PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 [110] 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. timing cover plate
  2. Worth the swap? (Leaf springs from 87 Pickup to 88 4runner)
  3. 88 22re help!!! :(
  4. Bushings for front 3rd frame mounts
  5. Cheap ways to replace a headliner
  6. 190 hp 3.0 V-6 from CHS Machine 210 Torq
  7. I have low 4 with out 4wd
  8. Painting my top
  9. 3.0L owners
  10. driveline vibration question
  11. What does this temp sensor do?
  12. My 88 keeps killing fuel pumps!?!?
  13. TPS and high idle?
  14. 1992 4Runner A/C Port Schrader Valve?
  15. ADD reverse question
  16. ZUK Mod still rides stiff!
  17. 87 Truck backfires, surges, and sputters
  18. New Toyota!
  19. 89 rough idle and acting like it's lost power
  20. 22re need help
  21. I think my Transfer Case is shot
  22. What is needed for injector pulse
  23. 1988 PU 22RE won't start. Has gas, has spark, turns over,wont fire. Ran yesterday?!
  24. Advice to make her a safer ride?
  25. electrical help
  26. Bypassing Rear Window Wiring, Headed Straight to Battery
  27. AFM question
  28. sr5 gauge cluster problems
  29. what does this code for mycheck engine light mean?
  30. 87 4runner Problems
  31. gonna do the 3.4 swap
  32. Truck totaled 2nd time within two years
  33. 3VZE Rebuilt Engine - Low Compression - WON'T START
  34. Did Toyota change the parking brake from '85 to '89?
  35. 3.0 v6 engine noise
  36. '89 4runner Trans Swap: Wiring?
  37. electrical problem (door locks)
  38. Chopping back lower half of bed on a pickup?
  39. fuel sending unit
  40. There she blows....HG...time for 3.4swap
  41. Ac compressor help!
  42. Magnaflow 11225 muffler
  43. CV axle replacement- axle too short?
  44. EFI Relay over heats
  45. Any differences in 88 and 89 extended cabs?
  46. EB Street RV *check* 261 Cam *check* 22re blown HG *check*
  47. Code 25, goes away when raining
  48. 22r wont run right need help
  49. how do get the warnhub bolts out??
  50. Rear end is scalding hot after a long trip?
  51. 94 4runner 22re low power
  52. 95 4runner bad idle
  53. UCA bushing replacement
  54. Low compression and won't idle
  55. wrecked bumpstop in rear
  56. Another a/c thread
  57. where to buy weatherstripping?
  58. Quick question about the factory air intake
  59. 1st gen 4runner aftermarket sunroof
  60. inconsistent power/rough idle issue
  61. 3VZ camshaft possition
  62. Should there be ANY slack in the timing chain?
  63. Hydraulic clutch tubing?
  64. '93 3vze water pump/timing belt replacement
  65. 92 p/u fuel pump "quit"?
  66. installing twin stick (need help please)
  67. 22r crank bolt stuck...and I mean STUCK
  68. high load/roll-off lean ping problem
  69. Gaskets and Seals Needed for Knock Sensor Change
  70. How to deal with rust above wheel wells?
  71. Dual Case Noise Question?
  72. Clunking after adding rear coils
  73. All Hail the mighty Oz!
  74. Transmission Whine/Knock (Video)
  75. 22re Header Build...
  76. My new tires 255/85-16 BFG's
  77. Rear leaf springs
  78. Starter question
  79. what do you think about my rear [suspension]
  80. Help with Front end squeaks & rattles
  81. Stock fan Shroud is too big & won't fit on eithe radiator??? 1988 4runner 22RE
  82. 92 4Runner back window/tailgate
  83. Radiator Fan Shroud needed?
  84. what is a window glass adhesive dam?
  85. 90 4Runner Horn
  86. Fuel gauge just died
  87. Where does this go? (Pic)
  88. 4WD/Transfer case not engaging, DID search, PLEASE HELP !!!
  89. Trail Gear Front Bumper w/ lift
  90. 90 4Runner Headlights Won't Turn Off
  91. Adding a Brush Guard and KC Lights to my 91 4Runner
  92. 88 4 cyl truck braking problem...
  93. no gears in auto trans, 4whl low only
  94. Timing cover gasket surface question question
  95. Solid Rear window to Rear Slider Conversion Questions!
  96. 5" 6" rear lift springs --- don't want 63" chevys
  97. timing cover bolts
  98. Need knock sensor wiring info
  99. came accross weird sticker
  100. Cranks but won't spark? - 1992 Toyota Pickup 4x4
  101. T-case/Transmission gasket question??
  102. Timing belt question....
  103. 3VZE Knock Sensor Earth Wire question pls???
  104. 3VZE Knock Sensor Wire Position
  105. V6 3.0L Top End Rebuild, No Power?
  106. IFS - clearance for larger tires
  107. 3.0 coolant leak (intake manifold?)
  108. 1987 Toyota Truck dashboard lights issue?
  109. 87 Yota E Brake Broke>>>HELP
  110. timing cover 89 22re
  111. westin bull bar for a 94 pickup??
  112. Twistedyota's Battery Intake Swap
  113. clutch and vibrating problems...
  114. Help: Timing Cover Bolt Bottoming Out
  115. Sudden Power Loss
  116. drive train vibration
  117. Back glass
  118. How did you mount your clocked transfer case?
  119. 4runner tailgate window motor
  120. Ignitor has gone bad I think in our 87
  121. Retrofitting power locks?
  122. 88 22RE starts but wont stay running
  123. aftermarket temp sensor locations
  124. 2wd Frame Width and 4wd Frame Width
  125. Name these "things"
  126. shifting issues..smoking?
