REpair or REplace: engine trouble 1987 22RE
Old Dec 8, 2013 | 10:07 AM
letted's Avatar
HI
1987 4X4, 4runner, 22RE, EFI, automatic –rough, stalling idle ~500rpm, used to be 1000rpm. 100Kmiles on reman long-block installed by dealer in NJ; shoulda lasted longer. Had head gasket replaced on it @~47Kmiles, head not planed
No smoke, no mayo, no power—
Compression #1=115, #2=90, #3=145, #4 = 145
2 broken bolts on exhaust manifold gasket, leaks pretty badly
Mechanic diagnosis = burnt valve, possible worn cam lobe (this soon on reman LB)?
worn rings, cylinder, etc.
{A} He wants $300 to try and (1)extricate broken exhaust studs from the engine (good luck there), re-install another manifold exh. gasket(2) remove dome cover and gap valves 8 & 12 respectively, (3)remove and clean out throttle body
(4)replace fuel filter that’s probably filthy…
no guarantee on the Exh man. Bolts and he suspects something maybe worse lurking;
{B}Considering replacing another reman engine from engineparts.com in Oregon on Ebay @1100 + 580 ship to VT. 700 installation, plus I’ll need to pony up another h2o pump, radiator, Exh manifold bolt/studs, motor mounts, fuel filter, fluids, yada-yada…He’ll flush out the Throttle body, hook everything back up and should be a decent rig –TOTAL COST ESTIMATE $2800.
I’m not a mechanic; I’m a looker and a go-fer with some mechanical understanding.
The folks on Yota got the chops, maybe someone could advise option A or B or C,move on to another vehicle.
200K miles on chassis, rotted rear quarters and wheel wells, undercarriage rusty but not too bad; replaced half of everything imaginable, well maintained but a bucket with a hole. Thing ran great, shifted great, a bear off road, new tires, almost new tailgate from CA, perfect condition (find that these days)! Anyway, I prefer to keep the SUV but…..
I’m adverse to doing the smaller, machine shop examination looking for bad cam, or bad cylinder and get into a grand worth of parts, labor and end up with another boat anchor.
QUESTION: does the low compression trump the other possible causes of poor idle, to stalling dangerously upon de-celeraton making the thing undriveable for now.
Would/Could Toyota dealer(arrgh) computer exam elaborate as to what is wrong?
Fixing a host of things as outlined by mechanic still doesn’t address an engine with low/ unacceptable compression , especially in #2 =90 psi
Should this vehicle be recycled for parts?
Thanks
letted
Old Dec 8, 2013 | 06:13 PM
Duffdog's Avatar
At this point, it seems like there could just be a problem with the head. I would remove the head, take it to a REPUTABLE machine shop and have them look at it. I never put a head back on a 22re with headgasket issues unless it gets decked, period.
I once bought a 4runner with a "new" reman engine and the #4 cam lobe was flat after 1 week. Also, if the compression low compression is not due to the head, and instead you have a bad ring set on one piston (or bad piston) I would just look into a new engine.
Old Dec 9, 2013 | 05:55 AM
letted's Avatar
repair or Replace engine trouble 1987 22RE
Thanks Duff, will take under careful advisement, leaning toward another vehicle only due to rust issues with chassis, probably not gonna last another 5 years up here in VT. my last 4Run, 1989 SR5, lasted ten years before sides began to peel up and liftgate failed. It was a good ten years though.
bigjstang
Jun 2, 2025 03:56 PM
Colington
Mar 8, 2020 09:51 AM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
cyclist231
Jul 7, 2015 12:56 PM
