Solid Rear window to Rear Slider Conversion Questions!
Old Jun 16, 2011 | 09:01 AM
pyrojoe22's Avatar
My truck is an 86 REGULAR cab 4x4. I got the rear slider window to replace my solid piece, but it didn't come with a gasket. And it doesn't look like my gasket will work. I need a gasket from a truck with a rear slider, correct? And is it the 4x4 vs 2wd or the reg cab vs ext cab that affects the size of the window?
Thanks
Old Jun 16, 2011 | 09:21 AM
MudHippy's Avatar
It's reg cab vs ext cab. 2WD and 4WD are the same. And no, sliding rear windows don't have a different gasket(it's actually called a weatherstrip), it's the same as a solid window. Notice the rib sticking out from the middle aluminum window frame all the way around it? See how it's the same thickness as the glass was? There's a reason for that...
I should also mention that the years you would've been looking for if you needed a gasket are 84-88. The earlier ones are too small, and the later ones are too big.
Old Jun 16, 2011 | 01:38 PM
pyrojoe22's Avatar
OOOOOOOOOOOMMMMMMMMMMGGGGGGGGGGG I COULD HAVE HAD MY TRUCK THIS WHOLE TIME!!! BAAHHHH
THAAAAAAAAANNNNKKKKKKKK YYYYOOOOUUUUUUU!!!!!!
i was trying to put the gasket in between the two ribs. Instead of on both ribs. I will go give it a try. The people at Toyota found two different part numbers for the 2 gaskets tho, and the people at Yota Yard said theyre different, also. But thanks!
Old Jun 16, 2011 | 01:42 PM
waskillywabbit's Avatar
Want to fix or replace glass on your Toyota? Don't ask the dealer, ask a glass shop. Guy that helps me at the shop does glass. Amazing stuff. Those back windows pop out and back in with a piece of 1/4" rope.
:wabbit2:
Jun 1, 2021 01:51 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
87turboPA
Jul 12, 2015 07:49 AM
coryc85
Jul 6, 2015 04:07 AM
toyoda8488
Jul 5, 2015 10:18 PM