  127. Pizza cutter question
  128. Zero compression in 2 cylinders....head gasket or valves?
  129. Oil pressure sensor locations
  130. Sudden knocking in front bottom of motor, loud then soft
  131. 1991 4runner code 51?
  132. Never owned a 22R, what to expect?
  133. Looking for TRD Sticker Image File
  134. Realy weird engine lope when at a stop...
  135. Starting Issue...Baffling
  136. Questions about brake bleeding with Air Compressor
  137. 48" or 51" RUF conversion better?
  138. ZUK Mod on the Super Cheap!
  139. Truck Groan on startup
  140. Timing belt change: (tension spring)
  141. Where does this hose go?! 1992 Toyota Pickup 4x4
  142. new guy needs fuel pump help
  143. Changing speedometer gear/ A340H transmission
  144. Bad Piston Rings?
  145. 93 22re Runs like crap when cold
  146. Bought a FJ62!
  147. rte to re conversion (o2 sensor ?'s)
  148. Pacesetter headers
  149. Need new header and x-case rebuild kit.
  150. engine problem?
  151. Coolant Leakdown Results - Slow Leak - Now What?
  152. Front clip
  153. Leak in bell-housing
  154. Help trouble shooting a dead miss??
  155. 282 swap..... what tranny set up best?
  156. Trouble code 14 what is IGF and IGT?
  157. Will 2wd body fit on $wd frame
  158. Just picked up 94 4x4 how to tell if head gasket was replaced.
  159. uh oh! truk died and wont start again
  160. Vent-visor question
  161. 22re idle problem
  162. compressor kicks in but no cold air..
  163. Silencer Removal Mod
  164. got some questions...
  165. AC Relay?
  166. 3VZE Rod journal tolerances
  167. 2Dr carpeting
  168. 2nd Gen Two Door 4Runner Round Up
  169. no power @ EFI fuse or relay
  170. to spool or not to spool...that is the question.
  171. 89 4runner with a blown head gasket
  172. Made some new toys for the runner
  173. 88 4runner 22re rain issue(tried searching)
  174. 90 toy p/u won't move
  175. Jacking Position on Diff?
  176. Swaping spark plug wires question
  177. need help with 93 22re
  178. drinking water in rad
  179. Please help diagnose possible blown head gasket.
  180. rear diff identification
  181. Odd front suspension noises. HELP PLZ!
  182. 3VZE Timing Belt Kits
  183. Early 22r head on a late 22r block?
  184. 33x12.5 installed with no lift!
  185. Replaced injectors now wont even crank
  186. 22re hard to start when cold an when it starts it idels up an down
  187. 22re running cool
  188. Lets play, guess where this grease is coming from
  189. 86 yota no spark. Now what??
  190. 1994 pickup cali emissions? code 27
  191. HeadGasket... Any Experience with CNS Motors?
  192. 22re o2 sensor bypass
  193. 3vze 3.0 problem
  194. 22re troubles
  195. 22RE - Part Numbers for Coolant Tubes?
  196. Rebuild Advice & Ideas
  197. need input please windows movin slower
  198. To buy a used clutch or not???
  199. '91 HVAC Blower Switch
  200. Installed Load warrior rack 93 4runner
  201. Loss of trans fluid,Filling transfer box
  202. Compression gets worse per cylinder, warped head/block?
  203. 91 3.0 v6 pickup gas too rich?????plz help ppl
  204. Good Fitted Seat Cover?
  205. Headers
  206. 22r/RE propane build Q?s
  207. 92 transfer case
  208. Rear window relay question
  209. Thermostat~ w/ or w/out jiggle valve?
  210. Surging idle
  211. Oil pressure; need your help?
  212. does 1.5" bj spacer change or limit wheel travel?
  213. Outsane's EFI swap build
  214. 95 v6 3vze over heating after sealing headgasket and replacing thermostat
  215. Code 52 (Knock Sensor): An unusual cause....
  216. Starter problems
  217. Sway Bar Linkage/bushings uneven
  218. AFM Test Results
  219. E-Brake Relocating?
  220. Towing 2800 pounds on my auto 3vze - help with gearing identification and towing?
  221. Sorry, but another backup light switch question.
  222. '94 3VZE VERY sluggish after a head gasket, any help appreciated
  223. timing cover write-up?
  224. 89 22r-e electrical problem
  225. Drive Shaft Question...
  226. Welding up exhaust - pics anyone?
  227. 87 4runner trans swap
  228. Location of low side ac fitting, 2nd gen 6cyl
  229. cold idle issue/oil light flicker
  230. blow head gasket on 22re
  231. Passenger Back Window Won't Work. Need Help
  232. Resetting ECU
  233. My girl topless, well sorta
  234. Which one is the ignition wire?
  235. idle problems better yet what idle
  236. rv with 22re.. electrical cutting out while running
  237. 2wd Transmission Swap Question
  238. changing pinion seal without messing with bearing preload?
  239. Lighting issue HELP me!!!
  240. Need rear window help
  241. 87 Runner 4WD Shifter....
  242. Silly idle question...
  243. Timing chain too short
  244. one messed up 22re
  245. OME Coils
  246. Will 92-95 Front Bumpers fit on a 90-91 4runner? - The Answer
  247. Long Cranking Time to start 3vze
  248. CEL Help needed
  249. 22re surging only in morning just before warm
  250. Anyone spool front and rear? 89 4runner SAS
