22re troubles
Old Jun 8, 2011 | 12:49 PM
94playtoy v6's Avatar
22re troubles
i just rebuilt my 22re new everything the truck is a 93 it has very low power than what it should, i installed my jumper wire and when at idle no codes than when u bump the gas i get code 51 it will only give that code if it is running, that is the only code, when i bump the gas it quits out untill i let off
Old Jun 8, 2011 | 01:03 PM
cjserio's Avatar
I think 51 is a TPS error code. Is the throttle sensor plugged in and adjusted properly?
Old Jun 8, 2011 | 02:11 PM
yes its pluged in and how do i adjust it? the screws and turn it?
Old Jun 8, 2011 | 02:21 PM
cjserio's Avatar
You might want to get a meter and test it out. Maybe it's plugged in but fried.
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Jul 17, 2011 | 03:58 PM
tysen86's Avatar
51 is switch signal? right? tps is 41?
mskalmus
May 28, 2017 07:51 AM
skoob
Oct 15, 2015 03:23 PM
mtc1105
Aug 4, 2015 08:06 PM
defrag4
Jul 31, 2015 10:50 AM
