 92 4runner cam shaft oil seal leaking
- Fuel pressure up switch on thermostat housing
- 22re to 22r question
- Throwout bearing/carrier
- 1990 4Runner, possible burnt valves?
- Looking at buying 89 Toyota Pickup
- Rear Main Seal Retainer
- Cold Starting
- 88 4Runner Rear Bump Stop Options
- LCE Headers Install Help (EGR vacuum modulator)
- need engine help.
- IFS lift shocks
- Water pump seized up on way home
- 87 22r pickup no spark and no fuel
- 95 4runner no brake pressure.
- Mysterious Coolant Loss?
- 93 Toyota pickup 3vze timing question
- Help with 1993 Truck Fuel Pump
- Roof rack Mounts for 2nd Generation 4runners
- 22RE Oil Leak Advise
- Power steering part time
- Lightbar/bumper blocking radiator flow?
- A/C refrigerant question
- 22re fuel rail gasket questions
- Rusty Fuel Tank
- External Fuel Pump?
- Oxygen sensor
- Running without a gas tank
- engine advice?!?
- 89 pickup heatercore problem
- Heater control valve compatibility between 22re / 3zve
- 1990 22re pickup 2wd problem
- plz help wont start,no lights and buzzing relay under hood
- pickup vs celica 22re
- Where to buy a carb..
- No pressure in cooling system
- 22re starts ok when cold. stumbles and dies after 2min
- 4WD won't engage, no 4WD light, '89 pickup
- Fuel filter replacement
- Valve clearance adjustment
- Bit of a rough Idle During Warm up
- Fuel Tank Pressure test
- what cam should I go with?
- help adjust timing
- Hard wiring the cold start circuit
- 3.0 bad fuse? wont crank.
- 89 pickup 3vze - need to know what manual trans will work
- 86 4runner jack kit
- 22re into v6 truck
- 2nd Gen 4runner rear window off track
- What kills a fuel pump?
- 1986 4runner idle/ignition system issues
- bleeding master brake cylinder
- MPG issue
- need help finding year/model based on engine serial number
- 93 Toyota Pickup FSM - Mobile
- '94 Parts truck-what will fit my '86 ?
- oops
- 1994 4Runner 3.0 V6 not getting fuel
- Need some educating
- TIPS ON MY 22rte MOTOR REBUILD
- Looking for power or dimable side-mirrors for 88 truck.
- can i take apart a 92 3l v6 toyota distributor?
- my new 93 SAS runner, i need to fix alot of stuff
- Coolant gauge never gets to temp and heater doesn't work
- Intermittent wiper switch from 91 4 runner into 88 pickup?
- don'tfit
- Help identify this mystery 4Runner...
- 86' 22rec with weird injectors
- got me some new coopers!
- brake issues and egr ?
- 3vze cold start rough idel
- 1989 4runner EFI tuning program?
- spark plugs & coil
- Overdrive/Temp Gauge Intermittently stops working - NOT A RETHREAD; PLEASE HELP
- 89 4 runner 3vze mid temp stumble
- Loose Auto trans shift lever
- 3VZE Fix - Lessor of 2 evils
- Bearing replacement, seal orientation...???
- 2wd Door onto a 4X4
- horrible engine ping at low altitude
- heater pipes
- What wire tells the comp to fire the injectors
- 88 22r carbed
- Mystery 22re problem ! Getting fed up with this engine
- 1995 3.0 automatic 4x4 4runner
- Bad miss and horriable exceleration about to burn it !
- Weird system voltage issue
- Which Bilsteins to get
- Low rpm stumble after replacing fuel damper??
- were to buy
- interchangeable locking hub parts?
- what is this?
- headlight/tailight issue.
- 88 3.0 low oil pressure help
- Help! High Idle Regardless of Engine Temp
- 89 yota truck 4x4 conversion advice
- 87 Pickup Rear Axle Assembly Removal as Whole Unit
- Clicking Noise from ECU with A/C on only
- 86 4runner with 22re want 37s need ratio help
- Almost starts on first try, then nothing....
- centerforce clutch issue 86 pickup
- 22re idle problem, please help!
- Couple of bolt questions.
- Replacing water pump -- replace timing chain while I'm in there?
- '95 4runner power door lock
- Front right suspension blew...torsion bar or shock?
- 22RE high cold start idle
- Another 3.0 cross over mod
- engine breakin
- 1990 2-door CLEAN!
- 3VZE Strange starting problem - then runs fine
- 93 22RE exhaust manifold leaks, persistant problem
- Automatic Transmission swap.
- '86 4Runner auto trans prob
- 95 4Runner Code 52 easier fix
- 90 4R vibration on deceleration, what to look for
- 88 4runner suspension questions
- Cracked Dash? What's your solution?
- 93 22re engine squeal
- cruise kicking off
- '91 pickup 3.0 v6 3VZ-E not starting
- '94 4Runner ADD/Hub Question - ADD
- 1986 4runner ignition timing problem
- Another "steering noise" thread. Please help.
- fuel issue
- 94 4Runner electricial issue
- bolt specs?
- 1993 3vze idle issues
- 3vz-e v6 valve cover issues
- 94 3.0 pickup idle surge
- 93'truck 22re/w tranny into an 87'runner
- 1995 v6 3.0l Engine losing power
- M/T & transfer fluid capacity
- Bad engine mounts?
- clutch leaks
